Page 2 of 2 FirstFirst 12
Results 41 to 44 of 44
Thread: Lock nuts or castle nuts with cotter pin
  1. #41
    cruiser's Avatar
    South Glens Falls, NY
    1,467
    Atlee sent nylocks with his safety cables so I guess mine are STC'd?
  2. #42
    3,082
  3. #43
    55-PA18A's Avatar
    Dillingham, Alaska
    633
    Each year before changing from floats to wheels, I would call Stoddards and get a set of gear bolts sent out. They were always nylock nuts and undrilled bolts.
    Jim
  4. #44
    10,205
    Quote Originally Posted by 55-PA18A View Post
    Jim
    Is there a tab welded on the gear fitting which will prevent the bolt from rotating? If so, the bolt is not subject to rotation and an elastic stop nut is applicable. Just because the gear can rotate on the bolt, it does not mean that the bolt is subject to rotation. You need to be able to answer the question "Can something cause the bolt rotate?". If the bolt can not rotate it is fixed. Things can rotate on a fixed bolt.
  1. This is just NUTS!!!
    By cafi19 in forum Cafe Supercub
    Last Post: 12-08-2008, 05:30 PM
  2. Screws,Bolts,Nuts and Cotter Pins
    By Flying Miss Daisy in forum Cafe Supercub
    Last Post: 05-22-2007, 07:13 AM
