mvivion
SPONSOR
Maybe I am wrong, but I always either had full carb heat or no carb heat never partial, just cause temp gauge says its cold enough for ice means very little in my opinion
That is the most common advice, probably because carb air temperature gauges aren't that common in most airplanes.
They are fairly common in Cessna 180/182s, at least the older ones. That is because those airplanes do tend to make ice a bit more than other airplanes. If it is equipped with a carb temperature gauge, there's no problem running partial carb heat. Only down side is you're feeding unfiltered air into the engine, but at altitude that shouldn't be an issue.
Fly a Beaver sometime.....the POH calls for carb heat any time they're in the right conditions. POH says run sufficient carb heat to keep carb inlet temp at or above + 4 C (or was that +7C? Been a while.). Pull on full carb heat and it'll sound like the engine is dying...great way to scare passengers.
