Page 2 of 2 FirstFirst 12
Results 41 to 78 of 78
Thread: PA-12 Build
  1. #41
    Jul 2012
    Montana
    442
    Quote Originally Posted by deetz View Post
    working on my 12 now and a couple of clarifications to your post:
    The gross weight increase is probably from Charlie Center @ Crosswinds. The dogleg extended baggage is a different stc, probably from Ron Sullivan. Still not clear if the upper baggage is part of Charlies GW increase.
    the Gullwing door and modification to lower the door base makes getting in and out of the 12 easier. That is another STC from Crosswinds.
    you may also want to look at the pa-18 seat mod with the battery under the front seat, but that gets pricey pretty quickly. An Atlee Dodge STC
    i alos opted for the cub crafters fuel system stc to get rid of the header tanks, and put in a fuel valve with on/off/both as well as left and right.
    The 12 type certificate (or maybe it is the original drawings) shows the header tanks being an option, so no STC is needed to remove them. The Dakota Cub fuel selector and the sight guages are both very high quality and a great addition, as I recall cheaper than Cub crafters and they come with an STC.
  2. #42
    Apr 2007
    Kingsburg, CA
    1,256
    Hi Wayne. Good to hear from you. I ran across your name recently at home while looking for something else. Glad to see you are progressing on your project. I look forward to following you along. I haven't been on .org too much lately. I need to get back to this site. This will be a good excuse to do so. Take care.
    Kevin
    Thanks mbsyvers thanked for this post
  3. #43
    Charlie Longley's Avatar
    Jan 2008
    Arlington, WA
    654
    Quote Originally Posted by MT12 View Post
    My 12 doesn't have a header tank or the front STC'd lines.
    I've thought about putting the front lines in. But who in hell is going to be doing hard maneuvering when you're running out of gas?
  4. #44
    10,218
    Charley, All you will need to do is to have your nose too low when you're low on gas to stop the flow of whatever is left.
  5. #45
    Jan 2008
    Arlington, WA
    654
    Yeah I think when I rebuild it I'll put in the front lines. That's the way it came when I bought it.
  6. #46
    Sep 2016
    5
    Looks like a great project!!!
  7. #47
    3,575
    Left-front is pretty easy; right front less so.
  8. #48
    11,096
    Quote Originally Posted by Charlie Longley View Post
    power on long or steep decent
  9. #49
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    379
    Early in 2005, I had located an IA who was knowledgeable about Cubs, and, just as important, was local to me. In Feb/March, '05, he picked up my fuselage and brought it to his shop. Keep in mind that Univair did not yet have their jig ready for producing fuselages. One of the first things we attacked was the crushed right doorpost. The plane had landed upside down after it broke loose during a windstorm two owners ago. It bent the spars and lift struts, smashed all of the wing ribs and fuel tanks, broke the flywheel and twisted the fuselage. Much was repaired by the PO to some extent.
    We cut the door post and jacked the fuselage internally to square things up. The right front wing attach point was quite a bit lower than it should have been. I can't imagine how stall/spins would be in this configuration.
ID:	30008 Click image for larger version.
    We installed a Sullivan extended baggage, X brace, -14 cathedral, -18 landing gear tabs and cabane, float fittings, elevator controls, repaired the jackscrew tower, sleeved the tailspring mount, new door trim, replaced the doorpost and a few other tubes in the cockpit area, -18 trim system, boxed the tail, replaced the D window frames, replaced some of the piper channel for the boot cowl and false cowl and missing pieces for the skylight.
    The fuselage was then blasted and checked for perforated tubing.
ID:	30010 Click image for larger version.
ID:	30011 Click image for larger version.
ID:	30012 Click image for larger version.
ID:	30013 Click image for larger version.
ID:	30014 Click image for larger version.
ID:	30015 Click image for larger version.
ID:	30016 Click image for larger version.
ID:	30017 Click image for larger version.
    The fuselage returned to the hangar in September, 05. My wallet was also quite a bit lighter too, so the trip back to the airport was easier. I treated the bare metal with "A Must for Rust" recommended by Kent White for preventing flash rust from forming on bare metal. This gave it a blue-ish tint. When I got it back to the hangar, it was time for more evaluation. That is what you do when you don't know what the next step should be.
ID:	30020 Click image for larger version.
ID:	30019 Click image for larger version.
ID:	30021 Click image for larger version.
    Next step? Maybe work on the wing until I can figure out what to do next to the fuselage. We had not really addressed the condition of the longerons in the way of the jackscrew tower and tailpost. They were not perforated, having been replaced after the wind storm, but I thought they were still a mess.
    Wayne
  10. #50
    Jul 2012
    Montana
    442
    I have to say, I'm feeling its time for an update
  11. #51
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    379
    You are quite right... time for an update. As I write this, I have to dig back into the dusty, cobwebbed recesses of my mind.
    I moved the fuselage to my garage so I could spend more dwell time on it. If you remember from my early posts, the plane had been blown over in a wind storm in it's previous life. The wing tie-downs broke and the tail held. When it went over, it landed inverted hard enough that the flywheel/starter ring broke on impact. The wing tops were stove in and the fuel tanks were flattened, making their capacity closer to 9 gallons.
    All of this damage had been repaired (after a fashion) and the plane returned to service (sort of) prior to me purchasing it.
    With it now residing in my garage, I was able to evaluate it frequently. I purchased a set of ribs and fuel tanks from Dakota Cub. I also purchased spars to replace the ones on the left wing, which the PO had patched by putting two doublers on the web inboard of the lift struts. My IA talked me into installing flaps, so I purchased the flaps and kit from Dakota Cub. I also upgraded the landing gear to SC gear. I found a local 290-D2 for a good price ( false economy) that needed "just a bit of work" to make well.
    I happened by the Univair booth at OSH and discovered that they were selling repair sections for the fuselage on 12s now. I ordered and received the "short" section, which included about 8' of longeron forward of the tailpost.
    Now, to find someone that had a -12 jig and the capabilities to weld it on and assure that the rest of the fuselage had been returned to square.
    I loaded the fuselage into the truck early one morning and set out for the shop. Driving around Minneapolis during the morning rush with 10' of extended load woke up a few drivers, I suspect.
    Approximately eight months passed before the fuselage made it into the jig. And then, it was discovered that the tailpost was off plumb by about 5 degrees. Univair was contacted and they exhibited OUTSTANDING customer service by shipping a new one and accepting the other one by return freight. Thank you Jim.
    A month or two later, I took delivery of the fuselage.
ID:	31945 Click image for larger version.
    In the interim, I retired from my day (and night) job and purchased a hangar at the ANE airport and met Darrel Starr, Windonhisnose and a bunch of the SC.org folks who reside there and around the area. The hangar was an empty shell of a pole barn. If I was to be able to work on the plane during the winters, it would need to be insulated and heated.
ID:	31947 Click image for larger version.
    Next up: the rest of the modifications, hangar updates and what have I been doing since I got the fuselage back in 2012
  12. #52
    180Marty's Avatar
    May 2004
    Paullina, Ia
    2,054
    I'm curious, who did you take it to for the jig work?
  13. #53
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    379
    The fuselage never ended up in a jig. It was attached to a "table" made up of two I beams welded together and ground flat and level to 0.030" end to end and diagonally.
ID:	31955 Click image for larger version.
    The work was done at Jay's shop in Brainerd, Javron Inc. It happened at a bad time for scheduling. He was in the middle of building his new shop for manufacturing Cub airframes and there was not enough room to set up the -12 jig in his old shop.
    The table was a compromise but I am confident the fuselage is as straight as it will ever get. He did a great job on it and it was worth the wait.
    Wayne
    Thanks 180Marty, Bill Rusk thanked for this post
    Likes windy, Hardtailjohn liked this post
  14. #54
    Jun 2018
    England
    455
    Is this project still ongoing? THANK YOU for posting all the pictures!! This has really helped me to see under the skin of the PA-12 and helped to understand mine!! I'm currently wondering how to get access to some of the stuff that's under the outer layer of fabric (over the stringers) and outside the frame fabric itself in the cockpit area, for example fuel switches, trim assembly, fuel pipes etc.
    Question: can I just cut holes in the inner cockpit fabric, for example at port rear, covering the trim cables etc, or is this fabric area part of the overall "stretched and stresed" fabric and therefore any holes should be contained within glued on rings etc?
  15. #55
    11,096
    Quote Originally Posted by Philly5G View Post
    you could remove all of the interior if you wanted to... not structural...
  16. #56
    Jun 2018
    England
    455
    Thanks Mike!! The other PA-12 at my airfield has solid panels, where I have fabric. Which was the original fit when the aircraft were originally built?
  17. #57
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    787
    Wow. 13 years and untold thousands of dollars in mods. Looks like it could be a nice one when you " getter done". Hope it turns out for ya! Your a much braver man than me........ And have the patience of
    Jobe.
    Wishing the very best on this massive project!
    Best of luck
    E
  18. #58
    11,096
    Fabric.
    But most everyone switchís to aluminum or kydex
  19. #59
    11,096
    Hereís some I made with kydex.
    https://goo.gl/photos/HmUX41Zzr5sDagzDA
    https://photos.app.goo.gl/HEgiiJwbFwE6gsaU8
  20. #60
    Jun 2018
    England
    455
    Thanks Mike, they look great! How did you attach them to the frame?
    Every day's a school day
  21. #61
    11,096
    Somewhere in there it shows how. Lip mounted to floor.
  22. #62
    Jun 2018
    England
    455
    Thanks Mike Iíll take a closer look
  23. #63
    Jun 2018
    England
    455
    Thanks Mike I’ll take a closer look
    I've just looked at the pics from my Mac and not my iPhone and there's loads more pics than the phone app shows and I can see there's a LOT of work gone into these!!!!!! They look EVEN more great!!!! Top work!!
  24. #64
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    379
    Yes, I am still plugging away at it. I installed a PA-18 seat and removed the truss. I am installing a seaplane door (right side only) and made one from cheap 3/4" square aluminum to get the dimensions and swing correct. Also to work out the hinge attachment. The new door frame was made from 6061 3/4" aluminum with rounded corners. I am currently working on a latch for it.
ID:	38879 Click image for larger version.
    I made templates for all of the interior panels except for the one behind the left D window. I also have the templates made for the lower luggage compartment.
    I need to mount the wing so I can get the flaps rigged so I began working on the left wing. All hardware was removed, cleaned up and painted or powder coated. New ribs, spars, ailerons, flaps, leading edges, bows and fuel tanks (Dakota Cub) and fasteners.
    In the meantime, life keeps getting in the way of progress.
    Wayne
  25. #65
    11,096
    Did you use the newish Atlee dodge STC for the -18 front seat?
  26. #66
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    379
    Newish? maybe... It is dated 6 Feb 2013 on the -12 instruction sheet and 3 Jul 2013 on the drawing, and 3 Sept 2013 on the MDL STC SA02418AK.
    Thanks pfm thanked for this post
  27. #67
    11,096
    Quote Originally Posted by flybynite View Post
    Yes thatís it. We always had to get them field approved. Nice that itís now STCíd.
  28. #68
    Jun 2018
    England
    455
    Thanks for posting all these photos!! They really help me in seeing what's under the surface, when figuring out what's the fix with my own PA-12!!
  29. #69
    Cranman
    FLORIDA/WISCONSIN
    216
    I thought the 12 had 4 1280 bungees. Looks like there are three on each side.
    A gun is like a parachute. If you need one and don't have one, you'll probably never need one again.
  30. #70
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    379
    There are three each side on the original gear.
ID:	39344 Click image for larger version.
    These were "before" shots.
    Wayne
  31. #71
    flybynite's Avatar
    Oct 2004
    Eagan, Minnesota
    379
    It is now January, 2019. Progress has been glacial, but ongoing. Last entry was beginning work on the wing to settle some alignment questions with the fuselage and control cables.
    I built a simple table to work on the wings. I leveled one end and used diagonal crossing strings to align the other end. I had the new spars alodined at a place in Minneapolis that does light poles and large pieces of architectural trim.
ID:	40796 You can see the " table" in the left side of the picture here, supporting the spars. Just a piece of plywood screwed to the legs. A piece of osb ties the other end to this one.
    I followed the wing assembly procedures that came with the Dakota Cub rib STC.
    Dakota Cub listed the location for the ribs in their procedures. The installation of their fuel tanks requires moving some ribs and compression struts and installing a brace tube in the tank bay.
    I ran into an interference issue with the tank and compression strut just outboard of the tank bay.
Name:	20181105_155417 zoom_LI.jpg
ID:	40797 The new strut supplied with the tank kit uses bolts to hold it together. The original Piper used rivets. I took the bolts out of the strut first and turned them around so the head was toward the tank (this picture) but still, I wanted more space. I replaced this strut with the one from the end of the wing (original Piper) and resolved the problem.
    I am using the Sullivan STC for flap installation. There are a number of issues related to the drawings and dimensions for this STC. The issues have been discussed many times on this site.
    I assembled the flap hinges and aileron hinges and hung the flap and aileron to see how different the issue would be on this plane. I used super glue to temporarily fasten the bellcrank bracket to tape I put on the spar.
ID:	40799 I established where the control cables entered the wing and made a cardboard template I taped to the root rib.
    The green strings are the routing for the aileron controls and the orange electrical wire is where the flap control winds up. There were also issues regarding the strap locations for
    the fuel tank supports. The one you see here (green) has to miss the bellcrank bracket and the wing root attach bracket on the forward spar.
    I played around with moving the bellcrank up and down a bit.
ID:	40800 Click image for larger version.
ID:	40801 I used a small piece of baling wire to see how far I would need to deflect the control cables to clear the flap pushrod and bellcrank.
    I also had to move the rib outboard about one inch to clear the bellcrank. If the bellcrank is moved lower than it is in the right most picture above, it contacts the flap hinge arm instead of the stop.
    At this time, the hole is drilled for the flap hinge bracket. NOT where the STC calls out, but the spar print from the Northland cd.
    Still have to get a location for the flap return springs. Think it is Mike S. who recommends two springs on each flap.
    One of the newer flap STC diagrams shows a bracket used to keep the aileron balance cable off the flap pushrod. Many folks here argue that is a high drag and wear point for the cable. I agree.
    I plan on using a small pulley to divert the cable. The pulley will mount to the rib adjacent to the bellcrank.
    Happy new year all!
    Wayne
    Likes Hardtailjohn, stknrddr liked this post
  32. #72
    10,218
    Don't forget to block the rear spar at the outboard rib for the proper twist prior to installing the leading edges.
    Thanks flybynite thanked for this post
  33. #73
    3,575
    I had to install something to deflect the aileron cable from the flap mechanism in my -12. I used a nylon fairlead, though with a little bit of trepidation. I did some calculations for the lateral and frictional forces between fairlead and cable and determined that the friction would be small. In practice, I was happy to find that it works just fine - my ailerons are smooth with very little friction discernible at the stick, including in flight.
  34. #74
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,959
    Exactly the same story with mine. The fairlead caused no perceptible change in stick feel. If I remember correctly, the interconnect cable was rubbing the flap return spring slightly. The deflection induced by the fairlead is very small.
    Likes pfm liked this post
  35. #75
    Jun 2018
    England
    455
    Maybe not relevant but....... one of the fairleads was missing in the aileron circuit of my PA-12, Iíve only had the plane 9 months so donít know how long itís been missing, but the aileron cable sized hole it was sawing through the mounting bracket was VERY scary!!!
  36. #76
    Jun 2018
    England
    455
    PA-12 Build
    Fitting the replacement meant cutting another access hole and a LOT of struggling to get the locking ring on............
    Sent from my iPhone using SuperCub.Org mobile appClick image for larger version.
ID:	40933Click image for larger version.
    Thanks Stew, flybynite thanked for this post
  37. #77
    San Juan Islands, WA, WY, AZ,NM,UT
    254
    The other day I needed to install a circle clip on a fairlead in an un-handy place. I got a pair of spreader pliers with the small pins used for drilled circle clips, put them inside the fairlead clip and Voila! on it went. Gonna use them all the time now. even in a "good" place they are a pain to install with needle nose pliers or something similar.
    Shiny side up!
    Thanks Philly5G, marcusofcotton thanked for this post
    Likes Philly5G, mike mcs repair liked this post
  38. #78
    Jun 2018
    England
    455
    PA-12 Build
    Quote Originally Posted by Hyrdflyr View Post
    Shiny side up!
    Well done!!!! We tried this, but couldnít get the circlip pliers on to the locking ring because of the access situation BRILLIANT you had better luck
  1. Pirate Cub Build
    By Sonexpilot in forum Member Projects in Progress
    Last Post: 08-25-2013, 07:00 AM
  2. Considering a build...
    By Helmetfire in forum Experimental Cubs
    Last Post: 01-18-2012, 03:05 PM
  3. Which door to build
    By storm_pilot in forum Experimental Cubs
    Last Post: 01-06-2007, 11:54 AM
  4. Build Your Own Paper J3
    By SJ in forum Cafe Supercub
    Last Post: 11-08-2006, 09:51 PM
  5. budget for re-build
    By JMBreitinger in forum Products, Purchases, Reviews & Prices
    Last Post: 05-06-2004, 04:52 PM
