Page 1 of 2 12 LastLast
Results 1 to 40 of 42
Thread: Ski rigging techniques
    spinner2's Avatar
    Montana
    1,729
    After recently rigging my Carbon Concepts board skis I Thought I'd share my technique and where I sourced materials.
    Both my plane and the skis are not certified so I'm not bound by an STC or Field Approval. I made reference to both 43.13 and Dodge's online ski rigging tips. Both are very helpful.
    The skis were received from Randy with pedestals but no rigging or attach points on the skis.
    I purchased the toe and tail attach fittings from Stoddards along with stainless steel axle washers. The fittings that attach on the gear bolts and the bungees came from Reeve's.
    I found some stainless steel clevis' with a high load rating from industrial supplier MSC that came with a 5/16" diameter pin.
    The threaded half of the clevis is threaded 5/16-24 so I replaced the pin with and AN5 bolt and as a keeper threaded on an AN nut. The plastic donut is UHMW that I machined a 1/2" radius into and drilled 5/16" for the bolt to pass through.
    On the gear attach point I used a Ronstan brand 6mm stainless steel, high load rated chain link. A hole was drilled though the hex section to accept a cotter key.
    The second cable on the right is the check cable.
    Setting the angles for ski movement was made easy using a chain hoist, comealong, and a smart level.
    The first step is to set the length of the check cables. I went with a maximum down angle, should the bungee fail, of nine degrees. 43.13 allows for considerably more than this, but less seems better as long as there is enough slack to allow full ski movement over uneven ground.
    The next step is setting the length of the rear cable. With the skis flat on the hangar floor I raised the rear of the plane with a comealong. I found that one click of the ratchet was equal to one tenth of a degree on the smart level with the placement I used.
    I went with 1.5 degrees nose up ski attitude in flight. This meant raising the tail 1.5 degrees above level and the setting the rear cable to this length.
    Lastly the the bungees are attached and the length of the crust cutter cable is determined by the amount of down force required to stretch the bungees. 43.13 has a poundage guide based on ski displacement. This step is a little subjective and not real easy to measure. But the end goal is to have enough tension on the skis through the bungees that there is no in-flight flutter of the skis.
    The rigged skis weighed 33.2 pounds each. 1/8" diameter control cable was used per 43.13 for skis and a plane this size. After finding the center of balance for the rigged skis I made a new W&B. This is easy to do when existing component weights and arms are already in an Excel file.
    A pair of Dolly's were fabricated too.
    I'm sure there are other ways to accomplish the same results but this is how I rigged these skis.
    1,706
    Keep an eye on your rear ski thimbles. If you notice stretching or flattening of the shape and often taxi over big drifts add some length as more nose up/longer rear cable may be desired.
    GAP
    Thanks tdusin thanked for this post
    9,845
    Also after your bungees are setting in tension for awhile ( tail down ) that your bungees won't return to where you originally had them, they stretch out a little
    Thanks Poor Joe thanked for this post
    Likes Poor Joe liked this post
    1,706
    There was a time when it got cold that bungees were replaced with Atlee Dodge springs. On the ground the bungees wouldn't react to changes in ski position quickly enough and tended to stretch in flight under wind load and flop around. That's at about -30F or colder in my experience. Maybe there's better shock cord material available now or some skis can't use springs for some reason. I like springs as they never wear out much due to sun and weathering.
    GAP
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    673
    GAP
    No experience with skis, but I've watched regular bungee cords slack to full extension in roughly-20/-30 weather. When brought back inside to warm up, we watched them shrink back to their normal unstretched size as they got back to room temperature. If I was flying anything that depended on bungees in a really cold environment, I'd look into springs too.
    1,718
    Put some silicone tape around that wire at the top of the bungie it will start to chafe quickly due to the wind.
    spinner2's Avatar
    Montana
    1,729
    Good suggestion. I put some spiral wire wrap around both ends on both sides.
    9,845
    And it's safe to use the $2 3/16" chain repair links sold at Ace, I hooked one between my truck and tractor and couldn't break it.
    Thanks A BELLAND thanked for this post
    9,845
    We had a foot or more of snow last Sunday but then the wind blew for a few days. Got to play a little today
    Step comes in handy
    Was having fun till freezing rain
    3,827
    Joe didn't come play?
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,100
    Glenn, telling us Alaska boys you have been ski flying is enough to get this thread sent to RnR
    "Always looking up"
    9,845
    Don't you have any snow?
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,100
    Nothing here in southcentral (Wasilla/Anchorage/Kenai). Airstrips dry as a bone. Only chance for skis is being based on lake ice, but then there is nowhere yet to land other than some other lake. Not sure how northeren Ak is doing.
    "Always looking up"
    4,705
    We need the ice before we need snow.
    May 2011
    Eagle River
    269
    After recently rigging my Carbon Concepts board skis...
    Nice work. I hope to see these skis out and about this winter. Up here I mean.
    Likes WanaBNACub liked this post
    May 2011
    Eagle River
    269
    Nothing here in southcentral...
    Ya, nothing but hoar frost on top of ten inches of ice here. We have half the equation. Now we need ten inches of snow.
    Ruffair's Avatar
    Jan 2008
    Lower Chena
    1,254
    Good ice, no sno on Dune Lake, (sw of fai )
    btw, this photo my get submitted for next calendar thing.... Cause I didn't take it..!
    nanook's Avatar
    Aug 2002
    northern alaska
    1,653
    GAP
    that is why 1/8" cable is too small for the check cable... Lose the bungees for springs...
    spinner2's Avatar
    Montana
    1,729
    I've got about 25 hours and perhaps as many as 300 landings on these skis now and I am really pleased with the skis and the rigging. Without snowshoes on, the snow in this picture would let me sink past my knees. These skis also turn very tight with some forward stick both to the left and right.
    I made a takeoff a few days ago into a 20 mph headwind and a DA of about -1500' and I'm sure the skis didn't slide more than about a ski length before I was in the air.
    Likes jwmusgrove liked this post
    Aug 2002
    Talkeetna Alaska
    262
    "I've got about 25 hours and perhaps as many as 300 landings on these skis"
    Wow. A landing every five minutes? Wow.
    spinner2's Avatar
    Montana
    1,729
    Quote Originally Posted by Randyk View Post
    I didn't do the math but I love to make multiple landings. I've got a couple of places, like on the reservoir yesterday, where I'd take off and get about 25' in the air and then make another landing. A minute or two later another one. And out there you can do that for 10 miles each direction. It doesn't take long to make a bunch of landings. Yesterday was such a great day I was out there for a long time....
    9,845
    Until you get powder like that to play in nobody will understand.
    A very stick puppy's Avatar
    Nov 2014
    Lake Clear NY
    138
    Step comes in handy
    Seldom does a week go by that I am not asked by customers and local friends "why do you enjoy that Glenn guy so much?". I think his pictures answer the question - who on the planet could not love a guy who has a 12/3 SkiDoo (okay - so it doesn't have the optional front bumper) and a turn of the century (pre 1900's) metal lawn chair along with a pristine (and well used/well cared for) pa-11 in his hangar? Add in his most recent comment about skiing in powder and I think even Joe will have to agree - Glennie is a rock star.
    9,845
    You missed a couple others, like my 1965 steel chain track Artic Cat 120D. Engine was seized and every link in the track were seized tight when I got it.
    https://youtu.be/WKeS26lRNRU
    https://youtu.be/Qt6oDkzX_Nw
    https://youtu.be/zEwrEoaKDrc
    https://youtu.be/7f6y2B1IPmQ
    PS. And your customers questions are scaring me
    Nov 2014
    Lake Clear NY
    138
    To be honest and up front, my customers scare me. But they give me money.
    spinner2's Avatar
    Montana
    1,729
    Today was another excellent ski flying day and I decided to go back to the reservoir. Wondering if I'd overestimated how many landings I may have made out there a couple of days ago, I thought I'd time myself doing a couple of 10 set landings routines with the stop watch on my iPhone. It surprised me. The first 10 took 2 minutes 16 seconds. The second set of ten were 2:44. That's 20 landings in 5 minutes.
    These are not FAA type currency landings for a tail dragger. I takeoff and almost immediately setup for the next landing. Few of the landings are full stop. Most of the time I'm pushing in the throttle again when I've slowed to about 20 mph. Then a throttle bump and it is off again. Sometimes I'm changing from 2 notches of flaps for takeoff to 3 notches for landing. But sometimes I leave it at 2 or 3 for both. And some are done with no flaps.
    I was introduced to this type of landing routine years ago when I got a seaplane rating in a PA18. The instructor had me do landing after landing like this on the lake we were operating on. We went for miles doing this. It was fun and didn't take long to get the sight picture and procedures established this way. It is still way too much fun.
    There is a lot of places to land out here.
    I didnt like seeing this; laying some tracks showed overflow on the next pass. Glad I didn't stop here.
    The overflow was in the shaded area on the far side of these islands.
    S2D's Avatar
    May 2002
    Montana
    4,063
    I'm kinda curious what that circular structure is out back at the 25 sec mark !!!!
    9,845
    Cedar Henge
    9,845
    Used to be a large dairy barn where my hangar now sits, burned to the ground in 79. I'm stuck with a 10' deep X 20' blue harvester silo concrete foundation, I started make a ? structure out of it.
    S2D's Avatar
    May 2002
    Montana
    4,063
    Oh !!!! And here I thot it was an Indian sweat lodge for giant Indians !!
    9,845
    It makes a good bandstand for summer hangar party's
    Jonnyo's Avatar
    May 2014
    Fairbanks, Ak
    112
    Camber angle
Name:	wheel camber.jpg
    For skis, I currently have my camber set to zero, with the airplane sitting on the ground, at the weight that I most often land. Does anyone set negative camber ? If you are snow skiing and you ever allow your downhill edge to tilt down ( positive camber ) you usually face plant immediately.
    The weak link for Supercub gear is a load inward, not aft. Of coarse you try not to, but I have had to turn with the outside ski lower than the inside ski. The landing gear is receiving a huge load inward because the outside edge is digging in. Some negative camber might help this. Having the inside ski dig in slightly, ( because of the negative camber ) might help pull you around ?????
    Thoughts, comments and ideas welcome !
    Jonny O
    nanook's Avatar
    Aug 2002
    northern alaska
    1,653
    Hey Jon, what skis are you using? They are usually slightly positive until the fat pilot gets in with all his gear and fuel! You should be sitting flat on the skegs loaded.
    Dec 2004
    Inkom, Idaho
    1,371
    GAP
    I noticed that on my Datum setup,deformed thimbles indicating a major pull on the 1/8" cable. I kept a close eye on the bolts and and the bushings the bolts go thru, and didn't see any further cause for alarm, so kinda blew it off/didn't do anything. I do a lot of uneven terrain, especially going up my ramp to the hangar, every flight. The issue is, if I lengthen the rear cables, the inflight AOA will increase beyond what I want, and I'm already a bit more nose high then otherwise needed. I guess my "solution" is to continue to just keep an eye on things, it's been like that for the last 6 seasons, with no further thimble deformation. They are deformed a bit but not flattened. My old hang gliding experiences taught me that when a thimble deforms, you have reached the working load of the cable, and then some. If we saw that, we threw the cable away and re rigged it. I suppose I could re rig back there, the same lengths, and see if it happens again, and if so, after what taxiing conditions. Maybe do that, but use the next size cable up....my bushing attach bolt is AN-4.
    Spinner2: Your rigging process sounds pretty straightforward, compared to figured out how/where to rig on retracts, having to take into account the fore and aft movement they have. Straight skis, must be nice! Yours look great.
    9,845
    Quote Originally Posted by nanook View Post
    All the federals I've flown are negative camber.
  36. #36
    nanook's Avatar
    Aug 2002
    northern alaska
    1,653
    always depended on the shape or age of the bungees on my federals. New bungees made them slightly positive.
  37. #37
    Dec 2004
    Inkom, Idaho
    1,371
    Right here: at 10:13, going up my ramp, is what causes my rigging issue. https://www.youtube.com/watch?v=ycv2GDm2DOo&t=66s. I got to play the hero in this video! Better then the zero.
  38. #38
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,388
    I didnt take time to load and watch the vid.
    Some ski installations have a strong spring on the rear cables for any extreme “ski-noseup” events. The aft spring needs to be stronger than the front bungee, obviously. A short loop of bungee has less give than a longer loop, so a shorter loop of the same diameter and durometer as the front bumgee works great.
    Likes courierguy, DENNY liked this post
  39. #39
    Jonnyo's Avatar
    May 2014
    Fairbanks, Ak
    112
    The skis are Atlee Dodge composites. Yes, they are slightly ( 1.5 degrees ) positive camber empty and about 3 degrees negative with full fuel, winter gear, 155 lb pilot, tent, woodstove and etc. I pumped up my Acme Gen 3 shocks to be stiffer for Winter ski flying, in the Interior, with our very deep sugar snow and very little crust. Thanks guys.
    Jonny O
  40. #40
    10,530
    As somewhat of an aside.......I REALLY don’t like the forward limit cables on skis rigged to the gear bolts. I MUCH prefer they be rigged to lower engine mount bolts. Much better and safer geometry.
    And, yes, I realize some installation instructions call for mounting to gear bolt.
    Thanks G44, Jonnyo thanked for this post
    Likes G44 liked this post
  1. Bending techniques
    By TheSponz in forum Experimental Cubs
    Last Post: 10-23-2016, 08:44 PM
  2. Proper Leaning Techniques
    By WindOnHisNose in forum Cafe Supercub
    Last Post: 03-22-2010, 02:29 PM
  3. Short Field Take Off Techniques
    By supercub in forum Tips and Tricks
    Last Post: 11-22-2002, 07:05 PM
