So, here’s a question: For those using the Earth X batteries in certificates Aircraft, what did you use for a basis for that installation?
Good question. There is a gal who works at EarthX, forget her name but she knows the products inside out. I'd suggest a call to them. My experience has been positive with them.
Just reading 41-13 on battery. There is nothing says must be certified. Just says different batteries for different uses. So- seems to me it is just a minor alteration to change from one battery to the next.
Ok- blast away!
I hope that you speak in jest since that is most certainly NOT a description of "Owner produced part". If you are not making a joke, I suggest that you do a little research.Owner produced part. Used the “spec the part” side of owner produced and requested EarthX build it for me. Got lucky, they actually build a battery that matched my specs exactly.
There is also an excellent article on EarthX in the December 2017 issue of Kitplanes magazine.
I've ordered a new Earth X battery and now I am seeing a lot of posts about them burning up. Any new information on them, should we be putting them in our planes? is there an installation issue that needs addressing? if anyone has info on why they have burned up, I'd sure like to know.
I'll let you install one in your Super Cub and sign it off David and we will see what happens.
I don't see enough data to install it via my A&P license. Would take a long conversation with my FSDO and then research their opinion.Soo what are you saying? Agree or Disagree? Not a valid point? Ummm
Ok, so now begs the question to all of you mechanics, and pilots:
You fly a certified plane in cold weather, battery mounted in the back so pre-heat won't touch it, and plane is left outside for a few days at a time so gets cold soaked.
You need a new battery, what would you buy and install?
If you are doing an annual on a plane and a guy has a non-approved battery, what do you do?
