There was about 2.5 # difference between the 3 with the fresno being the weakest... using a valve spring checker is not easy for this size spring and have it accurate.and at 35 psi oil pressure the relief is suppose to start opening up.
Someday I will do a demo on how to build a -8 oil pump that should not wear out in 5000 hours and not require any bushings...
