BENEFACTOR
Solo a lite C90 J3 or Pa11 with the right prop will beat almost anything off the ground. My 11 with a seaplane prop turned 2700 taking off and with me in the backseat was airborne in 125' no wind.Glenn
2650 for 5 minutes but what it is is what it is for a 90, glenns is a 200. rpms is a 200s best friend.
I thought Max RPM is 2475 for a C-90 powered 11.
Don't hold your breath, I turned blue year ago...
If it was a certified prop I would tend to agree, but as I read it one who takes that approach might want to start practicing their best kicking and screaming in case of a challenge it could get ugly.Two best mods besides 100LL are a good prop and 29" Airstreaks IMHO.
As far as a Catto goes...
From the J-3 / PA-11 TCDS
"101. Propeller - Wood (fixed or adjustable pitch)."
Sounds like a Catto is already named in the TCDS to me.
What diameter and pitch would you recommend for a propeller? Maybe a Mccauley 7141? I don't want to risk too high of an RPM, but want it biased more towards climb than cruise
Hey all, I was looking for some advice on giving a J-3 (with the C-90 engine) the bush plane treatment (STOL kit, Bush tires, climb propeller, etc) and was wondering if you all had advice on any modifications you would do. I don't want to do anything too drastic and have a fairly limited budget, but I still want to make it bush-worthy. Thanks! I attached a picture of the plane.View attachment 26502
I've always been under the impression that the FAA used double sided hammers to pound on us. So to be legit it has to be on the TCDS or Otherwise approved, STC, field approval, etc. (first side of the hammer) AND the part has to be produced by a PMA or otherwise certified shop or recently as an owner produced part (second side of the hammer) for an oldie... What am I missing here?Perfectly legal, the TCDS just calls for a wood prop with length and rpm limits. Did it on a Stearman the same way sever years ago. Unfortunately the PA18 TCDS is not written that way.
Should mention second best mod: Skis!;-)
DENNY, this was my grandpa's cub, and he gave it to me. He is incredibly meticulous and careful with his work, so I'm guessing that the gear was inspected recently.
