Results 1 to 5 of 5
Thread: PA-11 Cowl Info
    Jul 2016
    2
    PA-11 Cowl Info
    I am constructing a scale PA-11. I have been unable to find useful information regarding the design of the cowl, and it would assist me greatly if anybody could provide any insight as to its design/dimensions. If there exists any accessible plan/schematics that would be ideal, otherwise any knowledge pertaining to its measurements would be extremely helpful.
    -Much appreciated
    10,587
    If it helps it's the same as a Pa-18-95
    Jun 2007
    New Zealand
    491
    Go to supercubproject.com, click on drawings and search on "cowl". You can also find a Super Cub parts book on line and look up the part numbers for the PA-18-95 cowl and search on those part numbers at that site. Lots of cross-over between the PA-11 and Super Cub.
    Andrew.
    Jul 2016
    2
    Couldn't find sketches of the part so I drew my own design. I think it turned out pretty accurate:
    PA-11, PA-18-95 Frontplate:
Name:	PA-11 Cowl Design.png
    Jun 2008
    Ferndale wa
    7
    Cowling
    Quote Originally Posted by Bob1234 View Post
    -Much appreciated
    The pa11 and the Pa-18-95 are not exactly the same. I was converting my j3 to a pa 11 and I went to Univair and had them put the pieces side by side. The pa1895 has a swing mount and the pa 11 does not. The cowling pieces are just a little long on a pa18-95 then a pa-11. This is Because of the swing mount. It is only around 7/16 to 1/2 longer. the most expensive part is the nose bowl. The other pieces where relatively cheap compared to the nosebowl.
  1. Metal for boot cowl and engine cowl
    By Jim Miller in forum Experimental Cubs
    Last Post: 05-13-2015, 10:30 AM
  2. Webbing on nose cowl & boot cowl
    By cubnut93 in forum Tips and Tricks
    Last Post: 05-24-2014, 10:04 PM
  3. McFarland Cowl Seal Installation and Cowl Fit
    By Darrel Starr in forum Cafe Supercub
    Last Post: 03-30-2009, 10:42 PM
