Page 15 of 16 FirstFirst ... 513141516 LastLast
Results 561 to 600 of 601
Thread: J-4 project-3.14159265359
  1. #561
    RVBottomly's Avatar
    Sep 2017
    787
    With your build you need to support the vertical fin since it is just a single tube with a joint at the bottom.
    Right. I was thinking more about streamlined struts as opposed to wires from the vertical fin to the horizontal stabilizer. Don't know if there's much difference in drag.
    Off-topic, but I noticed the Husky uses struts from bottom up. No bracing on the vertical stabilizer?
    Edit to add: never mind about the previous question. Not enough coffee yet.
  2. #562
    Mar 2016
    1,430
    The Huskys I have seen are fully wire braced, I presume there is a newer model that does not need the Vfin braced?
    There have been plenty of studies about the drag difference between round wire and streamline wire. But a standard Cub would not be a plane that I expect would be measurably faster with streamline wires. There are way to many other drag areas to fix before hundreds are spent on fancy wires.
    I expect the streamline struts I an using might be no better than the round wires. I have not done any calculation of two 3/8 thick struts compared to four 3/16 round wires.
    Mine will be faired better at the intersections but might be a wash.
  3. #563
    Mar 2016
    1,430
    Second set of outer ends for these struts. These are not finished but they are ten fold better than the first set.
    I need to acquire the shims needed to set the struts up properly. The hardware used to lock these in place will be MS21042-6 nuts, and what is hard to see is the center of the stud on the horizontal is bored and tapped to take an AN3 or equivalent fastener to essentially "double nut" the assembly.
ID:	48908 Click image for larger version.
    The inner end at the fuselage I expect will attach to the underside of the longerons, not on top as in these images.
ID:	48910 Click image for larger version.
  4. #564
    Mar 2016
    1,430
    I am moving forward with the attachment points for the struts. The outer ends will have four aluminum rivets as well as being bonded to their ends. The ends now utilize Delrin bushings that can be shimmed as needed. I was working with bronze which is odd for me since I have not used any metal bushings since I discovered engineering plastics many decades ago.
    The inner end at this time has a steel mount tack welded to the lower fuselage. I may in time bolt this assembly to the fuse, time will tell.
    If the tabs are welded I will use pin rivets to attach the aluminum struts to the steel tabs.
    It is my intention to zinc plate the aft lower fuselage before painting. This will aid in the longevity of this aluminum to steel joint.
    Back outside again.
    The struts with a few detail shots.
ID:	49074 Click image for larger version.
ID:	49076 Click image for larger version.
ID:	49078 Click image for larger version.
  5. #565
    Mar 2016
    1,430
    A few days ago I got the last tack welds in holding all the ribs and bits in the elevators.
    The outer section forward of the spar will be a composite surface so that comes later in the year.
    Good feeling when to get it outside again with the surfaces hung in place.
ID:	49115 Click image for larger version.
ID:	49117 Click image for larger version.
  6. #566
    Mar 2016
    1,430
    Early yesterday I got the pilots side pedals tack welded from a bunch of sub assemblies made a year or so ago.
ID:	49119 Click image for larger version.
    And now the first trial fitting.
ID:	49121 Click image for larger version.
  7. #567
    Mar 2016
    1,430
    After the trial fitting I found I had to re-position the pedals for frame clearance and inner brake arm room. With all known clearance issues accounted for I assembled the PAX side pedals.
ID:	49123 Click image for larger version.
    With these tacked together it was time to get them in place.
ID:	49125 Click image for larger version.
    I have now flipped the fuselage upside down again so it is easier to build and install all the pedal linkage.
    Likes stknrddr, Hardtailjohn liked this post
  8. #568
    Mar 2016
    1,430
    Oh and one might see in the images of the pedals above, a week ago I installed a divider between the pilot and pax pedals making it very difficult for someone to get their feet over onto the otherside rudder or brake pedals.
ID:	49127 Click image for larger version.
    Someday these might prevent an accident without anyone knowing so.
ID:	49129 Click image for larger version.
  9. #569
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    773
    Sometimes on a solo cross-country I like to spread out into the middle of the seat. Left foot on the pilot's left pedal and right foot on the co-pilot's right pedal.
    It's a nice change in seating position. Not sure if your divider would prevent that or if you'd ever do that, haha.
  10. #570
    Mar 2016
    1,430
    No this will not interfere. I got the pedal linkage built and installed yesterday and am working of the pedal adjustment mechanism soon. One can sit with both feet to one side or straddle with a foot to each side and fly essentially with a side stick. The seat is contoured with the center raised a bit such that a flat set would be more comfortable for center seat flying.
    As I sit here on a calm morning after last evenings storms, I reminisce way back when I flew a C-150, I would take off, loosen the belt and move to the center of the plane. Trimwheel and throttle to finish the climb. Simply lean your head and sometimes ones shoulders to roll in and out of turns. Calm and peaceful.
    Likes CamTom12 liked this post
  11. #571
    10,149
    Quote Originally Posted by CamTom12 View Post
    I do the same or move both feet to other side. If you get bored just move over one pedal with each foot and " try" to do some Dutch rolls, fun stuff
  12. #572
    Mar 2016
    1,430
    I did that with the inner pedals, as in opposite travel. Took awhile but I got it. I wonder how long it would take for that to come back.
    I just connected the pedals to the rudder with a small dia rope, the travel ration is spot on. This is nice since I can keep moving forward and not have to remake parts.
    Mounting all the pulleys for the cable runs will be time consuming but they will be where the drawings depict the routing
  13. #573
    Mar 2016
    1,430
    I made a change at the bottom of the control sticks where the push - pull tube attaches. I now have what appears to be a nice full range of travel on the elevators which complement the rudder movement from the pedals.
    It is looking like the cable runs under the fuselage will be "almost straight" as in 2 to 5° changes at a few spots till they need to truly turn. Kind of frustrating since I am thinking I need to utilize guides rather than pulleys along this route. Thank golly that we have some very low friction plastic bearing material available rather than being stuck with Phenolics as in the past.
  14. #574
    Mar 2016
    1,430
    This post is from work I did a week ago,
    Here I am getting the pedals tack welded from a bunch of sub assemblies made a year or so ago and now ready for the first trial fitting.
    I do have a few changes to make since the outer pedal can contact a frame tube and the inner pedal needs to move a slight amount since there just in not enough room for the brake pedal.
    I will now assemble the PAX side pedals, then narrow the set I have shown here and leave them at that point till all the linkage has been built for a true test fitting.
ID:	49219 Click image for larger version.
ID:	49221 Click image for larger version.
  15. #575
    Mar 2016
    1,430
    And later that same day, And now there are four, far from done but they are there.
ID:	49223 Click image for larger version.
ID:	49225 Click image for larger version.
  16. #576
    Mar 2016
    1,430
    Take some 3/8 x 2" Phenolic bar stock, cut a half dozen squares. Drill and ream a center hole. Mount on a mandrel in the lathe. Turn the square to be round. Then with a round nose bit cut a .140 wide groove. Press a flanged bearing into each side.
    And wala, some medium diameter pulleys.
    Guess I need a few more pictures, I will get them on the second batch.
    These pulleys are for the lower elevator run which does not have much angle as well as the rear rudder cable pulleys.
ID:	49237 Click image for larger version.
ID:	49239 Click image for larger version.
  17. #577
    Mar 2016
    1,430
    I am going to touch on these pulleys again. I went down into the shop early to make a second batch.
    Here are more images showing the steps from the beginning.
    In the band saw, setup with a 1-2-3 block for this 2" material.
    Make the cuts which leaves me a bit short, out of 24" of material one gets 11 full squares and a short drop due to the waste during a cut. Being I scrapped one pulley in the first batch I will now have 10 which is fine.
ID:	49242 Click image for larger version.
ID:	49243 Click image for larger version.
    On the mill, I square the stack against the reamer, center the DRO and change to a drill, then ream the center hole.
ID:	49245 Click image for larger version.
ID:	49246 Click image for larger version.
    These then get mounted on the lathe, 3 at a time. I am using a 1/2 bolt as a mandrel with two nuts spaced apart in the chuck, quick and repeatable.
    Turn the outside then plunge the groove for the cable.
ID:	49248 Click image for larger version.
ID:	49249 Click image for larger version.
    On the work table, the pulleys, a couple of bearings ready to go together.
    Likes skywagon8a, stknrddr liked this post
  18. #578
    RVBottomly's Avatar
    Sep 2017
    787
    Very nice. I'm curious about your bearings source.
  19. #579
    Mar 2016
    1,430
    Various sources from all over the world.
    The bearings used here are FR188-2RS These being a .250 bore, .500 OD sealed bearing. If I recall these are rated about 250ish lbs radial load each. So call it about 500lbs per pulley, that is plenty.
    One can easily go up with the OD and get a greater load rating.
    These also lack an extended inner race so it is not a good thing to clamp down on these. In this application these will ride over a 1/4-.028 SS tube with an AN3 through bolt retaining the assembly. As such the bearings could have a bit of float which is not a bad thing.
  20. #580
    Mar 2016
    1,430
    Lots of little parts ordered so I can make the rest of the control cables. With luck these will all be assembled and get swagged in a few weeks.
    Till then the pulley for the rudder system need to go in as well as a few rub blocks along the cable route.
    I have not done a big phone order with BandB in decades but none of use will be shopping directly with them at any of the shows this year.
    I still want to design a manual trim system just in case I do not actually want the electric trim. Better to have all the mounting for it's cable run in place.
    But finishing the electric trim needs to be done, basically mounting the gear motor at this point.
  21. #581
    Mar 2016
    1,430
    Going through the camera I forgot I had these shots. I use a construction laser allot on what I build. Here are two shots using the laser to paint the line the cable and pulleys need to be aligned to. These shots you can clearly see how the cable run lights up by the laser.
ID:	49308 a Click image for larger version.
  22. #582
    Mar 2016
    1,430
    I got the elevator trim motor mounted yesterday. Waiting on a pair of limit switches to arrive that will need mounting and probably remaking a part or two. Then the system can truly be test run.
    To mount this gear motor I machined a solid coupler to stand in for the flex coupler to provide the best alignment possible. This drive has a square connector while the ball screw has a round shaft utilizing set screws which I expect will be altered with adding a keyway before this goes into service.
ID:	49393 Click image for larger version.
ID:	49395 Click image for larger version.
    This task was closed out with machining and installing a guide block for the top of the jack screw assembly.
    Now I can move forward with finishing the rudder cables since all components along there path are in place.
    Regards, Charlie
    Likes stknrddr, RVBottomly liked this post
  23. #583
    Mar 2016
    1,430
    With the trim motor in place I have the freedom to finalize the path the rudder cables take.
    A few images here starting at the back.
ID:	49430 Click image for larger version.
ID:	49432 Click image for larger version.
    And from the front
ID:	49434 Click image for larger version.
ID:	49436 Click image for larger version.
    Regards, Charlie
  24. #584
    10,099
    What is the purpose of the second cross tube? A place to insert a lifting handle pipe?
  25. #585
    Mar 2016
    1,430
    Correct,
    It is a thin wall stainless tube that is a receiver for a thick wall carbon tube.
    Stainless since it will be open to the environment.
    I kind of want one up higher but then I need to mock up the main gear to get a better feel when moving the plane around. It could be that all will be fine with a towbar on the tailwheel.
    Regards, Charlie
  26. #586
    RVBottomly's Avatar
    Sep 2017
    787
    Correct,
    That's an idea I think I'll steal (or borrow if you prefer)
    I hadn't though of carbon. When I first looked I thought you were using rebar.
  27. #587
    Mar 2016
    1,430
    Ahh but this is new Chinese rebar
    I welded a short 4130 tube to the airframe on each end with the St 304 tube spanning the width. I think this was a 7/8 .035 Stl 304 tube inside 1" either .028 or .035 bits to weld into the frame.
    If I recall the carbon tube is 20mm OD, 2.5mm wall.
    Check if you want the handle up high or down low, this one seems OK for carrying the plane but might be too low to just push it around.
    Without the front end up at it's proper height I can't really tell.
    Regards, Charlie
  28. #588
    Mar 2016
    1,430
    Humm, with the fuselage upside down again a couple of the rudder cable pulleys have been changed out to double groove pulleys. Odd, must be something weird or some sort of trickery going to happen here.
ID:	49473 Click image for larger version.
    Regards, Charlie
  29. #589
    Mar 2016
    1,430
    Sometimes a change is needed, well this might be a bit different than most needed changes. From when I drew then built the aft section of the fuselage it came to be realized a cable path needed to be different than what was designed years ago. Issue is a tube placement was done to allow the cable to pass outboard right next to the longeron. Well, that cable needs to pass more inboard which rendered the tube to be in the way. After days of mulling over it I decided the cable wins and the tube moves.
    So I clamped in a guard so I would not nick another diagonal and went in and cut out one end of a tube to move it over a bit.
    This is the first stage of moving it.
ID:	49533 Click image for larger version.
    Regards, Charlie
  30. #590
    Mar 2016
    1,430
    Dang. Just ordered 105 feet of stringer material. Interesting how much some material can add up to.
    Regards, Charlie
  31. #591
    Mar 2016
    1,430
    And in this cluttered corner of the shop I am starting a proof of concept build of the main landing gear. This is being done in mild steel tube while the flightworthy gear is intended to be a composite spring.
ID:	49746 Click image for larger version.
ID:	49748 Click image for larger version.
    Regards, Charlie
  32. #592
    Mar 2016
    1,430
    It is interesting moving around this plane sitting here mocked up with this gear. The door sill is at the middle of my abdomen. The propeller tips will have well over 20" tip clearance when level.
    Heck if I have to prop this I am not sure I can reach the blade at the 10 o-clock position.
    Yah the AOA looks nice but with the wing I will have and the huge flaps I question if I need this angle. Yah it will make use of the slats but in my mind they are for safety in flight.
    For a younger and more agile person this would be sweet, but needing a step ladder on each side to enter or egress is not appealing to me.
    Decisions-decisions, humm.
    Regards, Charlie
  33. #593
    10,099
    It appears as though your plan is for a one piece bolt on gear. Why not just make two for flight test purposes?
  34. #594
    Mar 2016
    1,430
    This morning I pretty much determined I will shorten the gear legs about 5"
    Where the axles bolt on will have more than one set of mounting holes allowing some option as well as changing tires and wheels.
    If I was 6'2 and had two good legs I would stick with what I was mocking up.
    Yes this will be a one piece leaf spring. I would really like to get it right the first time. The steel tubing is inexpensive and fast to work with, but will in no way withstand actual operations, even short term.
    The composite gear requires a mold, time consuming and expensive. There will be hard points to be machined that get molded in the layup.
    Then the carbon tows, innegra and S glass along with $200 of resin, much of which may go to waste due to short shelf life.
    I really am hoping to do this once.
    Aspects as stiffening or softening the spring rate can be altered, but the torsional stiffness and general dimensions are pretty much locked down once the fabric is in the mold, especially once I resonate it.
    I still consider going with an Olio type gear similar to original. I would utilize modern motorcycle fork legs, I have not done any recent drawings or calculations since I decided to go with a leaf.
    Regards, Charlie
  35. #595
    Mar 2016
    1,430
    I am fitting the stringers, starting up top since most of the mounts under the belly were done previously. I am liking it.
ID:	49795 Click image for larger version.
ID:	49797 Click image for larger version.
    Once the top is pretty much done I will undertake the sides, They will be tricky due to the baggage doors.
    Regards, Charlie
  36. #596
    2,149
    Charlie can you weigh the major components before assembly - wings, empennage, fuselage, FWF? Might be worth the effort. Not sure if covered or uncovered.
  37. #597
    Mar 2016
    1,430
    Sure,
    It has been some time since this has been on the scales and allot has been done. Next time I do I want to weigh the fuselage with stuff in it as well as bare tubes. Both before and after cover too. Some of the add ons be they the pedals which seem heavy in my hand while other parts seem light. It will be interesting where it is at compared to what is in my spreadsheet of weighed and estimated parts.
    The wings are a long way off but since they are metal skinned they will not be apples to apples with Cub parts. Maybe compare to Bearhawk parts. I expect mine will turn up heavier. I tend to not skimp with wing structure.
    The flaps and ailerons which are designed in both composite and metal, One or the other. They might actually end up as composite spars, ribs and trailing edges with fabric cover.
    I still have a desire to build the rudder and elevators in fabric skinned composite structure. Need to get close to the final weights to see what is needed to balance this out before I build superlight tail feathers.
    The engine will have a sheetmetal oil sump, forward facing HA6 carb to start with. Denso Alternator and Skytec starter. The flywheel will be receiving a day on the mill and lathe as well. That did not get done last winter and may not be till next till to become important.
    This will have a 4 into 1 header that should not be bad weight wise.
    Regards, Charlie
  38. #598
    3,027
    Curious why you are choosing metal wings over fabric? I was always told that fabric wings perform better at lower speeds.
  39. #599
    Mar 2016
    1,430
    Yes fabric wings perform well at low speed, because they can not achieve a high speed.
    Low speed and light weight are not my goal here. It might be feasible that a fabric wing could fly slower, but it is also considerably slower at cruise or high speeds as well.
    Everything I have designed and built has a minimum of 5:1 speed ratio. This plane should exceed that by a fair margin.
    The airfoil I have chosen, one of Riblett's optimized has a good chance of a fair amount of natural laminar flow. Being that laminar flow is not necessarily just fore-aft on a wing but actually has a fairly large spanwise component, this leaves out any rib-fabric construction for efficient higher speed operations.
    FWIW, The airfoil I have selected is not what is utilized on the Bearhawk aircraft.
    Oh, my selection of metal wing actually has more to do with what I can build with a lack of skilled helpers. The old brush & bucket layups need more hands than I can get here.
    Learning more about resin infusion is making me think again about composites. I have 3 real good wet vacuum pumps here ranging from 3/4 HP to 5 HP so I can draw down anything. Dry layups are not hurried.
    Regards, Charlie
  40. #600
    Mar 2016
    1,430
    Top stringers revisited,
    Yesterday I got the fiberglass tubes trimmed to fit in place on top of the fuselage. Today I undertook making some saddles these tubes will be supported on. The saddles are used where the stringer rests on existing structure. For these ¾" OD tubes I make these saddles from 7/8-.028 wall tube, split in half, then formed to fit snug to the stringer tube and welded into place.
ID:	49819 Click image for larger version.
    This is one of six saddles fitted today, the rosette weld will need to be dressed down.
    At the very front the stringers were trimmed to mate up to some structure,
ID:	49821 Click image for larger version.
    And then a saddle was formed and welded in for the stringer to fit into.
ID:	49823 Click image for larger version.
    Regards, Charlie
  1. Our Cub Project
    By tcraft128 in forum Member Projects in Progress
    Last Post: 11-25-2019, 01:32 AM
  2. I need a new project
    Last Post: 09-03-2013, 09:10 PM
  3. PA-12 project
