Results 1 to 25 of 25
Thread: New guy and plane (Experimental PA-12).
    May 2020
    10
    Recently purchased an Experimental PA-12. I have not flown the plane yet as it had some things the original builder did that needed to be fixed. I am also taking the time to change some things due to personal preference. Looking forward to flying it. This forum has been great info thus far. Thank you.
    Likes SJ, mike mcs repair, stknrddr, Vlad, Colorguns and 3 others liked this post
    357
    Welcome aboard. Nice looking bird...
    Back In Alaska
    Grant's Avatar
    At Work.....
    1,746
    That's a good looking airplane! Congratulations and welcome aboard!
    Jan 2009
    Twin Cities, MN KANE
    77
    Great bird! Love the PA-12 I have enjoy yours often.
    May 2020
    10
    Thank you all. Plane has an O-360, 3X3 landing gear, catto prop, dual caliper Matco brakes, 10 inch rim on 31 inch tire, 3 inch larger PA-18 tail feathers and is fairly simple inside. It seem fat at 1208 lb empty weight. Has 12.5 lbs ballast on the tail. I will re weight the plane soon just to verify.
    Likes Philly5G, Southern Aero liked this post
    Sep 2004
    Illinois & Wisconsin
    703
    Congratulations. Beautiful a/c. It looks like new.
    May 2020
    10
    50 hours since it was built. It is built with a piper pa-12 fuse and wings the builder had.
    Apr 2015
    Anchorage
    19
    Nice plane! I have a very similar one. I sent you a PM.
    7,080
    One of my students bought a similar aircraft, partially at my recommendation. He is in love with it. His other aircraft is an F-18.
    May 2020
    10
    trying to figure out if this forum re sizes pics or if I have to do it manually. A few more pics attached.
    Sep 2016
    134
    What’s the empty CG?
    Jun 2018
    England
    445
    Wow!!! Looks REALLY nice!! Interior really cool!!! and loving the door
    Every day's a school day
    May 2012
    SE Montana
    214
    Awesome looking bird! Those seats look comfortable! Where are you located?
    May 2020
    10
    Quote Originally Posted by Nodak33 View Post
    The cg has a different datum than the original PA-12. The wing incidence was changed by 2 degrees to match the same angle as a PA-18.
    Converted empty CG (to PA-12 reference) is 11.9 inches at 1,208 lbs. That is with 12.5 lbs of tail ballast. PA-12 range on the book is 9 to 18.6 inches aft of the wing leading edge.
    Hoping to get some weight off the plane. Have a few ideas.
    Likes Nodak33 liked this post
    May 2020
    10
    Quote Originally Posted by Philly5G View Post
    The interior is stiff but should work well. I am in the process of changing the seatbelts. They are 3 inch wide and not comfortable at all. Will post that later for those of you that want to use Crow seatbelts on your experimental aircraft. The front seat is from a cessna 150 and has a track. So the seat can move 4 clicks forward/aft.
    Quote Originally Posted by 1934A View Post
    Thank you. I am located in CA.
    Jun 2006
    Park City
    164
    Nice bird, you know chicks dig PA-12 !!! that's why I sold mine between my good looks and a plane like that..... well its spells trouble!! you've been warned!! Just Saying!
    I spent most of my dough on booze, broads and boats and the rest just wasted ! - Elmore Leonard
    Likes Nodak33, windy, jrussl, MainlandCub liked this post
    Nov 2003
    Thun Field, Washington
    787
    I put 3" belts in my Cub at rebuild. Not only were the 3"ers uncomfortable, they are really heavy, like about 6# heavier than the 2" belts that replaced them.
    Utah 12 Driver, about the "between my good looks..." I have to say "cough-cough".
    Likes FdxLou, Utah 12 Driver liked this post
    May 2020
    10
    Quote Originally Posted by Utah 12 Driver View Post
    Wow... I better be careful. Sound like I have new responsibilities with this new plane. I cannot believe this. This is something that should have been included with the paperwork.
    Quote Originally Posted by Carey Gray View Post
    The seatbelt weight is something my wife did not like right off the bat. Then she put the seatbelts on and they rubbed on her neck. I called Crow Enterprizes and designed new ones. They were also very stiff and made it hard for me to reach the flap handle. The geometry for the shoulder harness is not the best for the front seat but short of welding a new cross tube, the only other thing I can do will put the shoulder harness in my wife's face.
    Name:  IMG_2077 small.jpg
    Pic of seatbealts currently being installed.
    Sep 2016
    134
    Sweet Bird 🦅!
    Sep 2004
    703
    Other than it’s handsome appearance, what drew you to buy this particular experimental PA12? Why did the builder sell such a beauty?
    10,195
    Quote Originally Posted by AX-O View Post
    That location for attaching the shoulder harness ought to be moved. When it is attached as it is, if an accident should happen that tube will buckle towards the passenger. Then if/when there is a rebound of the passenger the kink in the tube could impact her neck/back of head with disastrous results. The shoulder harness ought to be connected to a cluster of tubing or a specially welded fixture. You could use a substantial cable to extend the length of the harness to a proper attachment location. There are many safer options available.
    May 2020
    10
    I wanted an Experimental cub type aircraft. That would allow me to do the majority of the maintenance work. This one was available at the time I was looking to purchase. I am not sure the reasoning for the seller.
    Sir,
    thank you for the post. I am new to these types of planes. Will research this more. Would you have a picture showing examples of mounting locations? Or a place where I can see an example for the PA-12 with the big cross tube?
    10,195
    Thanks AX-O thanked for this post
    WhiskeyMike's Avatar
    West Boxford MA
    929
    I installed harnesses in my -12 by wrapping plastic insulated 1/8 cable around the rear spar attach cluster, and used the left side over the right shoulder and visa-versa. I'm always annoyed when the harness catches around the back of your neck. The Y harnesses never seem to be comfortable for me, especially if the Y portion is too close to your back. This fixed it up nicely, and should comply with regs - and since you have a simple interior, should be an easy install. The rear harness could be attached by a cable to rear clusters, at a length to suit. You might also check CAR 8 about harnesses. The old Restricted category guys knew a lot about crash worthiness and how to properly install.
    May 2020
    10
    Quote Originally Posted by WhiskeyMike View Post
    sir, do you have any pics?
    I flew it 3.0 today. Did over 20 landing in every imaginable config. OAT was approx 110 with DA at 6,000ish.
  1. WTB: Experimental Cub- tow plane
    By jokerswe2008 in forum Projects
    Last Post: 06-02-2019, 01:30 PM
  2. Replies: 38
    Last Post: 02-19-2015, 09:37 AM
  3. J-5 to pa-12 experimental???
    By Harbi in forum Experimental Cubs
    Last Post: 04-29-2006, 11:33 PM
  4. experimental: SuperBear? experimental cub information wanted
    By RYAN_WINGS in forum Experimental Cubs
    Last Post: 05-09-2004, 03:12 AM
