Page 12 of 12 FirstFirst ... 2101112
Results 441 to 473 of 473
Thread: Introducing a J-4 project
  1. #441
    Cub junkie's Avatar
    My Moms basement
    2,069
    I've used automotive freeze plugs the appropriate size welded on one end, pack the sand by tapping the piece of tubing then drive the other plug in and squirt it in place with the mig. Thought I'd try the welding rod method sometime since I have a lot of extra rod that is too corroded to weld with.
  2. #442
    Mar 2016
    1,116
    It works but I would say with smaller tube use small wire, like .045 or .035. although it may be tough getting the last few pieces slid in.
    I have heard of oiling the wire but have just used it dry myself. I do not like the idea of finding oil running down to a weld when the tube warms up.
    After the bend it will take Vice grips to pull the first wires out.
  3. #443
    Mar 2016
    1,116
    I settled into how some of the support for the vertical fin is being done. I want a high torsional stiffness and determine a Vee shape front spar will allow lighter structure elsewhere. So, I drew what I wanted and printed it, cut two lengths of 5/8 .028 tube. Cut an 11" long miter up top and curved the lower foot where the airfoil allows.
ID:	46860 Click image for larger version.
    With the tube ends dressed it is set in place.
ID:	46862 Click image for larger version.
    Likes RVBottomly liked this post
  4. #444
    Mar 2016
    1,116
    A little more, I also had gotten the upper hinge on the rudder made yesterday.
ID:	46864 Click image for larger version.
    And the lower hinge with rudder arms tack welded.
ID:	46866 Click image for larger version.
    And the bottom of the front spar tacked in place.
    Likes RVBottomly, CamTom12, tempdoug liked this post
  5. #445
    RVBottomly's Avatar
    Sep 2017
    632
    Beautiful work, Charley.
    Thanks CharlieN thanked for this post
  6. #446
    Mar 2016
    1,116
    After plowing I finished up the mid rudder bearing mount. This like many other machined parts is made from 304 alloy so it will not rust the ball bearing into place as years go by. Next will be to make the pivot pin with it's mount to go one the Vfin spar.
    The rudder was originally going to be a single 7/8 tube but after seeing the prices for streamline brace wire I redesigned the full tail and went with the wider structure that has no need to be braced. This picture shows where I reworked the top of the control horn which originally had an angle cut to weld in the spar tube but then I changed the bottom mount to house an upper bearing. There are a total of 4 ball bearings locating the rudder. One of the many running changes that required rework.
  7. #447
    Mar 2016
    1,116
    The center rudder hinge is now tacked in place. The images here are with a jigging bolt in place rather than the pin the bearing will ride on when done. I like it, you just breath on the rudder spar and it turns to it's stop. This will be nice.
ID:	46903 Click image for larger version.
ID:	46904 Click image for larger version.
    And a better shot looking up under the top hinge.
    Likes CamTom12, tempdoug liked this post
  8. #448
    Mar 2016
    1,116
    One other thing I think I might do soon, I kind of want to get a feel for how this sits on the main gear. not to mention if the caster angle on the tail wheel is correct. In time I will more than likely be making a composite spring gear for the mains. Right now I have been jumping on the rear of the fuselage as well as picking t up and dropping it. Damn is that Fox Shock impressive.
    But up front I may make up a non usable gear from mild steel tube that I have left over from customer jobs. I can machine a few bits to mount it and bend up a yard usable gear. Yesterday this kind of started to be more feasible since I remember I have a pair of suitable size wheels and tires that are leftovers from a restoration I did decades back.
ID:	46910 Click image for larger version.
    Should look the part well enough.
  9. #449
    Mar 2016
    1,116
    Today's task has been to get the bushings for the horizontal rear spar into the fuselage. I machined a pair of bushings, finish welded some brackets on the fuselage which required rolling the fuse over, got some first paint in the area. Not permanent paint but with the bushings being pressed in, they might not come out again such that I wanted the inside of the tube coated.
ID:	46919 Click image for larger version.
ID:	46920 Click image for larger version.
    I needed to finish ream the bushings since the welded tube was surely not going to be round inside. This was planed for by leaving the ID 5 thou snug.
    Now the spar can be inserted for the first time. I did have to put the spar back in the lathe to dress the center a bit but it now is a nice snug fit.
ID:	46922 Click image for larger version.
    This spar tube is 6' long, It now will get the mid elevator hinge brackets and the brace strut mounts get made for under the fuselage and outer ends of this spar. The Spar also will get inner stops welded in place so it remains centered. The outer hinges will be further outboard on secondary structure.
    Last edited by CharlieN; 02-08-2020 at 06:49 PM. Reason: No the spar is not 8' long, the full horizontal is 8'
  10. #450
    Mar 2016
    1,116
    This morning I started with verifying that the horizontal spar was square and level. We almost, measuring the diagonals from the spar ends to a fuselage centerline about 7' forward gave me about a 3/8 difference.
    Remedy was insert a heavy wall steel tube into the mount bushings, slide a 4' length of tube over that tube and start pulling, just two tries and with a Stanley tape the tube is square to the airframe. Best I can measure level too.
    Next was to make the centering collars for the spar, for these I bought a short length of stainless heavy wall pipe that I machined the collars out of.
    First collar, this one takes the bolt that holds the two sides together through it as well as being tacked in place.
    The other side is captured inside the reinforcement and is removable should I need to fiddle with dimensions.
    And with each side slid in and the retaining bolt in place.
ID:	46933 Click image for larger version.
    Humm, my camera just climbed past 30,000 images so for the third time the image count is at 0001. Still going though. Glad I am not paying for film or slide processing as we used too, but I used to just run up 3 to 5,000 images per camera back then.
    Likes Riverking liked this post
  11. #451
    Mar 2016
    1,116
    Next will be to build the front spars for the horizontal, this morning I printed the horizontal drawing in full size and will start building the tooling to work on.
    And yes that is a 99" wide print.
    Lets see if this one stays,
    Likes mike mcs repair, Southern Aero liked this post
  12. #452
    10,646
    Attachment 46935
    bad attachment
  13. #453
    nd
    3,390
    would a lube fitting be a good idea?
  14. #454
    Mar 2016
    1,116
    Should not be needed as long as the paint on the inside of the tube remains good.
    The stainless spars ride in HPDE bushings. They together do not need lubrication. If lower friction were important I would use Delrin for the bearing but it needs to be machined with a thou or two of clearance. The polyethylene is springier as such I make the bushings a light interference fit which will reduce moisture migration. This does not mean I wont grease pack this since if moisture does get in, it will probably not get back out.
    That will be determined on final assembly.
    I just opened the post with the bad image and the pic appeared. Not sure if it will remain that way, I might have pulled the image directly from the camera which I am finding breaks some form of link that seems to be between my computer and this forum.
  15. #455
    Mar 2016
    1,116
    It is good to see our young one studying.
    Likes RVBottomly, windy, mike mcs repair liked this post
  16. #456
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,881
    Uh oh, it's going to become another pussy thread....
  17. #457
    Mar 2016
    1,116
    Today I bored the ID of the trim actuator to accept some Delrin tube, Installed the tube and bored it to fit the front spar.
    This shot is boring the Delrin,
    The spar it turns out will be stepped down in diameter and wall thickness. The innermost section needed to be bored to fit over the middle 1" x .035 section.
    With the inner and middle tubes pressed together and slid into the center trim section.
    Likes CamTom12, Riverking, RVBottomly liked this post
  18. #458
    Mar 2016
    1,116
    A few new pieces, these are the mid span elevator bearing mounts. Made in 304 alloy so they will be maintenance free.
    I started with boring the holes the ball bearings will press into, then I made a fixture to mount them centered on my small rotary table to shape the outside.
ID:	46994 Click image for larger version.
    Followed with dressing the edges on the flapwheel.
ID:	46995 Click image for larger version.
    Working the camera and dressing edges , did not get the shot I wanted. Oh well.
    But the parts came out fine.
    These will be slid onto the rear spar and later welded in place.
  19. #459
    Mar 2016
    1,116
    I have pressed the hing bits onto the rear spar,
ID:	47000 Click image for larger version.
    The center of the rear spar,
    The center of the front spar.
    The front spar almost ready to bend into shape.
  20. #460
    Mar 2016
    1,116
    A piece of tubing I have been waiting on arrived this morning as such I now have the front spar for the horizontal ready to start forming the sweep into it so I can do the rough building of the structure. The first step once I had it in hand was to ream the ID of the stainless tube since it turns out it was not spot on concentric. Once the carbon tube had a nice snug fit I was able to drill for the retaining through bolts.
    I have allot of cleanup to do on these parts but I have a few years to get that done still, But here are the major trim components.
ID:	47016 Click image for larger version.
  21. #461
    Mar 2016
    1,116
    Another task I had gotten too was some more drawing on engine parts, this being the intake manifold and exhaust system.
    Two renders here.
Name:	2 15 Exhaust.jpg
ID:	47021 Click image for larger version.
Name:	2 15 underside.jpg
  22. #462
    Mar 2016
    1,116
    First pull on the front spar tube, I am liking it.
    I will go back down and do a second pull to get the angle just right.
ID:	47045 Click image for larger version.
ID:	47046 Click image for larger version.
  23. #463
    Mar 2016
    1,116
    Just added a bit more bend to this tube, it is spot on.
    Neat thing is when I set it on my iron work bench there is no rock to it as in both sides are clocked the same. That is not always the case.
ID:	47048 Click image for larger version.
ID:	47049 Click image for larger version.
    Now it is time to make the tooling to build the framework for the horizontal.
    Likes RVBottomly, CamTom12 liked this post
  24. #464
    Mar 2016
    1,116
    Back again, Here is the trim assembly, assembled and it works, well so far.
ID:	47051 Click image for larger version.
  25. #465
    3,455
    What did you use for a gear motor?
  26. #466
    Mar 2016
    1,116
    At this time it is a power window motor made by Denso. This one is spec'ed for a rear window from an 07 Honda fit. If not real aware these use a worm gear drive so they will not back drive.
    The jacksrew is a 16mm ball screw. Probably a bit heavy but absolutely free of play. part of me thinks a 12mm would be fine. Need to see where the plane comes out balance wise.
    My design will also allow the installation of a pulley or a sprocket in place of the motor should I prefer a more conventional system.
  27. #467
    3,455
    Thanks - I saw that it's a worm drive. We were considering similar, or perhaps a linear actuator on our EAB -12 project. Do you have any reliable info regarding the up/down forces at the stabilizer leading edge? Thinking in terms of required torque on the screw, or axial rating on a linear actuator
  28. #468
    Mar 2016
    1,116
    As for loads, no. The force of moving the trim especially with the low friction of a ball screw is fairly low.
    The maneuvering loads at the front spar are in the low, hundreds. The rear spar is considerably higher, but still just higher hundreds, not thousands.
    I have not truly calculated them on this plane since I believe each time I had in the past I had a pretty low accuracy. On this plane, the airfoil has a pretty low pitching moment, but then there are the flaps. I have run some numbers but my confidence factor is low. I am building with a mild airfoil on this tail, it would not surprise me if I need more lift at low speeds. Easy enough to do but the plane will be down for some rework time.
    So far I have only truly had to rework one tail and that was on a very highly modified KR2 I did a full redesign on. We were very early users of the NLF-215 airfoil. I built large span flaps with drooping ailerons center hinged the way the airfoil designer wanted them. Plane was powered with a big VW, a 2350 is I recall. It ran 175+mph WOT,
    155 cruise and 30 over the fence. About as good as could be asked for. But when you first slowed it down it ran out of elevator so back home it came. Once the bottom of the stab was reworked the plane was a dream. The engine was frighteningly unreliable, breaking cranks, cracking cases. If you bliped the throttle it would split a prop blade. No clue what power it made but it was generous. Just did not like turning the low revs a prop needed.
    A linear actuator would work fine, nice thing is build time is low since they are self packaged.
  29. #469
    Mar 2016
    1,116
    I started the day with making sure the middle elevator hing mounts were spot on. When happy with them I did the first weld and later pressed a bearing in place.
    This afternoon I tackled the first rudder rib. This one is interesting as I want it strong but still under control weight wise. Being the lowest rib at the widest spot on the spar it is quite a triangular structure. The very aft of the fuselage here is 3.5 wide with the rudder spar a bit narrower to take into account the taper in width.
    To go after this I chose to make this rib assembly out of box tubing. Not just any box or in this case rectangle tube since this is 3/8 X 1/2 - .012 wall material. I bought this back in the '80s and can not find a source for it anywhere.
    Normally I do not even try to weld material this thin in the late afternoon, at least without a shot of Bourbon in me to smooth the nerves.
    But here is my first rub, roughed out and just held to the spar with a rubber band. The sides of this have a gentle concave curve to the tubes.
ID:	47068 Click image for larger version.
ID:	47069 Click image for larger version.
  30. #470
    RVBottomly's Avatar
    Sep 2017
    632
    Charlie, you've been on a tear. I appreciate all the photos because they inspire and give ideas.
    I particularly like the elevator hinge arrangement. I was waiting to see how that would work out.
  31. #471
    Mar 2016
    1,116
    I am hoping to get the main structure of the horizontal built the the next day or so. At this point it is kind of down to making a simple jig to hold 3 spars, the third being the elevator. The jig is simply a length of 2X8 with accurately cut grooves in it. I was going to cut the grooves on the mill, but once I placed the rotary table back on it that will be there a short while. So if I get to it, between the chop saw and hand held saws I will make a tool. The spars get clamped into it and I build the structure that will become the horizontal.
    I will then assemble the elevator spar with it's hinges which only the middle will mate up at this time. The outer hinge on the horizontal will be built into the composite skin structure that will not be addressed till warm season.
  32. #472
    Mar 2016
    1,116
    As a follow up yesterday I had printed a fresh full size image of the horizontal this time with a depiction of the elevator spar which you can see is not straight. Reasoning being this allows a continuous tube the starts concentric on bearings withe the outer bearings ahead of the spar while still inline with the control horn.
    One interesting advantage with this system is when rigging after ground travel or maintenance, the control surface has pins that just insert into bearings, then a threaded retaining bolt is installed. Reset cable tension and you are done.
    Here at the bottom of the rudder, the two bearings are in double shear, the lower bearing on a pin, the upper under a bolt on shear plate with an aluminum axle slid through from the top. Through the center of this is an An3-32 bolt threaded in that can ether be cottered or utilize an MS21042 nut underneath so as to double nut the assembly.
  33. #473
    Mar 2016
    1,116
    Two years ago I routed out this 1" MDF tool on a CNC router. Really sweet tool other than my current plan has all the surfaces 3" larger than this was made too. Not to mention the spars have changed. Might find a way to use it but I tend to think it is just some really sweet scrap.
  1. Our Cub Project
    By tcraft128 in forum Member Projects in Progress
    Last Post: 11-25-2019, 01:32 AM
  2. I need a new project
    Last Post: 09-03-2013, 09:10 PM
  3. PA-12 project
