Results 1 to 16 of 16
Thread: Metal cub bow.
    Apr 2016
    Anchorage, AK
    13
    Metal cub bow.
    Has anyone worked with a metal bow on cub wing? It would appear the J4 I'm flying has a metal bow? Seems rare.
    10,345
    seen it... bad idea... wood bow is a "consumable" part..... metal one might allow same boo boo to bend? spar...
    9,795
    Never saw one on a J4 or J4A. Is yours J4E?
    Apr 2016
    Anchorage, AK
    13
    39 J4A. Definitely some different stuff on wing going on. Looks like the metal bow is just attached to spar and no other braces. Might eventually replace if I can find a bow.
    9,057
    Quote Originally Posted by califlyboi View Post
    Stoddards
    Apr 2016
    Anchorage, AK
    13
    I saw they have a selection, I've read that J4 wing may be different? I can't imagine it could be that different (hell, it's a piece of galvanized pipe in there now...)
    6,739
    Conduit. Replace it with ash - see Mike's post. Some folks think that metal is better - it is if you drill holes in the ash and allow water to get in there. We are always banging wingtips on hangar doors - ash just shrugs.
    9,290
    At some point in time someone has replaced the original wing bow with a non-aircraft part. Wood is more durable than metal in this application and should not be difficult to make if you can't find a replacement part.
    Speedo's Avatar
    Jul 2002
    AK
    1,718
    Clyde Smith is a source for wooden wingtip bows. He does really nice work. I seem to have misplaced his contact info, but surely someone on the site has it.
    On a different note, the emerald ash borer is wiping out all the ash trees in America. I'm sure there is still plenty of milled ash available for making wingtip bows, but eventually it's going to be hard to source.
    Speedo
    1,664
    If I remember correctly (I could be wrong) Cub Crafters had an STC metal bow for the wing. I have seen them made out of conduit.
    18,660
    Univair sells the tip bows. They are made by the Amish. Problem is they get shipped via a round tube and they straighten out. I use to put them in a jig to reshape but ended up buying the bows from the Amish as well. You have to buy 50-100. They are a pain to package in their correct shaped and expensive.
    9,290
    It seems to me that it would be relatively simple to make a tip bow by laminating a half a dozen strips of 1/8" +/- wood over a simple form. Anyone can mix glue and clamp or tie the strips together. Then just shape with a plane, belt sander, jack knife, whatever.
    18,660
    Depends on what your time is worth. $30 a bow I think.
    9,290
    $34.72 from Univair plus shipping. 6 plus inches wide strips of 1/8" glued together to shape in the same amount of time as 1" strips. Cut off on table saw one bow at a time. Presto $210 worth of bows. These could be made rather cheaply even when you consider the cost of your time. I do understand your point Steve. What is the total cost of shipping?
    12Geezer2's Avatar
    Jan 2006
    Eau Claire, WI
    1,065
    This is what my former A&I (Mr. John Hatz of Hatz bi-plane fame) said should be done. He recommended fir strips over a plywood form with old inner tube strips to hold in place. Works great--strong and will not warp with age as Ash tips do. John was a talented, highly respected rag wing man. Really does not take a lot of time and I believe is well worth it. However MY time is not real valuable Yes, I HAVE seen many older ash tips with UGLY warpage.
    18,660
    After Piper started using 4 channel braces between the front and rear spars and the tip bow I have not seen much warpage other than the flat spots between all the support points in very old nitrate/butyrate dope covered wings. Have seen some very nice laminated tip bows. Too easy for me to grab one out of the rack, varnish and install.
  1. Metal pa-18?
    By Samsam in forum Cafe Supercub
    Last Post: 01-18-2008, 05:01 PM
  2. metal gas can
    By freestone in forum Cafe Supercub
    Last Post: 12-17-2006, 11:57 PM
  3. Metal Belly
    By Aviator in forum Modifications
    Last Post: 08-07-2003, 03:27 PM
