Results 1 to 28 of 28
Thread: Trim handle
    Hyway's Avatar
    Aug 2015
    Sydney Australia
    12
    Trim handle
    Hi Guys taxied out yesterday and in the run up bay the trim handle came off in my hand, taxied back in and looked on the floor for the parts, it consisted of a spring a cover plate and a very small pin. Found them all and reassembled after 10 minutes took off all went well.
    my question is the pin took me 3 goes to get it in, it went straight through the holes in the handle, what holds the pin in place? Is it the cover plate and spring? I would of thought it would of been some kind of fastener instead of a pin same size from top to bottom.
    it was a 1956 Piper SuperCub
    Mat
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,560
    Matt
    That pin is supposed to be a "roll pin". It should have a slit in it and be slightly beveled on the ends. It is compressed as you tap it in and held in place by friction.
    Here is a picture.....
    Hope this helps
    Thanks ...... Pete, I sit corrected. It was NOT originally a roll pin but perhaps that would be an option.
    Very Blessed. "It's not an obsession, it's a passion"
    11,980
    The original is a straight pin which is held in place by the cover plate being held out against the handle by the spring. The cover plate covers both ends of the hole thus holding the pin in place.
    21,783
    The escutcheon and spring keep the pin from coming out. Check your handle to see if the hole is wallowed out. I found an improved escutcheon that has the spring made into it and a nylon bushing for better wear. http://www.snydersantiqueauto.com/wi...-spring-loaded
    Darrel Starr's Avatar
    Plymouth, MN
    2,524
    I never liked that design. A spring & escutcheon plate to hold a pin in? Come on ... and on top of that they eat up the square aluminum plate that has the trim lettering on it.
    Solution: Throw the spring & escutcheon plate in the dumpster. replace them with a tube spacer over the shaft then reinstall the handle with a #4 bolt & nut. Has worked for me the last 400 hrs.
    And if you get deeper into it, install F520-15 Oilite bearings between the shaft and the two thin fuselage tabs as shown in the drawing.
Name:	P6190001 cropped.jpg
ID:	23959   Click image for larger version.
    3,990
    Just bend the pin a little bit, that way it's spring loaded in the hole and won't vibrate out.
    Hyway's Avatar
    Aug 2015
    Sydney Australia
    12
    Thanks guys for all your replies.
    I was also surprised at the simplistic design but not that fool proof, I think I will remove the pin and get it replaced with something that won't vibrate out or fall out if you push the cover plate in too far.
    once again thanks for the info
    Mat
    mike mcs repair's Avatar
    11,773
    original design has(and still) worked fine for many decades...
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    379
    G'day Darrel. Looks over engineered which is right up my alley. The Oilite bearing is the one coloured red?
    What process did you use on the walls? Fabric glued onto what sized aluminium wall?
    The photo doesn't show the number 4 bolt. But wouldn't a roll pin look better?
    Regards, Denis.
    Thanks MoJo thanked for this post
    11,980
    It is always nice to develop a better mouse trap. I understand that desire. I do it myself. Remember that when Piper designed these planes all of the automobiles had crank up windows. Remember those? It was very easy for Piper to send the stock boy to the local auto dealer to buy a box of window cranks, which is what was done. These planes were designed using the KISS principle. If you don't want the paint scratched just glue on a thin piece of anti chaffing materiel between the escutcheon and the plate.
    11,161
    Been working fine in every Model A Ford since 1928
    21,783
    The escutcheon I linked works great. Has enough pressure that it takes some doing to push it out of the way to get the pin in and out. It also does not rotate when you turn the crank since it has a has pressure and a nylon bushing to rotate on. Dakota Cub sales a sure shaft handle with a screw retaining the handle.
    nd
    3,782
    Quote Originally Posted by Darrel Starr View Post
    Darrel, i think this is a excellant fix, even before, after the brackets holes start getting sloppy.
    Thanks yellowbird69 thanked for this post
    Plymouth, MN
    2,524
    Texmex, the Oilite bearings are green in the picture located in the yellow brackets welded to the fuselage. Yes the fabric is glued to the side panels. The fabric is from Oregon Aero and matches the seats. The #4 bolt has an Allen head and is shown in the photo showing the fabric. The bearings allow the crank to turn much more smoothly than the original design of a steel pin turning in thin steel brackets which is never a good idea.
    Jun 2018
    England
    545
    Great design and thanks for sharing it Darrel I'm ordering the Oilite flanged bearings now and doing the mod as well Question; did you have to make up a new crank handle axle, as the additional thickness of the bearing flange would have presumably moved the position of the pulley locking pin hole to a point where it couldn't be used, or did you drill a new locking pin hole in the original axle, or deepen the groove in the pulley to pick up the original hole?
    And on the Oilite bearings, did you:
    Machine the Oilite bearings length down to match the metal mountings' thickness
    Put spacers on the outside of the metal mountings to the Oilite flange
    Just leave the length and let them ride on the pulley?
    Cheers and thanks
    Philly
    Stew's Avatar
    Jul 2013
    Haywards Heath, UK
    130
    The original Piper crank pin was just a modified 3/8" clevis pin (AN396-41 Length:1-9/32").
    Darrel has used a longer one (AN396-59 Length: 1-19/32") to accomodate the Oilite bearings and drilled a new pulley pin hole at the right spot and also allow the fixing of the crank handle with the #4 nut and bolt as opposed to the pin/spring/escutcheon arrangement.
Name:	41161_Pin-Stabilizer Adjustment Crank.jpg
    Aug 2012
    Exeter N.H.---Spruce Creek Fly-in(7FL6) Daytona Beach FLorida
    271
    Darrell---where do I buy this F520-15 iolite bearings??? Thanks---John
    "You cannot teach experience, you must acquire it."
    Captain Cub
    nd
    3,782
    3,990
    McMaster Carr?
    Thanks bobnall thanked for this post
    Stew's Avatar
    Jul 2013
    Haywards Heath, UK
    130
    When you use the Oilite bearings for this do you use locktite to stop them spinning in the bracket or does it not matter?
    4,677
    This one has the nylon
    https://www.mikes-afordable.com/product/A48139RE.html
    https://www.snydersantiqueauto.com/P...-spring-loaded
    If you want to pay more through amazon. The last ones i ordered showed up in grand general packaging
    https://www.amazon.com/GG-Grand-Gene.../dp/B085GHJ6KL
    Handle pn a702780A
    https://www.modelaparts.com/a702780a
    Likes jrussl liked this post
    21,783
    Yea, Snyder quit including the nylon bushing which makes it slide real nice.
    Oct 2006
    Seldovia, Alaska
    236
    I always carried a small needle nose vise grip pliers clipped under the seat in case the trim handle or fuel valve handle ever fell off. A million uses and used them often but never lost a trim handle or a fuel valve handle.
    Likes BC12D-4-85, hotrod180 liked this post
    2,762
    I have had fuel valve fall off on two different planes. Always keep Leatherman in reach.
    3,990
    Good point for annual insp - fuel valve screws tight! Thanks for the reminder - - -
    Likes DENNY liked this post
    Oct 2006
    Seldovia, Alaska
    236
    just a dab of thread locker does wonders. I always get the blue stuff. I don’t know about the other colors but the blue I can get off when I want to yet I’ve never had a tread come loose with it on
    PerryB's Avatar
    Aug 2007
    Chico, CA
    2,030
    Quote Originally Posted by reliableflyer View Post
    Blue is the softest of the Lock-Tites and a good choice for small machine screws. Red is next and green is for all of time. Red on a smaller screw usually requires heat to remove without breaking the screw unless you apply heat. On a fuel valve that might be questionable.....
    4,442
    Blue is actually considered a 'medium' hold. There are others such as purple that are less tenacious.
    Likes akavidflyer liked this post
  1. Trim Handle Removal
    By GeeBee in forum Tips and Tricks
    Last Post: 04-02-2014, 05:07 PM
  2. remove trim handle
    By nesincg in forum Super Cub Repair Facilities
    Last Post: 11-22-2011, 01:26 PM
  3. trim crank handle
    By spinner2 in forum Products, Purchases, Reviews & Prices
    Last Post: 04-16-2010, 04:11 PM
