Page 2 of 12 FirstFirst 1234 ... LastLast
Results 41 to 80 of 473
Thread: Wildcat Cub
  1. #41
    5,129
    What it looks like today.
Name:	cowl front.jpg
ID:	28140   Click image for larger version.
  2. #42
    5,129
    Progress. It was a good day. The cowl is coming together plus a supercub.org member traveled a long way to visit and take a look. I hope it helps him with his exciting new Cub project.
ID:	28189Click image for larger version.
  3. #43
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    979
    Stewartb, glad to see it coming together,looks great. I'll be back home in Feb.- Mar. and would love to stop by and see it.
    I just watched the Mustang video and here is the end of the season work, kinda like moose hunting when the shooting is done,lol.Click image for larger version.
ID:	28192 We pulled the engine for a rebuild , now waiting for it to come back is the pain. I love working on the old war birds, but flying them is better.
  4. #44
    9,268
    How much tail ballast on the wildcat for this engine?
    Some sweet work on that SB, Looking great!
  5. #45
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    979
    Bet you could get away with maybe 8-900 lbs. but the climb rate would make others notice,lol.
  6. #46
    5,129
    Memo from Mike. Written after to remind me of what we talked about before. Or maybe it was there but that side was facing the floor. Either way... Oops!
  7. #47
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,404
    Doh!
  8. #48
    5,129
    Baffles are mostly finished. Add a couple of blast tubes for the Pmags and fuel pump isolation box and the engine compartment is complete enough to step away. Time to tackle the G3X installation.
ID:	28658   Click image for larger version.
ID:	28659   Click image for larger version.
  9. #49
    tedwaltman1's Avatar
    Jul 2011
    Denver, CO
    425
    Looks very nice Stewart. At the suggestion of a friend, I actually raised the front of mine to be even with the cylinder mid-point. To my surprise, just that seemingly minor change dropped my CHT's significantly.
  10. #50
    1,967
    I put ramps on my cub. Started with metal tape and adjusted that over two years. When I had it right I made metal ramps I lowered them a bit taped them in place to make sure things worked as planed. Taping front gave me excellent control of CHT adding ramps improved it 10 more degrees with 234 all within 5 degrees of each other other in cruse #1runs 10 degrees cooler than the rest.. One side is higher than the other. I would not try this without CHT probes on all cylinders. A small amount of tape or ramp can make quite a bit of difference in temps. You could build adjustable ramps pretty easy I think it is one of the best things you can do for the motor
  11. #51
    5,129
    The IO-400 is supposed to have cool CHTs and warm oil temps with the big angle valve heads for cooling and piston oil squirters and cold air induction warming the oil. I'll deal with the CHTs by adjusting baffles and balancing the injectors. I think we have as good a handle on oil cooling as we can have. The baffles could take up several pages on my website. Maybe I should do a photo file for all build pics on Google Pics. When I get time.
    Likes pfm liked this post
  12. #52
    Meanwhile,...
    5,203
    Stuart, That looks like a solid engine choice but out of curiosity how does "cold air induction" warm the oil? Is it a way of taking even more cylinder heat and transferring it to the oil for dissipation?
    As for baffle openings, from mass and heat transfer once upon a long time ago I seem to remember that increasing the velocity (which raising the baffle ramp heights would effectively do) over a cooling fin increases its cooling coefficient compared to large area low velocity air once a certain velocity is reached. Unfortunately, I'm pretty sure I was hung-over for the discussion of actually determining what that velocity is and I never took a class which studied high velocity inletss only sub-critical velocity inlets.
    I like the blast tubes for critical areas but it would seem that having both critical tubes and the mid-cylinder ramp height (like the beautiful one suggested) could be benificial... This is challenging to me because I anticipate that you will have such a wide variation of intake conditions straight and level but not real fast, high AOA and finally to the ridiculously high AOA at very slow speeds that I could see the nose bowl possibly achieving the same effect at the high AOA conditions but you could also loose a great deal of inlet efficiency if the flow is greatly disturbed in that condition if sustained for long periods.
    Overall a baffling question that I remember discussing with Wayne when I was his back seat test dummy for a few days in the early testing of the SQ-2. We discussed summer temps but that wasn't a concern those days the tears I shed from laughing at the incredible performance froze to my cheeks but I do recall he was planning a bunch of hot temp. testing and if he planned it, it happened.
    Beautiful work on your project and a well offered a observation, my only suggestion is to keep all the arrows offered in your quiver as you move forward.
    I look forward to seeing more.
    Kirby
  13. #53
    5,129
    Cold air induction doesn't run the induction tubes through the sump. Apparently those tubes contribute to oil cooling by transferring oil heat to intake air. But adding heat to intake air robs power.
    Pressure cowls are an interesting thing. Velocity isn't everything. Sometimes it's better to slow down the air to allow heat to transfer better. Thus the attention to pressure differential. That's why I'll have butterfly valves in the outlets of my oil coolers. Playing with those will be telling. I've had to build air dams for the Cessna to help equalize temps between front and rear cylinders. I always figured I was moving some cooling from front to rear but never considered the overall cooling would be increased. The ramp thing is something I'll use if necessary. I hope the total cooling will be adequate and may only need to balance temps. More SQ guys struggle with CHTs than oil temps but typically they use hot-rodded parallel valve engines and streamlined composite cowls. My engine brings cooler CHTs and hotter oil temps. BCSC has struggled a bit with oil cooling in planes they've built with the IO-400. Dan @ HO warned me that one oil cooler wouldn't be adequate with this engine. I haven't seen anyone do what Mike and I have done with dual front coolers but I believe we have the best oil cooling potential I've seen to date. Part of the allure of the Cub cowl is to provide a known entity for cylinder cooling. The dual front oil coolers was designed on the fly. Come April we'll know whether we're on the right path or not.
  14. #54
    5,129
    Here's a side view of HO's IO-390 STC installation. This is similar to BackCountry's IO-400 oil cooler installation that I've seen photos of. Holy blast tubes, Batman! My 1" blast tubes will cool the Pmags and feed the fuel pump insulator box and the sum of three won't come close to what this picture shows going to the oil cooler. And HO has a second cooler in there, presumably on the baffle on the other side. If they can steal that much air for oil cooling and still manage CHTs I should be way good.
  15. #55
    Meanwhile,...
    5,203
    I missed that you did dual front oil coolers, mine had that set up when I purchased it. There was the standard stock (boat anchor) cub cooler and then anouther one (stern anchor) mounted in the front horizontal baffle. They worked way too good for a 150 hp O-320 not pulling a load. It was added early on in 604'S life by the first owner who sprayed alfalfa with it ocassionally in Nebraska. Was all piper parts and installation drawing, I replaced it with a single Niagra to run great temps and drop 12 pounds.
  16. #56
    5,129
    For guys interested in the numbers the two Niagara 20003A coolers weigh 2.4# each.
    Thanks Beaverpilot thanked for this post
  17. #57
    10,901
    Plus oil....
  18. #58
    Meanwhile,...
    5,203
    That will provide some serious cooling capacity, will you have cockpit control over them?
  19. #59
    5,129
    The idea is to put air control into the outlet ducts. One of a zillion details yet to be addressed.
ID:	29178   Click image for larger version.
  20. #60
    5,129
    Installing instruments sure has changed in the 10 years since the last go-round!
  21. #61
    9,268
    Maybe Dr. Randy will correct me, but I thought one was limited to one Viagra at a time...
    Ok, back to your beautiful bird: looking great! I really like your cleanliness in the installations. When you go to fix or change, it will make it much easier.
    On the side note, have you considered some hard points on the wings for 'wolf control' additions?
  22. #62
    Jul 2002
    Anchorage, Alaska
    5,404
    SB, make sure the wrappers are removed before u install those boxes
  23. #63
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    770
    Stewart, I love seeing your progress and reading your updates! Thanks for sharing them!
  24. #64
    10,901
    The wrappers stay on till final install time. Don't wanna zap one.
  25. #65
    5,129
    How to turn a bad fitting composite boot cowl into something useful. We liked the molded windshield channel. Mike envisioned a way to keep it and morph a more conventional boot cowl to it. But wait, why would I ever want to do old man gymnastics and hang upside down in impossibly cramped space to access behind the panel? What about accessing the rudder pedal pivots (BCSC's control setup has the pedals hanging from a pivot tube above). Why not make removable panels on the sides? No permission required. One more advantage of the experimental category.
ID:	29803   Click image for larger version.
ID:	29804   Click image for larger version.
  26. #66
    5,129
    Fine Line never fails to impress. Nice looking and comfy!
  27. #67
    5,129
    Progress. The G3X Touch component shelf has been wired. Holy cow that's a bunch of wires!
ID:	30077   Click image for larger version.
    Likes C130jake, WanaBNACub liked this post
  28. #68
    RaisedByWolves's Avatar
    Feb 2005
    3,984
    You will love the g3x
    Likes WanaBNACub liked this post
  29. #69
    5,129
    Details matter. Pretty blue powder coating on engine baffles, air box, and assorted engine compartment parts.
    Likes SJ, WanaBNACub liked this post
  30. #70
    Alaska/NE Washington
    364
    I see the dog and the cat are captivated by your project
  31. #71
    5,129
    Don't forget Windy. I enjoy a real bush pilot watching over my project.
    Likes WanaBNACub, C-FIJK, Fat Kid liked this post
  32. #72
    5,129
    Firewall forward is almost finished. G3X Touch components are in place. Entering the home stretch.
    Why do some photos post sideways even when they're correctly oriented when loaded?
ID:	30305   Click image for larger version.
    Likes gregory, Fat Kid, C130jake, Scooter7779h liked this post
  33. #73
    5,129
    Holy rat's nest, Batman! Seriously, the G3X Touch looks simple and elegant from the front but there's a whole lot going on behing the panel. I never considered the cost of coordinating and wiring the various boxes. Lesson learned!
    Thanks cubscout thanked for this post
    Likes Dave Calkins, Cub Kid liked this post
  34. #74
    C130jake's Avatar
    Sep 2012
    Minnesota
    403
    My harnesses were built with every possible input. Ones I am not using yet were hidden between boot cowl and interior panel. (Two auto pilot, carb temp, two fuel qty, trim position, back up battery) I may put in carburetor temp at next conditional inspection. One wire at a time. Easier than it looks. You will love the G3x.
    Jake
    Sent from my SM-G930V using SuperCub.Org mobile app
  35. #75
    Jul 2002
    Anchorage, Alaska
    5,404
    Holy rat's nest, Batman! Seriously, the G3X Touch looks simple and elegant from the front but there's a whole lot going on behing the panel. I never considered the cost of coordinating and wiring the variousp
    there is a lot to love in a stock oil pressure/temp instrument along with a tachometer. Just like the loving of a ratty original stock -18 Cub that can be patched back to "airworthy".
    But your shiny new EXP "cub" with a classy glass panel will be SO SWEET, so enjoy it since you can afford it and made those decisions. !
    Likes Cub Kid, pfm liked this post
  36. #76
    5,129
    I looked at conventional flight instruments and a JPI 930 for engine instruments. At face value the G3X Touch had a similar price tag. I added the AP because it wasn't very expensive to do so. The lesson here is that the cost of professionally wiring it, not including any cost to install it, is about 50% of the aggregate cost of the display and components. That may have been a deal breaker had I thought about it, but I didn't. The point of the comment was to alert others who may wander a similar path. I have no regrets, I asked for a service and it was provided. The work is excellent and the pricing was fair. I'm just sharing my experience. On the bright side, all the wires are labeled using a wire printer. How cool is that?
    Thanks Cub Kid thanked for this post
    Likes Gordon Misch, wireweinie, pfm liked this post
  37. #77
    Jul 2002
    Anchorage, Alaska
    5,404
    What auto pilot? I didnt catch that earlier in the thread. Its cool if it works well in a Cub control system. Some ap's do not
  38. #78
    5,129
    Garmin sells the servos for $750 each. The G3X Touch has 2-axis control capability built in whether you use it or not. We started with the capstan hubs (the operation style that grabs cables) and thought about where to hide the servos but went with direct drive rods on the torque tube-stick housing for roll and to a fixture added on the bottom of the stick for pitch. The pitch servo is a little exposed to feet but with the rudder and brake rods running through that area it isn't a big deal. There are pics on the website. http://wildcatcub.com/at-your-servo.html
    I call the wing leveler button the "Chicken Switch". Not because I expect to use it if I get into the crap and start second guessing my stupidity, which isn't a bad idea, but rather for when I take my wife fishing. She brings KFC for after work adventures and this way the damn plane can fly itself so I can eat chicken AND hold a napkin. Civilized!
  39. #79
    Jul 2002
    Anchorage, Alaska
    5,404
    Have messed with the capstan style on the cables in an EXP Cub and was less than impressed
    Garmin doesnt make junk, so it oughtta be really neat. I am an original recipe guy!!
  40. #80
    5,129
    Eating an apple and milling a panel. More fun with power tools.
