Results 1 to 10 of 10
Thread: Airframe screws getting loose solution?
    RandyZ's Avatar
    Dec 2013
    Live in Elizabethtown, KY
    13
    Question Airframe screws getting loose solution?
    Anyone have an idea on how to keep the little aluminum screws all over the wing/fuselage/access panels from vibrating out? Has become a part of my post flight now to tighten these guys along with a bug scrub. Invariably some go missing. New owner of PA-18-150. My first post on the forums😊 Thanks all.
    Randy
    N82518
    aktango58's Avatar
    18AA
    9,459
    silicon. Just a dab on each screw...
    use clear, it will not show.
    evroosevelt's Avatar
    Dec 2009
    Wilsonville, AL
    159
    Randy fly it down to AL17 Wilsonville AL and we will try and fix that.
    EV
    256-310-3806
    2,285
    Put a dab of clear silicon in the hole before you put the screw back in. I had to redo weight and balance on my pacer every time I flew until I learned this trick.
    mike mcs repair's Avatar
    11,774
    Quote Originally Posted by RandyZ View Post
    Anyone have an idea on how to keep the little aluminum screws all over the wing/fuselage/access panels from vibrating out? Has become a part of my post flight now to tighten these guys along with a bug scrub. Invariably some go missing. New owner of PA-18-150. My first post on the forums Thanks all.
    Randy
    N82518
    whoever drilled the holes used to big of a bit(to fit a clecko size)... seen many...
    but now your only choice is a bigger screw...
    RandyZ's Avatar
    Dec 2013
    13
    Thanks so much for the advice guys. And so quickly. I like this forum already! Will let you know when I venture out to AL17. Currently running the wheels off this thing and looking for grass strips /$100 hamburgers �� Thanks so much to each of you for responding!
    Cheers,
    Randy
    CamTom12's Avatar
    Jul 2015
    Huntsville, AL
    782
    Randy,
    I'm just up the road from you at HSV. We need to link up one of these weekends.
    Cameron
    Jim 4WF's Avatar
    May 2010
    anchorage
    62
    Thin weed wacker line in hole then put screw in, cut flush with razor knife before fuly tight. Acts like a nylon lock nut.
    RandyZ's Avatar
    Dec 2013
    13
    Thanks Cameron & Jim! I go into Moontown often. Great little strip! Randy
    Thanks Jlee thanked for this post
    RandyZ's Avatar
    Dec 2013
    13
    My profile avatar was taken in Moontown at the fuel pump
  1. One hot O-235 - oil cooler solution?
    By Piper46 in forum Modifications
    Last Post: 10-29-2017, 10:25 AM
  2. High EGT -- Simple Solution
    By Darrel Starr in forum Tips and Tricks
    Last Post: 06-20-2011, 07:26 PM
  3. Firewall solution??
    By JayH in forum Experimental Cubs
    Last Post: 02-19-2011, 11:48 PM
  4. Loose Screws
    By RON NORMARK in forum Super Cub Sick Bay
    Last Post: 06-01-2006, 12:15 AM
