Pete Lastrucci
Johannesburg, South Africa
I have a PA12 with an O320 Lycoming.
It has the PA18 stab / elevators fitted as one of the mods for the bigger engine.
Is the standard (PA12) elevator deflection of +27 deg up and 32 down correct, or would the PA18 spec of 25up and 15down now apply?
Secondly what is the correct rigging procedure for the elevator position in relation to the front belcrank / joystick fore aft position. (ie aircraft level, stab and elevator 0 degrees, now the position of the stick?)
A bit of concrete advice here would really be appreciated as I cannot find this info anywhere!
Pete Lastrucci
South Africa
Pete Lastrucci
South Africa
