Page 2 of 2 FirstFirst 12
Results 41 to 70 of 70
Thread: Building an Experimental PA11
  1. #41
    nd
    3,535
    Has anyone just mounted a small gearmotor back there to run a belt/cable to just turn the stock pulley on the jackscrew?
    or just take the pulley off and hook the motor output shaft direct to the jackscrew?
  2. #42
    Upper Peninsula of Michigan
    441
    Thats pretty much what bill rusk did on his Javron
  3. #43
    10,189
    Electric motors do not have much power when operating from a dead start. They would be much better in this type of application if they had a reduction gearing/belt pulley arraignment where the motor could get some RPM while doing it's work.
  4. #44
    Southern Aero's Avatar
    Jan 2008
    kcco/1ga2
    187
    I haven't found a satisfactory way of driving the jack screw and leaving the manual trim in place............. need some kind of clutch/disconnect ...... I have experimented with several gearmotors but haven't found a lighter one that has enuff power to work under and air load. I have also been working on incorporating a Mitchell trim motor assembly from some old Piper Comanche Senaca, etc. Little heavy so have been working a modified gearmotor with same working principal. Will post something later on it if I get it to work properly. Maybe someone else has already done this and can shed some light?
    ......... It doesn't cost any more to go first class! You just can't stay as long.
  5. #45
    nd
    3,535
    thousands of high torque startup motors out there like this.https://www.amazon.com/dp/B00NMDPQAQ...a-323303013812
  6. #46
    gbflyer's Avatar
    Feb 2007
    PAGS
    736
    Can’t recall fooling with the trim much on the -11 we had. Had the -18 balanced tail, understand the Pacer width tail is the best.
    Certainly not a moose hauler. I’d think the Ray Allen servo and a tab would be a pretty simple and light solution. Works good on our current S7S. I doubt we use 5 degrees of the available deflection.
  7. #47
    Jan 2008
    kcco/1ga2
    187
    Yup, quite familiar with them ......... have quite a few. Would work fine but I want to be able to disconnect from the drive so I can manually trim. The Mitchell type have a spur gear that is disconnected when power to the drive motor and solenoid is removed allowing you to still manually trim. I am experimenting with that kind of disconnect with one of these gearmotors
  8. #48
    3,572
    Why do you want manual trim also? Redundancy? Fine adjustment? Just curious, thanks!
  9. #49
    Jan 2008
    kcco/1ga2
    187
    Yes to both!
    Thanks Gordon Misch thanked for this post
  10. #50
    3,572
    Interesting. I will be helping a friend with an experimental -12, and I was planning to recommend to him an electric trim similar to what Stewart used. That's why I asked.
    So my follow-up question is, why the need for manual "fine adjustment"? The higher load capacity linear actuators have slower travel rates, which I think might be why Stewart's actuator has such a high force rating. I think.
    Calling Bill Rusk - - what is the travel rate of your electric trim system, and do you have issues with setting the trim "exactly" where you want it?
    Redundancy, to me, isn't important because at least in my -12 I only touch the trim for changes in loading.
    Edit: I think that cruise would be the only flight regime where an "exact" trim setting would be desirable. But in that regime a small change in engine power setting can achieve approximately the same effect as a small change in trim setting. Or I just set my arm on my lap so there is a slight stick pressure.
    Not trying to be adverse, just trying to envision an optimal solution. Thanks - -
  11. #51
    5,129
    http://www.tcwtech.com/Safety-Trim-Page.htm
    Actuators will use the 10A model. High speed-low speed controllable and the low speed rate is user adjustable at the module.
  12. #52
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    842
    I have about the same setup as Bill Rusk and I love it. No pulley or cables. Very simple. About 17 seconds on the ground.. Easy to trim perfect.
    I can't really see the purpose of having redundancy in a Cub trim system..? Worst case scenario is almost really a non event.
    Thanks PerryB thanked for this post
    Likes JeffP liked this post
  13. #53
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,956
    Just power it through a pull-able (new word) circuit breaker, so it can be readily disabled should a switch stick.
  14. #54
    3,572
    Stewart, could you please give an operational report on this system when you've flown it a bit?
  15. #55
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,956
    If I ever DO get around to building a SC it's going to have an electric actuator with a digital position indicator. Phooey on cables, wires, pulleys and springs.
  16. #56
    441
    Yes, just run the positive wire to a toggle switch ahead of the rocker switch so it can kill the juice if it sticks
  17. #57
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,956
    I was just thinking of a plunger type CB, but the ones that have a protruding head that can be pulled. As opposed to the ones that push in flush.
    Likes Gary K liked this post
  18. #58
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    842
    I don't any trim indicator in my case. I Just takeoff full nose down trim and work my way from there.
  19. #59
    PerryB's Avatar
    Aug 2007
    Chico, CA
    1,956
    Just curious, is your plane somewhat aft on the CG? It surprises me you go to full nose down for takeoff. Or does that have something to do with a modified thrustline?
  20. #60
    5,129
    Slow speed might make sense for the RV guys who are all about going fast but I'm confident the faster speed will be fine in the Cub. It isn't that fast. And I do like the three second time limit. Nobody wants runaway trim and the little stick top switch is the weak link in the system.
    Thanks Dan Gervae thanked for this post
  21. #61
    441
    You can always try to make things easier when building your own cub...this boot cowl allows access to the front rudder pedals.
ID:	41084Click image for larger version.
    Likes jrussl, BC12D-4-85, CamTom12, stknrddr liked this post
  22. #62
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    842
    I was teached to do so, for shorter takeoff distances. Just like full nose up for landing. But the plane feel more natural at about neutral trim.
  23. #63
    441
    Any of you out there with experience see an issue with me using a J3 engine mount? I know the PA11 is 4 degrees different....but what will this do? how will affect flight characteristics? This is a plans built fuselage and I have mounted the O200 using the J3 mount.
  24. #64
    Feb 2008
    STL
    264
    Hot Damn Dan!! Looking good!! Your kickin my butt!
    If you get lost while flying, don't try hail a cop. Pick up the first railroad you find and hug it until you get somewhere.
  25. #65
    May 2014
    85
    Quote Originally Posted by Dan Gervae View Post
    Leave the J3 mount; it is automatic thrustline-mod, and in my humble opinion, the only way to go on this fuselage/wing combo.
    Only downside is that on 29s with big gear, you won't be able to see much over the nose when on the ground. Takeoff, landing, flight characteristics of zerothrustline on this fuselage and wing is fantastic and far outweigh the need to s-turn while taxiing.
    (I fly a Wag Aero J3/PA-11 like thing with a zero-ish degree thrustline up on big tires and gear)
    Likes Southern Aero liked this post
  26. #66
    441
    I haven’t worked on my project much this summer since I took on building a new hangar....I did take it all apart for fabric work ( only fuselage and ailerons left to cover) but I had a local guy do me up some seats. I think they look pretty nice.
  27. #67
    39-J3's Avatar
    Sep 2008
    Maine
    553
    I saw on another thread that you are back to working on your 11. I am looking forward to following your progress and curios as to what the empty weight will be as I have a stout 0-200 powered PA 11.
    Larry.
    Thanks flynlow thanked for this post
  28. #68
    441
    I had this fuselage envelope so I used it...I wouldn’t use an envelope again, more of a pain than it’s worth...I had to splice the tail fin piece on since it was separate. Anyway, I’m plugging along again. Once I finish tapes on this, all I have left for fabric are ailerons and landing gear....then 3 to 1 brush coats and ekofill....should be ready to paint when the weather warms. My fuselage rotator was at my dads 100 miles away so I used the old 2x4 trick. I didn’t feel like fabricating a new one. Lol
    Thanks stknrddr thanked for this post
    Likes Riverking, Southern Aero liked this post
  29. #69
    441
    Here's my fake carbon fiber panel
    Likes motosix, Chicken Hawk liked this post
  30. #70
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    786
    Dan,
    How's your progress on the Cub Special
    coming along????
    E
    Sent from my moto e5 go using SuperCub.Org mobile app
  1. building exp PA11
    By jon s. blocker in forum Cafe Supercub
    Last Post: 02-04-2014, 10:51 AM
  2. Are You Building an Experimental Cub?
    By Steve Pierce in forum Experimental Cubs
    Last Post: 01-22-2010, 07:18 PM
  3. Experimental SuperCub building
    By Jr.CubBuilder in forum Experimental Cubs
    Last Post: 04-21-2004, 04:03 PM
