Ironically that went away after I indexed the prop 180 degrees. But I hear what your saying….it sure had been running well too. It’s not the end of the world. I’ll fix it right. It wasn’t stuck too bad and I hope I can get it feeling good again before Oshkosh/New Holstein.From above "Maybe it was morning sickness"
6/8-21:
#279 "Actually now that we are talking about this, my Catto has a strange harmonic at about 2375 as I’m just transitioning from liftoff to climb out ...only for a few seconds then it goes away"
#284 "The idle mixture may be slightly rich as I occasionally get a stumble on takeoff...usually on a touch and go or full stop and then go again"
"...engine has 300 Ish hrs on top and 30 on lower (new bearings after tear down and internals magnafluxed and yellow tagged)"
Maybe it was talking to you earlier?
Edit: If I were out in the bush and had a stuck valve - I'd apply Kroil or spray brake cleaner and tap it with my rubber hammer. They have it removed and repaired when back in town.
...I did shut it down hot when I landed the other night and it was stuck as soon as I started it...
I had 3 stuck valves, did the rope trick to unstick & also reamed the guides and buffed the valve stems as much as possible. Everyone recommended MMO, so I tried it. Made it home then up to the Idaho backcountry and two of the exhaust valves started sticking again, less than 20 hrs after the reaming exercise. Removed the cylinders & had them overhauled by a reputable engine shop. A lot of time & money spent and the overhauled jugs got me about 400 hrs before two more valves were sticking. Bit the bullet and overhauled the engine & found a spalled cam shaft. 2400SMOH when I did the OH. If I had to do it over again, I’d have done the reaming enough to make it home, then overhaul the engine or install new cylinders. The MMO and overhaul of worn out tired cylinders were both a waste of time and money. IMHO
windy
Mogas or 100LL?
100LL. I’m religious about leaning at the high DAs where I live & at all lower elevations too. The spark plugs rarely had more than a tiny lead glob or two and were always light gray. It was a LyCon engine. Cylinders were new Lyc nitride ones at the previous overhaul. It took me 8 years to put the 2400 hrs on the engine.
is it worth the effort tho pull the motor and place on a stand? I fell like it could save some work not pulling it. Thoughts?
Drill works good, I use MMO to free it up and then valve gringing compound on the shaft to clean up the guide hole
Never used Seafoam on anything, have to try it
