Results 1 to 11 of 11
Thread: PA12 180HP Conversion
    D.A.'s Avatar
    The Left Coast
    667
    Do you have to remove any fabric from a PA12 to install an O-360? I've seen all the tubing added with Charlie Center's mod, but I can't remember if that was for a 180 or for the 1950 GW increase. If there is a way to install a 180 without structural mods, is there an STC or are each of them just field approved? How are the banner tow guys doing it?
    Thanks in advance.
    D.A.
    4,396
    Crosswinds has the short mount/modified cherokee cowling 180hp STC and Univair has the short mount/Supercub style cowl STC. I'm pretty sure both will require Cub tailfeathers, Cub gear, and probably flaps. That's where the modifications will bite you if you don't already have those things. It's likely that the 1935# gross would be a preferred mod but it isn't required that I recall.
    D.A.'s Avatar
    The Left Coast
    667
    I'm pretty sure both will require...Cub gear, and probably flaps...
    Thanks Stewart. So you'll be into the fabric on both the wings and fuselage. You'd only need to replace the forward gear fitting to run Cub gear if I'm not mistaken. But it sounds like there aren't any other structural mods within the fuselage. The banner guys must be getting FA's because I've seen some PA12's with stock gear and no flaps towing signs. I've even seen J5's with 180's as tow ships.
    Thanks Stewart.
    9,046
    The banner guys are not normal category. Likely "Restricted" so it is another ball game.
    D.A.'s Avatar
    The Left Coast
    667
    The banner guys are not normal...
    Yeah, I can vouch for that
    Likely "Restricted"....
    Yeah, I was afraid that might be the answer.
    Thanks skywagon.
    10,192
    you just ADD/weld 2 pieces to the EXISTING front gear attach fitting on each side to attach the cable Vee to
    D.A.'s Avatar
    The Left Coast
    667
    Is that an STC Mike?
    CubDriver218's Avatar
    Sep 2007
    Minnesota
    626
    So if I already have a 150 HP is there a lot more that needs to go into getting a 180? or can I simply buy engine, and buy STC and "plug and play"?
    Fast or slow, always low, freedom of flight soothes the soul.
    WhiskeyMike's Avatar
    West Boxford MA
    868
    Pa-12/180
ID:	21794I use the Xwinds STOL version and really like it. I"ll have to check, but I don't recall any fuselage mods. Only for gross weight increase. Big tail yes, flaps, maybe not. Performance is excellent. As a minimum make sure you have the landing gear straps modified per SB (or AD) from flat strap to beefed up with streamlined tube welded around it. Also check for the SB on the little aileron hinge support brackets. That one is obscure but there should be a little extra bracket on the aileron hinge supports. Had them both ways and never had an issue. BTW The XWinds mod allows for excellent cooling, plus the twin mufflers are efficient and quiet.
    Colorguns's Avatar
    Dec 2013
    Bloomfield NY
    304
    Charlie Center conversion, short mount, no other tubing needed in the fuselage other than for increase of GW.
    Nov 2018
    1
    I own one of the sister ships to 2504M.
    I am up in Alaska with 3396M. Just got her up here from Alabama. I have a bunch of questions about the planes if you could send me a message
    For whiskey mike
  1. Replies: 16
    Last Post: 03-10-2017, 11:35 AM
  2. 180hp conversion
    By phgeorg in forum Modifications
    Last Post: 08-28-2014, 07:14 AM
  3. PA12 O-290D Conversion
    By TrentF in forum Super Cub Sick Bay
    Last Post: 09-29-2008, 11:00 AM
  4. 180HP Conversion - available options - PA18-150
    By Stearmanfrosty in forum Modifications
    Last Post: 05-03-2007, 05:36 AM
