Page 1 of 2 12 LastLast
Results 1 to 40 of 46
Thread: Aileron Cable - is this Okay?
    SchulerJL's Avatar
    Aug 2009
    Peoria, Illinois
    579
    I went flying last Saturday morning and as usual I had a couple of GoPros hanging on the plane. They are great to review technique etc. While I was watching the movie of the right wing, I noticed a lot of play in the aileron cable when I did a forward slip. It only seems to do it when I am in a slip. The first one has the most slop in the cable. I included the wing camera video on the first one as that was the steepest slip. On the video you can hear when I do a slip and watch the cables go slightly slack. The cables are new, had them replaced last January 2014. They do not feel loose on preflight inspection. Should this be a concern?
    https://youtu.be/BrIfH4ff1BM
    Bill Rusk's Avatar
    5,248
    No. Thats normal.
    Very Blessed.
    9,845
    Quote Originally Posted by Bill Rusk View Post
    No. Thats normal.
    Or still too tight for some of us who like a sloppy stick feel.
    irishfield's Avatar
    2,957
    Point the camera in another direction and the "problem" will go away!
    Likes flylowslow liked this post
    fancypants's Avatar
    Jan 2011
    IL
    331
    Your cables look pretty tight. Took me a while to find a halfway decent photo, but this shows the "slop". Feels ok to me, but it is a little strange to see the cables flapping in the wind.
    I'm in the middle of replacing my cables right now, partly due to excessive slop, but mostly because the balance cable was OLD, and there was obvious wear on all four cables. I found it interesting that the cables I removed measured out almost exactly to the original Piper spec, 173-11/16" for the upper control horn cable (attaches to bottom of stick) and 167-15/16" for the lower control horn cable (balance cable above your head). So, no apparent cable stretch. The slop in the system seems to have been caused by worn pulleys and a bent pulley cage. Some of the slop could have been removed if I bottomed out the turnbuckles, but I'll feel better with new cables. We will see if the new Dakota Cub ball bearing pulleys allow cable tension to be increased without inducing too much drag.
ID:	19726Click image for larger version.
    SchulerJL's Avatar
    Aug 2009
    Peoria, Illinois
    579
    This is why I am a member - awesome replies. thank you. I thought it was a non event. There is very little slop in the cables - I like that - so I thought it was Okay.
    Fancypants - how in the world did you come up with that picture so quick?
    Bill Rusk's Avatar
    5,248
    Just as an aside, sometimes just one turn on the turnbuckle will completely change the "feel" of an airplane. Mostly in the ailerons, but even in the rudder and elevator to a lesser extent. Don't be afraid to experiment a little. What feels "best" to you will probably be different from the next guy. As Glenn says above.
    Very Blessed.
    fancypants's Avatar
    Jan 2011
    IL
    331
    I don't need much of an excuse to start looking through old airplane pictures... it was a nice distraction during a boring conference call. Happy to help.
    SchulerJL's Avatar
    Aug 2009
    Peoria, Illinois
    579
    Dan Byker replaced the cables last year. It had Stainless cables that were used during the restoration - after about 150 hours the stainless cables started to fray. I really think it handles better with the galvanized - or it was just set up better. Flies awesome now, I would have hated to change anything.
    cruiser's Avatar
    South Glens Falls, NY
    1,441
    I added DC ball bearing pulleys last year but I think the biggest improvement was made when I disassembled, cleaned and lubed the stick bearing saddles. Dried up grease is really draggy!
    texmex's Avatar
    Aug 2008
    Hanging Rock, Australia.
    332
    Can't vouch for the handling. But I got very poor life span with the stainless. The galvanised ones seem to last much longer.
    I guess the stainless steel cables are good for low
    usage aircraft on water.
    For those that do a lot of Cub work (Mike, Steve etc) does that seem about correct?
    9,845
    I'd tell you that my J4 has the original galvanized Navy tucked woven splice cables that piper installed in it in 1940 but you'd think I was crazy flying it on floats 100+ hrs a year.
    algonquin's Avatar
    Apr 2013
    Seldovia,Ak
    904
    You wouldn't believe how many times I find a pulley that is sticking during annuals. I like LPS2 to free them up, when checking them don't just rock them turn them a couple revs both directions. Also make sure they move when the controls are moved, this is where you find worn pulley groves and/ or cable tension problems.
    Jan 2012
    Whitehorse, Yukon
    424
    Most guys I have talked to agree that galvanized cables are the way to go, even for float ops. If you are primarily in a salt water environment that may be different. But stainless cables are prone to fraying and stretching (so i have been told). As
    Alginquin said, pulleys are more often the culprit with draggy controls
    9,472
    My 2 cents,
    Stainless is more susceptible to chaffing and wear than galvanized. This is usually not a problem. The stainless cables on my 185 are nearly 40 years old without ever having any need to be changed. It's tensile strength is also less but is more than enough for our application. It is important that the pulleys be properly lubricated so that the cables do not drag through them. Dragging damages both the cable and the pulley which also changes the cable tension due to the reduction of the pulley diameter. The advantage of stainless is that it is more corrosion resistant than galvanized. Galvanized can easily develop rust in moist environments. This rust can be hidden inside leaving broken strands which can be unnoticed for years until the cable breaks.
    Galvanize solution: Soak thoroughly the galvanize cable in a can with some warm soupy paralketone (sp?) or some other suitable sticky corrosion preventative (like LPS-3). It comes out of the can rather thick so be sure to thin it. Kerosene works (gas does too). You want it to penetrate and coat all of the strands of the cable. Take the cable out of the can and hang up to dry before using. It gets sticky. It will last for years with this treatment.
    Cable tension: I will not question your desires for loose cables for light control pressures. That is your choice. However remember what the cables are supposed to do. In this case it is to move the ailerons. The ailerons need to be able to hit their full travel stops in all flight conditions. IE: Gusty crosswind approaches and landings. Do this: Have a friend hold the stick hard against the stop. This stop is under the floor at the rear stick. You grab the up aileron (be careful how you grab it, since it is more susceptible to fingers than to air loads) and pull it down. Can you pull it away from the up stop on the wing? If the answer is yes, the tension is too loose. Full aileron travel depends on the pilot being able to hold it against the stop with the in flight air loads pushing against them. IF the ailerons can be blown away from the up stops, you will not be able to hold the wing down as much as you wish in a crosswind take off or landing. Your ability to pick up a wing while landing in a gusty crosswind on short final will be compromised. How would you feel if you dragged a wing on short final because the ailerons did not hit their stops? Also and I hate to bring this up, if you loosen your cables, earn a hat, and your mechanic or IA didn't catch it, he could be liable. Lose his license, money, life style, etc., etc. Don't jeopardize your mechanic.
    The cable from the stick up the front strut to the aileron controls the up stop limitation. If you wish the aileron cable tension to be loose use the adjustment of the balance cable for this purpose. A loose balance cable allows the ailerons to fly up in flight (loosing some short field performance).
    9,845
    I like my cables looooose. I moved or shortened the stops to give me full travel. Same with the rudder stops, if you have more then 3/8" between rudder and neutral elevator your going to have trouble turning on skis.
    behindpropellers's Avatar
    NE Ohio
    6,702
    Maybe your cables are straight and your strut is flexing
    RaisedByWolves's Avatar
    Feb 2005
    3,827
    We have been seeing the stainless wearing on the struts of the supercubs, where it goes through the fair lead, and rubs.
    9,472
    That does not surprise me. Those fair-leads should be of a materiel which will not wear stainless. Nylon, Delrin, what? There is a phenolic anti-chafe strip on the top of the bulkhead at the aft end of the 180/185 baggage compartment. IF the elevator cables touch they will wear there.
    ps. Perhaps loose cables allowing a lot of whipping around in the breeze is the cause of the wear?
    9,472
    Addendum to post #15 above,
    For some reason unknown to me, Piper designed the Cub with equal travel of the ailerons in both up and down directions. Most other types of planes have differential aileron travel, that is more up than down. Differential travel reduces adverse yaw. A down aileron has more drag than an up aileron thus when banking the nose will tend to yaw in the direction opposite to the desired turn. Less down aileron than up, reduces this tendency. More down aileron increases the stall speed on that wing. So what happens when a wind gust drops your wing on short final? Your reaction is to slam the stick full in the opposite direction. That encourages the low wing to stall rather than to lift up. Is this related to the "Moose Stall"? (Don't forget to use the rudder)
    I know you all know this, it doesn't hurt to remind us all.
    Why do I bring this up here? It is because there seems to be a desire among some to leave their aileron cables loose, either intentionally or unintentionally. The important most critical thing to pay attention to is that the ailerons MUST hit their up stops (not the stop under the floor, the one on the wing) with the stick hard over in flight. The cables stretch a little under load. If you want to leave the cables loose, let the ailerons ride away from the down stops. This may actually improve the aileron response. Don't get me wrong, I'm not encouraging you to do this. Only trying to make you more aware of the consequences.
    This equal aileron travel in both directions requires more aggressive use of the rudder to supplement the ailerons in picking up the wing. If you learned to fly in a Cherokee you will need lots of practice with your feet. Those pedals are not just a foot rest.
    SchulerJL's Avatar
    Aug 2009
    Peoria, Illinois
    579
    That is outstanding information. I never "joined the dots" with regard to this - makes sense - thanks
    RCharles's Avatar
    Jan 2004
    Atlanta, Ga
    252
    I am replacing a stainless cable due to wear at the forward strut Fair-lead .What is the best way to connect the new and old cables together to pull the new one through the pulleys without removing the them ?
    fancypants's Avatar
    Jan 2011
    IL
    331
    RCharles: try heat shrink tubing, or the method shown in the post linked below. Removing the pulleys for that particular cable should be easy if it gets jammed up. Those pulleys are readily accessible by removing the covers on top of the wing, and inside the fuselage where the cable exits.
    http://www.supercub.org/forum/showth...l=1#post619711
    RCharles's Avatar
    Jan 2004
    Atlanta, Ga
    252
    That looks like the way to go... with the safety wire , etc . Thanks
    10,501
    Quote Originally Posted by RCharles View Post
    heat shrink is all I've ever used... the KEY is to pull gently, and not yank if it gets stuck, sometimes ya gotta back up and try again...
    cruiser's Avatar
    1,441
    Your making a lot more work for yourself than necessary, the most difficult part is disconnecting/connecting the cable at the rear stick. Unless you have a big hole in the floor, take the stick bearing saddles apart, raise the torque tube slightly for access, don't lose the shims. Clean and lube the saddles, clean and lube the pulleys, pull the cable thru the wing with anything long enough to reach. Done.
    jimboflying's Avatar
    May 2005
    503
    Is there a consensus about which is best, galvanized or stainless for cables?
    9,472
    Quote Originally Posted by jimboflying View Post
    If you live in dry country galvanized will do. In high humidity and coastal regions when kept outside the portions exposed to the elements can rust. If the rust forms on the inner portions the cable can break without you knowing it was rusted. This can be minimized by a liberal application of paralketone. They are a little stronger than stainless though not enough to matter in our use. Stainless is more susceptible to chafing where it rubs on fairleads etc.
    Use 7 X 19 for best flexibility. 1 x 19 is only good for straight runs like in rudder cables.
    10,501
    I use galvanized unless by saltwater
    Stainless doesn’t wear well
    18,832
    500 hours on stainless aileron cables, they start fraying at the first fairlead on the lift strut out of the fusleage. Had no issues with galvanized.
    9,472
    500 hours on stainless aileron cables, they start fraying at the first fairlead on the lift strut out of the fuselage. Had no issues with galvanized.
    Does it matter what material this fairlead is made from? Would it make a difference if it was wood, phenolic, teflon or some other material? Perhaps we should consider changing the materiel that this fairlead is made from?
    Stainless cable is susceptible to chafing and wear in places where we may not expect. Places such as that pulley inside the wing where the cable turns 90 degrees going to the aileron. That pulley bracket is made in a manner so the cable rubs on the side of the pulley, not good. The bracket does in many cases need adjustment.
    9,845
    My 1940 J4 still has most of it's original galvanized cables Piper built it with, braided ends and all.
    18,832
    It is the original nylon or whatever Piper used. Not an issue on galvanized. Have not seen any issues at the pulleys except the front elevator pulley that turns 180 degrees. Also have found frays on the rudder cables where they exit the fabric. What is interesting is that the issues I have found are on Cub Crafters data plate Cubs with 500-1000 hours. Haven't found issues on factory cables with at least 1500 hours other than the noted stainless aileron cables. Also no issues on my 13,000 hour Super Cub which I think got new cables at rebuild in 1992 but don't remember the hours.
    CenterHillAg's Avatar
    Texas Coast
    92
    I run galvanized cables on my AgCat, 1200 hrs on the current set and look fine. My buddy runs stainless on his and replace them every year/600 hrs with flat spots and fraying already starting. I’m not convinced stainless is the solution to corrosion issues on airplanes, for cables or panels. It just seems too brittle to hold up to the shaking. I prefer galvanized cables and a properly prepped and painted aluminum panel.
    Likes mike mcs repair, Steve Pierce liked this post
    6,804
    Can't believe I did not contribute here. I see 6000 hour Cub galvanized cables. Just saw both rudder cables replaced after 600 hours on a Super Cub. stainless. But worse - the restorer put aluminum cable feed-throughs in the fabric. Cut both sides almost in half.
    I replaced my personal Cub aileron cables three years ago, after 5000 hours. One strand on each side broke, and was a potential hazard mostly to my fingers when wiping down the struts.
    I keep oil on the pulleys and Par-Al-Ketone on the cables (sometimes).
    Dec 2004
    Inkom, Idaho
    1,371
    My RANS S-7S uses cable for the rudder, and they travel thru nylon guides. I had both start to fray at 1200 hours (stainless) and replaced them with galvy. One thing stainless is preferable for: a hang glider or ultralight, where you are constantly handling the cables when breaking it down, your hands and the sail stays clean. For conventional aircraft use it seems to offer more disadvantages then it's worth?
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    406
    Did you pull the fabric off to change the cables ?
    Quote Originally Posted by fancypants View Post
    Gerry Marcil
    Every day spent flying is a great day !
    10,501
    Quote Originally Posted by C-FIJK View Post
    Why would you need to remove fabric??
    Cut, heat shrink new cable to old, pull it in gently.
    If you are good you get it all cut to proper length before pulling in the final piece .....
    If you are not gentle you break the heat shrink or pull it off cable and your life gets sad fast....
    fancypants's Avatar
    Jan 2011
    IL
    331
    Gerry,
    I did not remove any fabric to replace my aileron cables. As Mike mentions above, it's possible to feed the new uncrimped cable into place without major disassembly.
    That said, if I were to do it over again I might just buy the pre-fabricated cables from Univair. Since I was replacing all of the pulleys at the same time, my recollection is that it would not have been much more trouble to snake the finished cables through the wings. That was a while back, so I might be forgetting something.
    Jul 2013
    21
    If you are worried about heat shrink failing to keep the old an new cable ends together while pulling through the airframe (especially with the cheap Chinese heat shrink found at your corner auto parts store) you can take some 20 thousandths safety wire and spiral it down each cable across the splice area and then cover both it and the splice with heat shrink. The wire will aid the heat shrink's tensile strength. Or go liberal on the heat shrink length by using a good 6 to 12 inches of it to grip more cable on each side of the temporary splice. There is also some good thick adhesive-lined heat shrink but it might be too stiff to bend well around pulleys. Try to use 3:1 or 4:1 ratio shrink tubing to grip the cables with more pressure.
  1. Aileron Cable Clearance
    By tempdoug in forum Tips and Tricks
    Last Post: 02-02-2007, 08:15 PM
  2. 12 Aileron Cable Tension
    Last Post: 05-06-2005, 08:24 AM
