jimboflying
I decided to make a titanium firewall for my experimental 14 project. I first made a plywood form to the outline I wanted. I then made a 2X8 forming block with a groove cut into it to accept one side of the angle aluminum which was the shape of the corners of the firewall pattern. I then formed the predrilled aluminum angle and removed any small wrinkles with a shrinking tool. I then welded the ends together. I next drilled the titanium sheet, cut the outline, deburred, and riveted the sheet to the formed edge. The lessons I learned were: to use hardwood for the forming block, keep the groove narrow to prevent wrinkles, that titanium is a funny metal, titanium is hard to drill with anything other than very low speed, coolant and heavy pressure, titanium sheet has a grain structure and can crack when a roller die is used to form it, and titanium makes cool sparks when ground on. Finished weight was 3#6oz.
