Russ Norwood
Austin, TX
I recently bought a '76 Super Cub and have the Atlee HD muffler. I discovered an exhaust leak and the muffler looks like its toast. It has a major hole/leak near the left end and under the shroud, by the duct going to carb heat. The shroud is buckled/separated a little with a small crack probably from the direct exhaust heat exposure. My question is whether the shroud is reusable if we can work it back into shape? If not, I may order the Hot Rod combo with new shroud. Help me spend my $$$. Photo of shroud added.
Russ
