Results 1 to 19 of 19
Thread: Muffler replacement, reuse shroud?
    Dec 2014
    Austin, TX
    8
    I recently bought a '76 Super Cub and have the Atlee HD muffler. I discovered an exhaust leak and the muffler looks like its toast. It has a major hole/leak near the left end and under the shroud, by the duct going to carb heat. The shroud is buckled/separated a little with a small crack probably from the direct exhaust heat exposure. My question is whether the shroud is reusable if we can work it back into shape? If not, I may order the Hot Rod combo with new shroud. Help me spend my $$$. Photo of shroud added.
    Russ
    9,127
    sutton exhaust...
    Aviator's Avatar
    Jun 2002
    Canada (Legally)
    1,398
    Could you post a few pics? A muffler should not burn through (hole) with normal use unless the material or the workmanship was substandard to start with. A crack maybe.
    Sep 2013
    Nor Cal
    167
    I vote Sutton also!
    18,974
    The aluminum is soft and can probably be reformed, patched or welded.
    10,580
    Quote Originally Posted by Aviator View Post
    BS.... thats why you need to inspect them often, they DO fail in many ways....
    Aviator's Avatar
    Jun 2002
    Canada (Legally)
    1,398
    If someone came out with a SS shroud STC, I'd buy it. It just might buy you enough time to find a good place to put her down before the fan stops - or worse – after a muffler rupture.
    Less than 30Hrs. on new muffler:
    beaver18's Avatar
    Quebec Canada
    180
    Sutton for me ,great heat and S/S shroud
    18,974
    30 hrs? How many years? Looks old and rusty and had a severe backfire. Huge difference in an original muffler and the materials they use today.
    9,555
    Don't know about Canada, but here I would just make one out of s/s and call it a minor alteration. Most shrouds are stainless anyway.
    moneyburner's Avatar
    Mar 2003
    Western Washington
    961
    I'm curious about the failure modes here. Was there a backfire? Extreme EGT? I wouldn't imagine the shroud could handle bare exhaust - it would simply melt if the power setting is high enough, right? My thinking is that it would not be worth repairing.
    Quidquid Latine dictum sit, altum videtur
    1,761
    I have the hot rod muffler, makes the cub sound like a Harley. Might have helped takeoff RPM a bit did help CHT at full throttle. It is loud.
    Aviator's Avatar
    Jun 2002
    Canada (Legally)
    1,398
    Aviator's Avatar
    Jun 2002
    Canada (Legally)
    1,398
    Sorry, Mr. Pierce and moneyburner, I don't know how old it was. No backfire reported in the info I got. Have a few more pics of the damage, but I'll have to look for them on my archives drive (if needed).
    18,974
    Sorry but I have inspected a lot of mufflers and that looks like it has way more than 30 hours onnit. Calan Der time has an effect as well.
    irishfield's Avatar
    2,957
    That was definitely "blown" away, it didn't melt.
    10,580
    I agree... way more than 30 hours... or some BAD running engine....... misaligned stacks??
    Aviator's Avatar
    Jun 2002
    Canada (Legally)
    1,398
    I'm not doubting your expertise and experience with these cans. This info is 12 years old but I can't tell you when the event took place.
    Dec 2014
    Austin, TX
    8
    Wow, shows you how bad it could have been. Mine burned up the scat duct and blasted a sleeved fuel fuel line with heat but no other apparent damage. The burning smell of the exhaust, particularly on takeoff was very noticeable. I am going to try and have the shroud repaired and spot welded. New muffler on the way. thanks for the input.
    Russ
  1. PA-11 Oil Temp Capillary Air Shroud?
    By DavePA11 in forum Cafe Supercub
    Last Post: 07-21-2013, 07:42 AM
  2. Muffler Shroud
    By btracy in forum Cafe Supercub
    Last Post: 06-30-2007, 11:00 PM
