Results 1 to 19 of 19
Thread: Ron Building Javron Cub 1
    Aug 2008
    79
    Started May 2012 building two turners for both wings.
ID:	18437   Click image for larger version.
ID:	18438   Click image for larger version.
ID:	18439   Click image for larger version.
ID:	18440   Click image for larger version.
ID:	18442   Click image for larger version.
ID:	18443   Click image for larger version.
ID:	18444   Click image for larger version.
ID:	18445   Click image for larger version.
    Aug 2008
    79
    Four more pictures of Ron's Javron Cub
ID:	18447Click image for larger version.
ID:	18448Click image for larger version.
    Bill Rusk's Avatar
    5,336
    Fantastic. Thanks for posting Ron. I hope to see it in person someday.
    Looks GREAT!!!
    Very Blessed.
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    15,106
    Looks great, Ron! I moved this thread to the Members Projects in Progress area.
    Jun 2002
    NC
    402
    That looks good, Ron. I'd like a larger space to work in like yours. As I recall, you've not had that project too long, have you?
    Meanwhile,...
    5,250
    Love the yellow, looks great!
    Crash's Avatar
    Apr 2002
    Nikiski Alaska
    2,695
    Impressed! Looks like you're doing a great job.
    Crash
    Aug 2008
    79
    Thanks Bill Id like to compare notes with you on your motor mount and your air box asIe you know your motor mount and mine are the same and I,m working with Jay on my air box as I don't like it pointing down in the front.Ieither want it straight or running up and carb heat inlet dosn't satisfy me/ thanks aging your project is outsanding Ron
    Aug 2008
    79
    Thanks Bill Id like to compare notes with you on your motor mount and your air box asIe you know your motor mount and mine are the same and I,m working with Jay on my air box as I don't like it pointing down in the front.Ieither want it straight or running up and carb heat inlet dosn't satisfy me/ thanks aging your project is outstanding Ron
    Aug 2008
    79
    Jasperfield I started about May 2012 by building two turners,tail feather stand and bar to paint the flaps and aileron's on I built both wing at the same time bought the spars for 2300 # load. thanks Ron
    Aug 2008
    79
    Oldcrowe I like the yellow too but I have heard about it too but you can see a oil lea on yellow where you can't on grey or black .thanks Ron
    Aug 2008
    79
    Crash That a real complement coming from you.Thank you very much
    Aug 2008
    79
    Update on project:
    PTT on stick and toggle trim switch on top.
ID:	19401 Click image for larger version.
ID:	19402 Click image for larger version.
    Route for PTT on side of throttle.......................................... .....................................installed
    Struts primed.
    Fiberglass window strip...superior to original.
    Jun 2002
    NC
    402
    Thanks for keepin' us up to date. You'll like the PTT on the throttle. That looks like one of B&C's push buttons.
    Tell us about the window strip.
    Aug 2008
    79
    Hi all I posted the PTT so others could see what my PTT looked like. The window strip has bin a real pain on this airplane because the AL stripes I got fit very poor and trying fit than made for a bad day . So I got in touch with a good CUB builder Tim James and he gave us a guide on the material and the way to go about it and my friend Chris Tatro did it and I helped a little. If you what to do this I can help whit the material list but it takes a little time and I 'm slow.
    Dec 2008
    Madras, Oregon
    4
    Ron Copeland Javron Cub Completed
ID:	20211 Click image for larger version.
Name:	Rons cub 2.JPG
    Special Airworthiness Certificate issued May 15 after 3years 7 months of solid work. Empty weight 1052# with oil, a
    40# metal prop and 850/600 tires. I intend to replace the 40# prop with a Catto prop.
    I've been flying the airplane for a week...all is fine with the minor exception of #1 & #2 cylinder temps running warm in the 375 degree range. Flies straight, stalls straight.
Name:	Ron w&B data.jpg
    Bill Rusk's Avatar
    5,336
    Ron
    Awesome. Congratulations. That is a great weight too. So far we now have three Javron Cubs done and all three are very light.
    Congratulations. I can't wait to see it.
    Very Blessed.
    Jun 2002
    NC
    402
    Finishing what you begin is a big deal, and you've endured to the end. Congratulations to you.
    Please give us updates about your test flights and also tell us what you'd do differently if you were to build another airplane.
    Jasperfield
    10,335
    [QUOTE=Philair;630221]...all is fine with the minor exception of #1 & #2 cylinder temps running warm in the 375 degree range. Flies straight, stalls straight.[QUOTE]
    Congratulations that is great. There is nothing too warm about those temperatures. 375 is good.
  1. Building a Javron Cub
    By Bill Rusk in forum Member Projects in Progress
    Last Post: 08-18-2020, 10:06 AM
  2. Jasperfield's Javron
    By Jasperfield in forum Member Projects in Progress
    Last Post: 06-18-2015, 03:49 PM
  3. Who is building a Javron Cub?
    By Jasperfield in forum Experimental Cubs
    Last Post: 12-18-2014, 10:43 PM
  4. INDEX To Building a Javron Cub Thread
    By Bill Rusk in forum Cafe Supercub
    Last Post: 10-27-2014, 08:31 PM
  5. Building some new Hangars at 3w5 anyone have a Washington State Building Engineer License?
    By photosfromabove in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 09-23-2014, 08:37 AM
