I am probably just about the last person on this site to install a set of VG's on my Super Cub, but I learned a couple of things during the installation that I would like to share. First of all, I was extremely impressed with the quality of the VG kit. It contained just about everything needed to install the VG's. It is a high quality kit.
The first thing I learned was that the templates are quite floppy and stretchy when they are pulled off of the backing sheet. The floppiness makes it difficult to get the template into position without a few wrinkles and some minor re-positioning to get things right. I found that if you placed a strip of wide masking tape across the template it was much easier to get into position without wrinkles on the first try, and it saved a lot of time.
The second thing I discovered was that when the activator was sprayed on, a lot of overspray went onto the fabric. To eliminate this I ran a wide strip of masking tape along both sides of the template before applying the activator. This eliminated the cleanup of activator on the fabric.
The next thing I discovered is "The bigger the glob, the better the job" does not apply to the adhesive application! Excess adhesive that squeezes out around the VG only makes a bigger mess to clean up. Also, the stick end of the clean up swabs works very well to spread the adhesive evenly on the bottom of the VG.
The final thing I would suggest is to apply 6 VG's and remove the templates from the first 4. Add 4 more VG's and remove the template from 4. This allows the glue to set adequately to hold the VG's in place, but still allows the templates to be removed easily.
Now, if my head cold will go away and the skies clear up, I can go see how well they work!
