I see a lot of stuff done incorrectly for what ever reason and thought it might be an informative thread to see what kinds of things people find so that others won't make the same mistakes.
This is an oil pressure line run from the right side of the firewall to the engine. Great idea, shorter run etc. however you now have to disconnect it when you swing the engine for normal maintenance. It is also in the way of getting the engine mount bolt back in.
