BENEFACTOR
Anybody have any experience with a front mounted oil cooler and a Sutton exhaust? I have a new LyCon 160 hp O-320, new baffles, Sutton exhaust, new aluminum Cub cooler etc. that is heat up the oil to 245 degrees in 30 minutes with an OAT of 87 degrees. Removed the filter adapter and vernatherm and installed screen and viscosity valve. Duct taped around the cooler so no air goes around it to no avail. LyCons questions how close the cooler is to the muffler and being that all my experience that I can remember with the Sutton exhaust has been with a rear mounted cooler I wondered if anyone is running this combination and have had any issues. Kinda grasping at straws at this point, next step is to install a stock exhaust system and see what that does.
