Results 1 to 22 of 22
Thread: Trouble behind the gearbox
    Splatterpuss's Avatar
    Oct 2011
    27
    These are pictures of a 182TW. The owner says the cracks have been present for decades and are no problem, but they look like trouble to me. Can the experts here weigh in?
    Thank you,
    Splat
ID:	15564   Click image for larger version.
    Cub junkie's Avatar
    My Moms basement
    2,116
    An I/A has been letting that go for years?
    Oct 2011
    27
    Looking at the books, it seems so, yes.
    11,364
    never mind... I thought you meant original 182 trike .....you best look at the outer shoes for cracks too!! they (182 original) ARE $4700.00 EACH!!!!! I was shocked when I heard that last week!!
    ya cracks = bad... will need to add a doubler and probably a stringer(look at a 185 for example of what to do)... not earth shattering but some work....
    irishfield's Avatar
    2,987
    Is the aluminum actually cracked or just the **** paintjob... looking at the belly someone forgot to clean and prep!
    Oct 2011
    27
    It's hard to tell, but the aluminum is definitely creased.
    Aviator's Avatar
    Jun 2002
    Canada (Legally)
    1,398
    Wrinkles down are usually telltale signs of hard landings (don't ask me how I know). I'd inspect the gearbox real carefully and if OK not worry about the creases - if that's what they are.
    10,490
    I have seen paint cracks like that on Cessnas and after inspecting found that it was only the paint. I agree that it does look like an aluminum crack. Clean it chemically and look inside. Slide your finger nail across it to see if it catches. If there is no crack, forget about it. It likely will not change for years.
    Jan 2012
    1,789
    If you trust an internet forum more than your mechanic I'd say you need to find a new mechanic.
    If that area has been seeing paint failure for decades it's way past time to touch up the paint.
    11,364
    I have seen one 170 with cracks there in those wrinkles.......... they just added a doubler
    Sep 2006
    corvallis,or
    422
    Asking questions on an aviation forum is using all available information. There are experts on here I would trust over any local mechanics, IA's or even the factory.
    If you spend enough time here, its easy to pick out the people you want to take advice from and the naysayers on this sight.
    11,364
    and when you go to make the doubler, use a larger piece of aluminum and roll it to shape BEFORE cutting it to size since you need the same amount extra metal on sides to engage your rollers..
    9,301
    Are those draw (cherry) rivets just to the left of the cracks, under the strut?
    Worth spending a little more time checking...
    11,364
    no, screws. Hmmmmmmmm
    10,490
    Yup! Hmmmmmmmmmmmmmmm. I didn't notice those before. Good catch, that opens up another whole point of inspection and inquiry.
    gbflyer's Avatar
    Feb 2007
    PAGS
    740
    Seems reasonable that a crack in the aluminum would have kept going. Definitely investigate the possibility that its paint. Can't remember ever seeing screws there either, maybe something to do with the conversion? I do know that gearbox issues can get $$$$$ quick. We wholesaled a decent old 180 one time because of it. I think it turned out OK for the guy, but you never know until you open it up.
    9,301
    I had not expanded the picture. Screws just don't seem right.
    Jul 2010
    Elizabeth, WV
    583
    I took them to be machine screws with washers and stop nuts on the inside. jrh
    White City, Oregon
    921
    Blew up the picture and those are structural machine screws... They have the flanged head that makes it look like a washer is built into them.... I would remove one and check that the shoulder is the right length... Otherwise, they are perfectly legit to install there.
    Brian.
    10,490
    Quote Originally Posted by Steve's Aircraft (Brian) View Post
    Blew up the picture and those are structural machine screws... The have the flanged head that makes it look like a washer is built into them.... I would remove one and check that the shoulder is the right length... Otherwise, they are perfectly legit to install there.
    Brian.
    You're right, perfectly legit. But why are they there in the first place? Cessna didn't put them there. It's the "why?", that has my attention.
    White City, Oregon
    921
    From the very first post this is a 182 converted to a tail wheel... The screws were used probably because it is difficult to get a bucking bar in there to drive a rivet... I have installed more than one structural screw because of that reason.
    As for the wrinkles and cracks... As Mike says, install a doubler plate there... I have seen that same thing on 170's with 180 gear legs and a doubler plate is a good solution. Go look at a 185 and copy the shape of the factory plate and install...
    Brian..
    Oct 2011
    27
    Thank all of you for your replies. I walked away from this airplane because there were just too many questions about the airframe. No mechanic can know everything or be everywhere. The expertise on this site is astounding. I always learn when I visit the site, and I'm grateful for the help.
    Splat
  1. T for Trouble
    By sierra bravo in forum Cafe Supercub
    Last Post: 01-26-2013, 11:04 AM
  2. generator trouble
    By wacodriver in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 03-21-2009, 08:13 PM
  3. Trouble getting an order
    By ddh in forum Member to Member
    Last Post: 02-14-2007, 12:07 AM
