SteveE
SPONSOR
Jenks, OK
Seems Tim's hanger is starting to take after Tim's other appendages according to his few friends from the North East....and is sagging in the middle..
Well, OkieEngineering Inc. has come up with fix for Tim's sagging hanger... a well designed fix that even the very weary can put together like their last erector set. Most of the cheap steel supplies came from Tim's junkpile, while the crane portion came from Harbor Freight. We pulled it a little tight, in case it settles, so be careful with the button on the lift, its a bit touchy. Click on the pic and you can see more detail in the engineering.
