Results 1 to 5 of 5
Thread: o 235 c1 prop
    don
    698
    o 235 c1 prop
    I have an o 235 c1 with a two position prop control valve. what adjustable pitch propeller was intended for these engines???
    meinster's Avatar
    Jun 2013
    Hawaii
    55
    Well according to the TCDS
    http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/0a059b37ac25df6786257b63006b66b9/$FILE/E-223_Rev_21.pdf
    It has an SAE type 2 integral flange, looks like the two position option was available on different (later) models, but that might narrow the search of what type of props could have been used.
    Sorry for not really helping you at all.
    9,287
    Propeller - Sensenich, two-position controllable, hubs C-2FM-3, C-2FM-4, or C-2FM-5 with PC-276A6 blades.
    This prop has wood blades and an AD note which requires (I believe) annual inspections by a prop shop. Basically they have been AD'd out of service.
    They were approved on the PA-12.
    don
    698
    Thanks guys I knew there be somebody out thsomething'snew something.
    9,287
    A thought, if you are experimental, it may be possible to operate certain compatible constant speed props on this engine. The prop will only travel to the stops in each direction and will move slowly. This obviously would require some research to find the correct prop.
  1. Cruise Prop vs. Climb Prop
    By j3jm in forum Cafe Supercub
    Last Post: 04-24-2019, 01:50 PM
  2. Correct prop torque for McCauley prop
    By OVEREASYGUY in forum Super Cub Sick Bay
    Last Post: 03-07-2006, 03:35 PM
  3. Cruise prop vs. climp prop
    By aktailwheel in forum Tips and Tricks
    Last Post: 06-22-2004, 11:06 AM
