What is everyone using for sealant on fuel fittings? For example, the 90 degree fittings on the header tanks? 90 degree fittings on the stock fuel gauges?
Fuel lube. Oldy but goody. Use sparingly on anything that carries fuel. It has an added advantage in that it takes less torque to tighten fittings and makes disassembly easier.
