Results 1 to 17 of 17
Thread: J-3 Cub Service Manual
    DesperadoPilot's Avatar
    Jan 2009
    Brazoria, Texas
    412
    Ran across this online, a 1941 Service Manual for a J-3 Cub, thought I would pass it along to those who may not have one.
    http://www.eaglesport.org/documents/cub_service_manual.pdf
    A j-3 Cub Parts Manual:
    http://www.eaglesport.org/documents/...rts_manual.pdf
    Also a 1946 J-3 Cub Owners Manual.
    http://www.eaglesport.org/documents/...nual_piper.pdf
    More stuff where this came from at this link:
    http://www.eaglesport.org/cub_links.php
    I fly IFR (I Follow Roads).
    Ruffair's Avatar
    Jan 2008
    Lower Chena
    1,254
    Thanks 4 posting this.
    kem
    Darrel Starr's Avatar
    Plymouth, MN
    2,524
    Thanks, I just copied them for a friend who has a J-3C 65.
    Lisa Martin LMartin's Avatar
    Jan 2012
    Coeur d'Alene, ID
    133
    Thank you! I have a J3 w/ O-200A in the hanger of the house I'm renting and I am working on annual inspection squawks. Two questions:
    1. Should there be inner cylinder baffles? There are none.
    2. It needs a new propeller. The owner is asking if he can use the 1A100 MCM6950 off his C150. Does anyone have a field approval for this model? Even so, does the pitch make it pretty useless? He bought "big" 26" ABW tires because he wants to go backcountry with it (in North Idaho).
    Grant's Avatar
    At Work.....
    2,001
    Quote Originally Posted by LMartin View Post
    I keep telling him to go with the prop listed on the STC. He won't listen to me, because he wants to save money. Sad truth about aviation, small mistakes sometimes cost a lot of money. We all need to be prepared to trot out our checkbooks. I'm getting tired of being an A&P
    1. Should there be inner cylinder baffles? There are none. - No
    2. The owner is asking if he can use the 1A100 MCM6950 off his C150 - It would not make a good prop for his intentions even if it was approved. There are much better props....The best ones are not approved. I personally think for a C-90/O-200 that the best prop is the Sensenich 76AK-2 40.... If you want it to pull hard and go slow. Installation on a J3 is not approved, but it is approved for the engine... Go figure.
    I'm getting tired of being an A&P...... I get it....
    Likes Brandsman, BC12D-4-85 liked this post
    Nov 2007
    NW Mn
    81
    Grant, thanks for posting this info. I have a J3C-65 with a C 90
    Mike Syverson
    3,692
    TCDS 1P2 approves the 76AK-2-40 for the A65-C90. I've had mine on a PA-11-90 and Taylorcraft C-85 Stroker (via Field Approval/C90 equivalent) and it does pull well on skis and floats. Has a wider blade chord than the Sen CK series I believe.
    Upper Peninsula of Michigan
    809
    I have that 76AK-2-40 on my C90 Taylorcraft…in full agreement. It’s the prop for that set up
    11,263
    Side by side the Mac 1B90 7440 pulls a little harder
    Likes LMartin liked this post
    3,692
    ^^^^Yes. Dominion Propeller in Anchorage told me the same thing. Some better.
    Even better> https://www.sensenich.com/shop/aircr...tol-propeller/
    21,958
    Lisa, pick your customers. Some will cost you money. Lots of askholes out there. I have learned a lot about vetting who I work for over the years.
    Jan 2012
    Coeur d'Alene, ID
    133
    Quote Originally Posted by Grant View Post
    I was nosy…Fleming Field KSGS? I spent a month or two there this spring working with Jeff Hauck for Dauntless. In fact, I go to Fairbanks tomorrow and finish the BLM contract with Jeff. Thanks for the help.
    Jan 2012
    Coeur d'Alene, ID
    133
    Thanks. This was supposed to be quick because it hasn’t flown. Maybe the last several annuals were quick. My Cubs have a back plate under the brakes. This one doesn’t. Is it an option? The floorboard is breaking out around the brake.
    21,958
    It is in the parts manual and the drawings.
    Well, maybe not on the J3.
    Grant's Avatar
    At Work.....
    2,001
    Yep - Thats me. Jeff is good people. Super talented. Let me know if you are ever back in town. Plenty of fun flying around here. Are you flying for Dauntless or bending wrenches?
    Jan 2012
    Coeur d'Alene, ID
    133
    I fly chase planes to wrenches.
    Jan 2012
    Coeur d'Alene, ID
    133
    Does anyone have a field approval for a McCauley 1B90/CM on a J3C-65 with a Univair STC’d O-200A? My FSDO is telling me I need a previous field approval as evidence for getting this field approved. 🤷*♀️
  1. J3 Service Manual
    By SKJ in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 07-03-2013, 09:58 PM
  2. PA-18 Service Manual
    By Jim Miller in forum Cafe Supercub
    Last Post: 03-24-2005, 09:46 AM
  3. PA-12 Service Manual
    Last Post: 11-22-2003, 10:51 PM
