BENEFACTOR
Have a Super Cub with a balanced LyCon 160 O-320 that has cracked two Niagra 20003A oil coolers in the last 400 hours. The airplane has a Sutton exhaust with the rear oil cooler mounting. The crack is adjacent to the bottom oil line fitting where the first two baffles solder together. Talked to Niagra Air Parts and they say there is no epidemic and it is probably strain on the fitting from the hose. The hose is pretty flexible with no obvious bind on it. Just curious if anyone else has had an issue?
