Results 1 to 18 of 18
Thread: 150 HP Vs 160 HP
    KALB
    70
    Post 150 HP Vs 160 HP
    Does anyone know what the process would be to convert the 0320 from 150 HP to 160 HP? Is there an STC?
    S
    Aug 2002
    Talkeetna Alaska
    258
    On your mag thread you said your engine is a 0-320-B2B. That is a 160 HP, usually converted from a A2B. Check your log books.
    MN_flyer1's Avatar
    Jan 2012
    Hutchinson, MN
    99
    I think (and others would know) that this is done IAW the Lycoming parts manual and OH manual. If your engine has all the correct part #'s to make it a 160 then it is a 160. I believe the narrow deck required new case studs, hold down plates, pistons, and some possible changes to the front crank journal area.
    KALB
    70
    Quote Originally Posted by MN_flyer1 View Post
    Yes, I made a mistake it is 0-320-A2B, so It would need to be converted....
    Meanwhile,...
    5,004
    EASY. Did mine a couple of years ago. Needed to be topped anyway so just all new cylinder assemblies and about 6 hours AE time and presto-chango... Log book entry for the engine but since there is great debate related to needing an STC I went the safe way and bought the Cub Crafters STC for the Air Frame.
    Nov 2012
    Lake Lanier, GA
    1,069
    I just did it and here is what I did. Others have other thoughts about how to do it legally but I am very conservative with my paperwork, because the FAA looks at my airplane every once in while because I do charity airlifts under 91.146. So here goes.
    You need an STC to convert the engine. I purchased the Ly-Con STC. It is about 250 dollars. It comes with a data plate that you place under the Lycoming data plate and it allows you to strike through the data on the Lycoming plate and replace it with B2B data. The Ly-Con STC requires your engine to be a wide deck. The STC will specify the parts change out.
    You also need an STC to hang the engine on the airframe. You have a number of choices, I used Cub Crafters STC. Crosswinds also has one, both are good in my opinion.
    If you are using a stock 74 Sensenich prop I found the 56 absorbs the power just fine.
    Hope this helps
    Cubonaut875 SchulerJL's Avatar
    Aug 2009
    Peoria, Illinois
    576
    Is the carb, exhaust stacks, starter, alternator etc. and everything else the same, just cylinder change? if you have a wide deck A2B
    Jerry Burr's Avatar
    Sedro Woolley, Washington.
    700
    Hi GeeBee. Did you use the 150 hp magneto timing after it was a 160 ? thanks. Jerry B.
    jrussl's Avatar
    Jul 2005
    Madison, WI
    487
    Quote Originally Posted by Jerry Burr View Post
    I am curious as to the difference in the timing?..........................
    Nov 2012
    Lake Lanier, GA
    1,069
    I am not an A&P however, both A and B series are 25BTDC according to the Lycoming Operator's Manual
    Sep 2012
    Bettles AK & Arizona
    289
    If you have a metal prop, I would make sure that the Prop TCDS allows that engine as there are sometimes unique harmonics that can tear a metal prop apart if it isn't tested for that engine.
    Darrel Starr's Avatar
    Plymouth, MN
    2,524
    16-bravo's Avatar
    Feb 2007
    wasilla, ak
    417
    You dont have to change cylinders....just pistons.
    Plymouth, MN
    2,524
    I believe the 160hp cylinders are choked differently than the 150hp ones. Would be worth checking with an engine shop, Lycoming or Superior.
    Also, in order to install a 160hp engine on a Super Cub, you will need an STC, Cubcrafters sells one. This is a different issue than just converting the engine.
    shouldhunt's Avatar
    Sep 2006
    Chugiak, Ak
    74
    Dont forget your crank have to meet SB 505
    Cub Builder's Avatar
    Mar 2011
    North Central AR
    649
    I converted an 0320-E2G (wide deck) from 150 to 160 hp for my SC clone. STC paperwork not withstanding, here's what I found in my parts research.
    The cylinders are different in that the 160 hp cylinder is indeed choked differently. However, you often times find 160 HP pistons running in the 150 cylinders and it doesn't seem to be an issue. On a narrow deck engine you need to add the banana plates to the cylinder bases. I have also heard the cylinder hold down studs called into question, but don't have any specific knowledge on that subject. Some of the early narrow deck cylinders were not nitrided. Don't use them for a 160 hp conversion.
    The pistons are obviously different. (higher compression and wider ring grooves)
    The rings are different. (to fit the wider ring grooves in the piston)
    The wrist pins are different. Same dimensions, but thicker wall on the 160 hp version.
    To the best of my memory, everything else was the same, including the ignition timing.
    -CubBuilder
    KALB
    70
    Quote Originally Posted by shouldhunt View Post
    Engine was overhauled in 05 by lycoming and checked.
    S
    Plymouth, MN
    2,524
    Good point, the crank must pass SB 505B: http://www.eci.aero/pdf/97-3.pdf
    Remove the button plug inside the flange and clean up the inside diameter. It must be corrosion free at 1.92 inches diameter to qualify for 160hp.
