Page 1 of 2 12 LastLast
Results 1 to 40 of 44
Thread: PA18-105 special.
    Jun 2013
    1
    PA18-105 special.
    Does any one know did the 105 special have original equipment that included electrics?
    Speedo's Avatar
    Jul 2002
    TN
    1,839
    Could you find that info on the Type Certificate?
    Speedo
    cruiser's Avatar
    May 2002
    South Glens Falls, NY
    1,492
    Yes, it was an option. My airplane was a PA-18 until the early '70's when a new owner put "PA-18-105" on a registration application. OK City liked it so much they went all the way with "PA-18-105 Special". I don't like it much but the airplane does not seem to mind. Jim
    Feb 2006
    N. california
    132
    Quote Originally Posted by cruiser View Post
    I think it might be "special" ,with a light weight starter, and alternator. Cause light is right!
    SJ's Avatar
    Jan 2002
    Northwest Arkansas
    15,909
    105 Special was a CAP trainer. I had one, many had toe brakes ("tango cubs" with T at the end of their N numbers), parachute front seat height, and electrics in all that I have seen.
    sj
    Mar 2004
    Newnan, GA
    18
    Steve is right, I have N227T. Originally it had a battery, starter, generator, and navigation lights when we got it from the CAP at the St. Joseph, Mo. airport in 1969. The type certificate data sheet says that the 105SP is the same as a PA-18 regarding required equipment (main gear, tailwheel, engine, propeller) except for note 3 which describes a revised battery installation along with the toe brakes, parachute seats, etc. Interesting reading if you own one, but doesn't answer your question.
    Don
    Bill Ingerson's Avatar
    Jan 2004
    Snohomish Washington
    1,433
    I have 279T and it came with lights, no flaps, toe brakes, Used by CAP and never left California. The back seat had a set up for a Parachute.
    Jan 2012
    5
    I have 247t but a it was wrecked in the 70s and has a different fuselage but the cap did own it.
    Cheater1239's Avatar
    Sep 2013
    4
    I am the new owner of 323T .now in WA, from GA
    22,075
    This one?
    Sep 2013
    4
    This one?
    Thanks for the radio loan, it was sent back a couple weeks ago, I trust it arrived? Turns out it was the connector in the tray had backed way out
    22,075
    Yes, I did receive it. Glad I could help. Glad to her it was an easy fix. Have fun with the new bird.
    Sep 2006
    corvallis,or
    423
    Steve, your a class act. I've never met you but it seams all you do is help people out.
    I'm glad you received the money for your tail wheel and you still trust people by loaning things out.
    If your ever in the Pacific Northwest let us know early so we can meet.
    thanks for all your knowledge too.
    eric dapp
    KCVO
    Jan 2013
    3
    I have the same problem, my Dad's plane. It is SN 101 and the paperwork was changed to "PA-18-105 Special" about 20 years ago during recover and overhaul. She was built during the first few months of 1950 and has been a Montana ranch plane ever since. I will eventually end up owning it. It is pretty much in original configuration from factory except for 8:50 x 6 tires and second wing tank added. No electrical, heel brakes, 0-235-C1, 13 rib wings. Super light, great fun to fly. Same as you I don't like it much listed as "Special" but the airplane seems to not mind. I would like to correct the paperwork back to PA-18 nuthin when I buy it in the next few years. Not sure how much of a hassle it will be. I understand this is not an uncommon error. Anybody have any advice on how best to handle it?
    cruiser's Avatar
    May 2002
    1,492
    When ownership of the airplane changes you might try a registration application showing PA-18 (only). When that does not work enlisting the help of your local FSDO would be your next move, IMO. I e-mailed, called and faxed OK City explaining when the mistake was made, no joy. After a conformity inspection by my local FSDO he contacted OK City by letter and they refused to correct it. I give up, good luck. Jim
    Jan 2013
    3
    Ok good to know what to expect, maybe I'll have better luck that way.
    Thanks.
    112
    105 pa 18 special
    steve, i had a tango cub too. they also call them "light frames" but then you beef up the tail and add this and that and they weigh about the same as most.
    i had heard they were air force trainers, but you say canandian air force? myne had toe brakes, which i thought i would like becuase i cut my teath on a cessna, but those special toe brakes were pretty special if you know what i mean. at any rate its the one i always say i should have kept. it had weld on float fittings, 160hp, borer prop, and vg's. it really wanted to fly. throttle ahead and the thing was about in the air. not quite a carbon cub but not very far behind. and i learned what the saying "climbs like a home sick angel" meant when i flew that plane. wish i still had it. even though you have to put your right foot behind your left ear to get in it. thats why i am looking at a 12. but the standard door is not ingress egress freindly for the front seater.
    sj
    aeroergosum's Avatar
    Mar 2014
    North Granby, CT
    17
    Quote Originally Posted by bladeflyer View Post
    I own SN102, also registered as "Special" though I don't think it is. March 17, 1950 model, N# ends with Kilo, 0-235-C1, flaps, nav lights, starter, generator, battery, heel brakes, horn-balanced elevators. Put on EDO 1400 floats in July 1950, second fuel tank installed in 1956.
    Likes D.A. liked this post
    7,967
    You guys sure the feds didn’t just correct the paperwork back to its original status? Aren’t all of the Tango cubs 115 Special?
    Bearhawk Builder's Avatar
    Aug 2012
    In the woods
    902
    What’s the data tag say? Seems that’s the one that really counts. Don’t we all think our Cubs are special.
    S2D's Avatar
    May 2002
    Montana
    4,277
    They arent Tango cubs. Most of the '50 cubs were Kilo cubs.
    3,941
    This is the data plate on N323T, which a friend of mine owns.
    PA-18-105-SP.
Name:	tango cub data plate.jpg
    Mar 2014
    North Granby, CT
    17
    Quote Originally Posted by aeroergosum View Post
    Though I don't know what parachute seat looks like but the one that is installed is uncomfortable after a few hours. It's only a thin padded covering. Flew from 4B9 near Hartford, CT to Medina OH, 6:41 non-stop once.
    Jan 2013
    Hudson, MA
    105
    Bladeflyer, by any chance does your tail number end in "K" (N####K) similar to what Aeroergosum describes? I think these were sometimes described as "cub specials", but, from what I understand, in 1950, the flaps and O-235 were optional equipment. The plane my Dad owns is a 1950 "Kilo" cub. It now has an O-320, 2nd tank and full electric. Though I never flew it in its original configuration, I heard it was awesome-- with a light load it was a better STOL performer than after the mods and in the air it just handled really nice.
    cruiser's Avatar
    May 2002
    1,492
    The 1950 airplanes, registrations ending in a K are PA-18’s. Some got changed to PA-18-105’s or PA-18-105 Specials because, in my opinion, various owners filled out a registration application mistakenly using those model numbers. The FAA liked it and changed the model number. I went thru my local FSDO to try to correct mine at OK City, no joy. My data plate is stamped PA-18. My registration says PA-18-105 since the mid ‘70’s
ID:	52414   Click image for larger version.
ID:	52415   Click image for larger version.
    Mar 2014
    North Granby, CT
    17
Name:	1950 W&B0001.jpg
ID:	52424Click image for larger version.
Name:	1950 W&B0002.jpg
ID:	52423Click image for larger version.
    I'm thinking the Data plate was replaced. It is located at the upper left trim panel. Airplane Flight Manual and W&B note the aircraft as a PA-18 (Commercial). This 18 began service with Central Maine Flying Service, Old Town, Maine on 4/11/1950.
    Nov 2002
    Fargo
    840
    Nope that’s an original early supercub plate
    Thanks aeroergosum, WWhunter thanked for this post
    D.A.'s Avatar
    Free America
    718
    I own SN102..."Special"...0-235-C1...Put on EDO 1400 floats...
    Just curious, how did it do on 1400's with the O-235? I just got a "Special" with an O-235 also. I'm hoping to put it on a serious diet and hoping it will make a reasonable single place floatplane?
    12,382
    From TC 1A2:
    Maximum Weight 1474 lb. with Item 209(a)(See Item 209(b) for 1760 lb.)
    209. Two Floats
    (a) Edo Model 92-1400 floats...
    (b) Edo 89-2000 floats...
    The 1400 floats are approved and legal. However, notice the maximum allowed gross weight is limited for a good reason. There is a limited amount of floatation. In other words, it is under floated. An under floated seaplane is a recipe for trouble in all but perfect wind and water conditions. When you have a choice of minimum or excess floatation and you are looking forward to a safe operation, always choose the larger float. Until you accumulate an amount of seaplane experience, you will not understand. Leave the 1400 floats for the J-3 and PA-11 owners.
    I've flown a PA-18 on 1650s, a float larger than the 1400s. They were too small.
    D.A.'s Avatar
    Free America
    718
    I've flown a PA-18 on 1650s...They were too small.
    Thanks - I was considering those as well.
    12,382
    Quote Originally Posted by D.A. View Post
    For whatever airplane to determine the minimum sized float. Take the maximum gross weight (1760 for a PA-18 X 0.9 = 1584 X 2 (two floats). FAA requires a 100% reserve buoyancy. So the smallest float for a PA-18 at 1760 pounds would be a pair of 1584s. The nearest float which meets these numbers of which I am aware would be the EDO 1650.
    The maximum weight a pair of floats can legally support would be floatation of one (1650) / 0.9 = 1833 pounds.
    Another example would be a Cessna 172 (2300 lb. landplane gross) on EDO 2000 floats. 2000/0.9 = 2222 (maximum certified gross weight on floats) As you can see, the seaplane gross of the 172 is limited due to the size of the floats. Because of this EDO stretched the 2000 float to 2130. 2130/0.9 = 2366. So the 172 can now utilize it's full landplane gross on floats. That extra 8" in length made a tremendous increase in performance.
    In post #29 I addressed just one issue with undersized floats. Here is another.
    Whatever weight the airplane is on the floats, it will displace an equal amount of water weight. So, any extra floatation will be above the water. When a float is at a minimum size it will be lower in the water than the larger float for the size of the float. Therefor it will require more power to initially accelerate, to push to one side the water, in order to get up on the step where the lower drag allows the plane to accelerate to flying speed. A plane with an "oversized" float will not be as low in the water. Therefor there will be less "solid" water to displace prior to getting on the step. The Cub which I flew on 1650s easily took double the time and distance to get on the step than an identical Cub on 2000s. Once on the step the remaining distance was similar. So in other words, if you can comfortably operate a Cub on 2000s out of a 900 foot pond, you may never get on the step with the 1650s.
    With this in mind, your 125 hp Cub would be happier with bigger floats. The Cub I flew on 1650s had 150 hp. I hesitate to estimate how much further it would have gone with only 125 hp. It certainly would have used a lot more.
    Thanks Bill Rusk, mixer, BC12D-4-85, D.A. thanked for this post
    12,382
    While we are on the subject, here is reason #3.
    The only difference between the EDO 1650 and 2000 floats is 23 3/8" in length. All of which is forward of the step. An additional 8" made them 2130s.
    In rough water, the ability to remain on the step is effected by the length of the forward section of the float in relationship to the distance between the wave tops. Primarily the flat section of the keel between the step and the location where it starts to curve upward to the bow. Also the optimum angle between the keel and the water surface while on the step is approximately 8 degrees.
    With that in mind the 2000 floats can remain on the step with the wave tops being 2 feet further apart than the 1650s. When the waves are too far apart but also higher than just a few inches, on 1650s the plane would climb up one side of the wave and down the other. As you can imagine, if the airplane does not change it's pitch attitude the angle of the bottom of the floats to the water changes considerably depending on the shape of the waves. From minimum drag angle to maximum drag angle and back again. Low power and short floats just can not overcome these obstacles.
    I had a friend with a homebuilt (Acey-Ducy) 100 hp on 1650 floats. He had trouble getting off in rough water because it kept falling off the step between the waves. This because that 8 degrees disappeared between the waves so it had to start over. We solved his issue by making a new longer set of wings to reduce stall speed and added 50 hp to the nose. Now it had the power to jump from wave top to wave top. But it still had a float/wave issue which the engine and wing were more able to overcome.
    Thanks Bill Rusk, BC12D-4-85, D.A. thanked for this post
    Likes mixer liked this post
    jrussl's Avatar
    Jul 2005
    Madison, WI
    775
    Pete,
    Thanks for sharing all your knowledge with us. I very much enjoy learning from your posts.
    Jeff
    Likes cubdriver2 liked this post
    Feb 2021
    22
    Priceless information that is only obtained through years of experience. I’ve learned more from a few paragraphs of Pete’s then I have entire books on the subject.
    Likes Bill Rusk, BC12D-4-85 liked this post
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,617
    I too will chime in. Thank you for sharing all your experience and knowledge. Folks like you are what make this such a great site.
    Thank you Pete
    Very Blessed.
    Likes cubdriver2, BC12D-4-85, TurboBeaver, D.A. liked this post
  36. #36
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,336
    [QUOTE=skywagon8a;829340]For whatever airplane to determine the minimum sized float. Take the maximum gross weight (1760 for a PA-18 X 0.9 = 1584 X 2 (two floats). FAA requires a 100% reserve buoyancy. So the smallest float for a PA-18 at 1760 pounds would be a pair of 1584s. The nearest float which meets these numbers of which I am aware would be the EDO 1650.
    Educate me.. What am I missing? If required reserved buoyancy is 100%, wouldn't each float be required to float the plane at gross? IE, 1750 gross, each float floats 1750?
    "Always looking up"
  37. #37
    12,382
    [QUOTE=skukum12;829350]
    Now your making me look up numbers instead of relying on my old memory. What I've described is the way I was told about the procedure to do the calculations.
    If we take the max gross of the 172 seaplane of 2222 lbs for an example. 2222 lbs X 90% = 1999.8 lbs (size of the float) X 2 floats (100% reserve). CAR 3.370(b). OK, so they rounded up the number by 2 tenths for the EDO 2000.
    CAR 3
    3.370 Buoyancy (main seaplane floats). Main seaplane floats shall have a buoyancy in excess of that required to support the maximum weight of the airplane in fresh water as follows:
    (a) 80% in the case of single .floats,
    (b) 90% in the case of double floats.
    Main seaplane floats for use on airplanes of 2,500 lbs. or more maximum weight shall contain at least 5 watertight compartments of approximately equal volume. Main seaplane floats for use on airplanes of less than 2,500 lbs. maximum weight shall contain at least four such compartments.
    FAR 23
    § 23.2310 Buoyancy for seaplanes and amphibians.
    Airplanes intended for operations on water, must -
    (a) Provide buoyancy of 80 percent in excess of the buoyancy required to support the maximum weight of the airplane in fresh water; and
    (b) Have sufficient margin so the airplane will stay afloat at rest in calm water without capsizing in case of a likely float or hull flooding.
    Likes Bill Rusk, D.A. liked this post
  38. #38
    skukum12's Avatar
    Feb 2004
    The Last Frontier
    1,336
    This is how I read it: The floats should support 190% of the gross. 1.9 x 2222 = 4221.8. I still don't know how 100% reserve pencils out from the equation.
    "Always looking up"
  39. #39
    D.A.'s Avatar
    Free America
    718
    ...your 125 hp Cub...
    Don't I wish. I'd give anything for even an O-290 right now but I only have an O-235 - Bummer. But like I've said, I'm just hoping to lighten this Cub enough to make a reasonable single place floatplane.
    ...An under floated seaplane is a recipe for trouble...When you have a choice of minimum or excess floatation and you are looking forward to a safe operation, always choose the larger float. Until you accumulate an amount of seaplane experience, you will not understand…
    Got it! And thank you for that advice.
    ...The Cub which I flew on 1650s easily took double the time and distance to get on the step than an identical Cub on 2000s. Once on the step the remaining distance was similar. So in other words, if you can comfortably operate a Cub on 2000s out of a 900 foot pond, you may never get on the step with the 1650s...
    The smaller lighter floats took double the distance to get on the step, Holy cow - This is good stuff!!!
    Thanks so much for sharing your knowledge.
  40. #40
    12,382
    Don't I wish. I'd give anything for even an O-290 right now but I only have an O-235 .
    Oops, you're right, you did say that. I got carried away with the discussion. With an 0-235, what I've said is even more important.
  1. converting pa18-105 special to 135hp
    By lunchmoney in forum Modifications
    Last Post: 12-28-2005, 09:57 PM
