Darrel Starr
Plymouth, MN
My tail wheel shimmied recently for the first time ( after 265 hrs) so I reread Gilbert Pierce's Essay on the subject. Upon disassembling the tail wheel, I discovered that the two 1/4 inch bolts holding the spring in alignment were bent and the rubber pad distorted ( on reassembly, I eliminated the rubber pad and installed new 1/4 inch bolts). Also the washers under the 7/16 bolt at the front were yielded some -- I know Steve Pierce says to use hard washers; I will get some for the next time I have it apart. Also the tail wheel tire was way out of balance so I installed a new one.
The main problem though was that the tail wheel pivot was at about a 4 degree negative caster angle.
This picture was taken before disassembly right after landing with a shimmy. No one in the plane & about 36 gallons of fuel.
Doctor Randy recently had his tail wheel shimmy & bought a new Bush Wheel spring set which he is very happy with. His airplane with an unknown quantity of fuel (full?, 36 gal) & no one in the plane sets with a 6 to 6.5 degree positive caster angle. Since he is happy with this set up, I aimed to duplicate the angle his plane sets at.
Here is Randy's tail wheel.
So, happily, I have a friend, Don Rosacker, who has a 50 ton press in his hangar. So with another friend, Tim Loth, Don & Tim Re-Arched the springs using a rough drawing I had made as a guide.
Don is the handsome octogenarian on the right. Tim is the much younger dashing guy on the left.
I also have another set of Pawnee springs that Grant recently sold me at Wipaire (they got them from Univair). So we can compare the originals with the re-arched springs.
At the rear edge of the spring, the re-arched set is 1 3/8 lower than the originals. Gilbert said that his ended up 1 1/2 inches lower.
The reassembled tail wheel on N18SY now has a little more arch than I was aiming for. Randy's is 6 to 6.5 degrees positive. Mine now is 7 to 7.5 degrees positive. Gilbert warns that too great an angle will make it hard to steer. I haven't flown it yet.
Our Super Cub, N18SY, after re-arching the Pawnee spring set. It now sets at a 7 to 7.5 degree caster angle; no one in plane and 36 gal fuel.
With Vivian in the back seat (120 lbs) and me in the front seat (210 lbs) and with 36 gals of fuel, the caster angle comes down to about a positive 6 degrees.
I measured these angles by taking a side picture of the assembly as shown then either using the metal panels on the wall of the hangar for reference or a plumb bob to establish a vertical line. Then on the 8x10 photo, I drew the angles, measured the legs, calculated the tangent then looked up the angle for that tangent. Repeatability seemed to be plus or minus 0.5 degrees.
