Page 6 of 7 FirstFirst ... 4567 LastLast
Results 201 to 240 of 246
Thread: New member building a PA18-95
  1. #201
    Bill Rusk's Avatar
    Spokane Felts Field, WA/Poplar Grove, (Chicago) IL
    5,236
    Jim
    You are awesome. Great family, and memories for the boys that will last a lifetime. Well done.
    Very Blessed.
    Thanks Jim A. thanked for this post
  2. #202
    Apr 2013
    Cloquet, MN
    135
    Thanks for the kind words Bill. Cub Junkie, not a phase converter, just an old disconnect. My plan is to run it with a VFD. Pretty cool what you can do with these things nowadays. Might put one on my lathe someday as well. It is single phase so no hurry with it, but the mill isn't and will have to have something. Heavy American steel being powered by Asian gagetry. Yes patience on the balsa model thing. Boy on right got frustrated to the point of tears last year on one he was having trouble with. We had a talk about how important it was to get your butt kicked, come back and eventually win. He did. It is fun to watch this one do stuff with his hands. He's the only lefty we have and he has his own way of doing things.
    Likes marcusofcotton, rmac liked this post
  3. #203
    Apr 2013
    Cloquet, MN
    135
    Learning more the hard way, the battle continues...
    Had high hopes for Saturday, my mechanic and I were confident. Timed the mags, twenty gallons of fresh gas, gallon and a half drained out of the lines via the primer into my john boat gas tank for next spring. Replaced the safety wire for my prop bolts (I ignorantly used .032). Everything checked off the list, ready to see if it would build oil pressure with the starter, bottom plugs out, all plug wires off, prop went round, oil pressure guage coming up. All looks good, ready to briefly light a fire and look for oil leaks.
    Had my mechanic, watch the primer connections for leaks, gave her two pumps. No leaks, full rich, 1/8" of throttle, master on, start...
    Fully expected her to kick first blade over. After 6 and not even a snort, my heart sank. Gas running out of the carb heat box, must have flooded her. We went to lunch, tried again, same results.
    Pulled the rocker cover on number one, slowly brought it up to TDC. Intake valve opening approaching TDC. What the heck?
    Ever do something a year in the past when it was easy, clean, well lit, and so sure you had done the right thing?
    Helen Keller and Ray Charles can see the timing marks on the cam gear and crank idler gears. It is practically nonexistent on the crank gear. Not stamped with an indentation or dot, but a faint grey zero almost like printed on. We searched the crank gear and debated back and forth for an hour on which tooth bore the dull grey letter. In the end my mechanic and I were both confident. That's it, someone has even slightly dressed the tooth down ever so slightly with a bevel to help identify it. NEGATIVE. We are now both confident we were three teeth off.
    So yesterday afternoon I had my first experience pulling an accessory case on a mounted engine. Not much fun, heartbreaking really. Luckily it wasn't a greasy, grimy, gritty mess to start with. I did manage to make about a 1 quart lake of 40 weight mineral oil. Another dingbat move, had 8 qt. in it, should have drained two out through the sump drain before ripping and gouging. I was confident I would be buying two new gaskets and using 1.25 of them. Unbelievably, that was not the case. I'll get to that in the end.
    Mechanic came back this morning to evaluate with it opened up. More head scratching, I can't see that can you? Finally a picture taken from my Spock like Tri-corder phone thingy told the tale. With the flash you could faintly see the letter. Three teeth off. Properly timed, the two of us got the case back on. Lots harder to get everything to mesh with the engine in the horizontal. Torqued up, again this is lots easier in the vertical, well lit and tons of fighting room. Slight film of gasket maker on gaskets curing till tomorrow. Got the mess cleaned up and it didn't appear as though I contaminated the oil that I left in the sump while doing battle. Retiming mags and trying again tomorrow.
    Kudos to this stuff. My mechanic insisted I use it. Never used it before this project, will never try to use what I have used before on mating surfaces for oil again. Loctite and Permatex, (same company now I believe), make an anaerobic gasket sealer/maker. It will not set up like silicone until you squeeze all of the air out of the two surfaces being mated, giving you practically all the time in the world to get things right. If any excess squeezes out of the mating surface, it cleans up like red grease, not gacky silicone. If I would have used a thin film of silicone to hold the gasket in place, I'm sure I'd be waiting for replacement gaskets. Once the joint popped, the accessory case gasket was left in tact, and was easily saved. I couldn't believe it. Again, not an expert, obviously. Consult your mechanic.
    In good spirits again. Looking forward to tomorrow.
    Jim
  4. #204
    TurboBeaver's Avatar
    Jun 2009
    Northern Maine
    703
    Boy this thing is fighting you tooth n nail all the way.......
    You certainly have great determination and patients to no end. Wishing you the very best of luck with your
    project Jim.
    E
  5. #205
    Apr 2013
    Cloquet, MN
    135
    Thanks. I'm confident it's gonna happen, if it was easy I'd probably lose interest anyway. It'll be worth it soon.
  6. #206
    Apr 2013
    Cloquet, MN
    135
    I'm flying again
    At 7pm she started like I flew it yesterday. Amazing what happens when the engine is timed properly. Tonight was what I fully expected last Saturday, prop came around not quite twice and she was running.
    Mechanic and I ran her for 1 minute at 1,000 RPM, tested both mags, all was as expected and shut her back down. No oil leaks, oil pressure in the green.
    Unbelievably smooth and even. Nothing like my tired old engine and mounts.
    One more night in the hangar without the cowling on to observe for stray drips, then cowl it up and fly.
    Mechanic and I will go together for the break in.
    I'm one happy and excited dude.
    Jim
    Likes Sam D, Bill Rusk liked this post
  7. #207
    Apr 2013
    Cloquet, MN
    135
    Uneventful, just like I like it...
    First time as a co-test pilot today. Thought when the time truly came to put the 172 back in the air I might be nervous, but strangely that wasn't the case. Vigilant yes, nervous no. Probably because I saw first hand every piece from start to finish(corrected mistakes and all). Very grateful to my mechanic for being so patient and willing to work with me on this.
    Flew left seat, very different procedure from everyday flying, neat experience.
    Now just everyday flying. Going to put 10hrs or so on it before hauling kids, they are anxious.
    Last picture of two tin cans. The one behind me is happy to be flying again and I am happy to be flying it. The one in my hand was a celebratory PBR. High brow stuff, but I'm worth it and it was a special occasion.
    Next pictures will be Supercub stuff, I promise.
    Jim
  8. #208
    Apr 2013
    Cloquet, MN
    135
    Adventures in Alchemy
    First try at plating today. Pleased with the results. Not cheaper to do this yourself on a big pile of small parts, but I wanted to do it and show the kids. $555 bucks in stuff here. $255 in kit from Caswell, roughly $200 for cheap power supply, and $100 bucks in pots, thermometers, alligator clips and the like.
    Basically it goes like this, sand or bead blast your parts so they are spotless. Degrease them in a darn near boiling degreaser powder/water mix (from Caswell), Mix up a solution that if I had to guess is mostly vinegar and salt (from Caswell) in distilled or RO water. Circulate the solution with an aquarium pump and heat the solution to 110 degrees F. Hang two zinc plates in it, (also from Caswell), and hook the positive lead of a constant current DC power supply to the zinc. Hang your steel parts that you are plating from copper wire from a copper tube and hook the negative lead from the power supply to that. You run .14 amp/square inch through the parts for 20 minutes. You are basically putting the positively charged zinc in solution and depositing it on your negatively charged steel. The pulley cages took 1 amp total, and the flap hinges took 6 amp total. I had the voltage set at a max of 12V, but in reality, it doesn't take near that much. The amps are what drive and regulate the process, so a power supply with constant current is what you want. Most of the switching power supplies have both CV and CC. I would not recommend the one I have pictured here. It is of poor quality. I have used it twice and had to fix it both times before using it. It did not come from Caswell.
    After parts are plated with zinc, rinse them with distilled water, and dip them in the yellow chromate/distilled water solution at 80 degrees for 30 seconds to give them the cadmium color. Rinse again and let dry.
    You rinse the parts back to the buckets you did the last process from to keep from contaminating your baths and wasting materials. You cover the buckets with gasketed lids until next time.
    The stainless pots have water in them to heat the solution in the plastic buckets. Tank heaters that won't contaminate the process are expensive. This old range from my wife's parents was free 23 years ago and I use it for heating 7018 rod, making jerky, and now plating. It will also bake cookies and cook pizza!
    You can homebrew the elixirs and buy the zinc from somewhere other than Caswell. If you did this I'm sure you could do this lots cheaper than what I have done, but I didn't want to do that on these parts and I figured I didn't need to complicate things on my first try.
    The only semi-nasty stuff is the chromate or color. It is an etching acid. Keep it off your soft and tender parts. I'd compare it to battery acid. Have a fan going, don't be stupid with it.
    You can make these parts shiny with a brightener in the plating bath, but I opted to leave them dull like what I think of with true cad. From what I read the zinc does the lion's share of the protecting. The chromate does some too but is more a matter of preference.
    Again, not an expert, not a professional plater. Just trying and learning new stuff by slowly building an airplane in my shop with my kids.
    Lots of fun.
    Jim
ID:	39306   Click image for larger version.
ID:	39307   Click image for larger version.
ID:	39308   Click image for larger version.
ID:	39309   Click image for larger version.
ID:	39311   Click image for larger version.
ID:	39312   Click image for larger version.
ID:	39313   Click image for larger version.
ID:	39314   Click image for larger version.
  9. #209
    Jun 2009
    Northern Maine
    703
    Thats looking real good! Keep up the good work. It will all pay off in the end.
    E
  10. #210
    Apr 2013
    Cloquet, MN
    135
    Plating Progress
    All the small parts for the wing are plated. I am down to the longer stuff that won't fit in my plating tank (bucket). I have a plan for this stuff, flap/aileron hangers and the like. Going to give it a shot before I take any pictures of that.
    In doing small batches like I am, it is hard to keep the final color consistent. You can see there is some variation throughout the parts. I've learned that it pays to take the zinc anode out between every batch and clean it. It gets like a wet soot on it during the plating process. The soot washes right off with a spray bottle of distilled water. The anode also keeps breaking down into the brine solution even when there isn't current flowing through it. If you pull it out between batches it will last longer and keep the solution cleaner. I filtered the plating solution once through coffee filters, I'll likely do it again before the bigger parts. You also have to monitor the color that comes out on every batch and add a small amount of brightener solution periodically. You can do some nice looking stuff with a setup like this, and if you can keep it to one batch, which isn't much, your colors will be consistent.
    Uniform color wasn't the most important thing to me with this. Most of this stuff is buried in the wing. What isn't will get some paint shot over it anyway. I'm confident all of this stuff has a good coating of zinc that won't blister or flake off. For good measure, I have rattle canned a thin layer of clear over top of all the small parts(no pictures of that yet). It takes some of the vibrant color away from the shiniest of parts, but it improves the luster on the dullest and helps improve the color variations.
    Sharing some pictures of my "cheap" little blast cabinet setup. I bought it to clean up cylinders with walnut shells on the engine project/projects. I have since switched over and tried glass beads and finally aluminum oxide for the current project.
    All I had for a compressor at the time was a 22 gal portable. I knew it wasn't near enough, but it was what I had and it worked well enough to start with. Surprisingly, I didn't lock it up. Finally saved enough for what I wanted and got it playing this weekend. 60gal two stage, regulated down to 120psi, teed in with old compressor and about a 10 gallon portable tank. This is nice. Big compressor actually shuts off while blasting, and with nearly 100 gallons of storage, gives it enough off time. C-Aire is the make, they are the same company that made my little compressor, hopefully this one is just as tough. Both were at least assembled in the U.S. Best of both worlds, smaller compressor for small jobs and everyday stuff, big compressor when needed.
    Some other blast cabinet improvements were the hillbilly dust collector and two $5 dollar magnetic/Velcro LED lights for in the cabinet. Both the dust collector and the lights work surprisingly well. Just need to pulse down the baghouse between batches to keep the Shop Vac filter from blinding(shake).
    More pictures soon.
    Jim
ID:	39437   Click image for larger version.
ID:	39436   Click image for larger version.
ID:	39435   Click image for larger version.
ID:	39434   Click image for larger version.
    Likes RVBottomly liked this post
  11. #211
    Apr 2013
    Cloquet, MN
    135
    Finished my plating. Stuff to share that I learned.
    Finished with plating the larger parts today. All that really needed to happen to accomplish this was a different shaped plating tank. Hung the parts in diagonally with the zinc along the sides. Worked well.
    Had some rework to do on some of the smaller parts. The colors varied slightly but more importantly the difference in shininess bothered me. I sprayed clear over top of about 12 parts to remedy this. DON'T DO THIS. When the clear was still wet, I was happy. When it dried, I was not.
    The problem is Caswell recommends no brightener for a Cad look. This is fine for the first few batches, but slowly your parts start looking like bronze baby shoes with no oil slick colors in them. The solution is to add this brightener in the plating solution to liven things back up. When you do this, the finish is too shiny and starts to dull to acceptable then too dull, repeat. This is tough to control and hard to get repeatable results.
    I did some reading and tried three different quick acid dips after zinc plating and right before the chromic acid(color) dip to bring the zinc to a bright sheen. Sulfuric acid was a fail. Muriatic acid was a fail. Nitric acid at a 1% solution was a huge success! The picture of the spar attachment bracket halfway dipped is the difference. I quit using the brightener and used this method on the small parts I had to redo and all of the large parts. Very uniform, very easy to repeat, nice coloring.
    Things I learned:
    If you blast your parts down to bare metal, plate and chromate them, and are unhappy, 30% more or less Muriatic acid(hydrochloric with impurities), will strip all of the plating back off in about 30 seconds. Do this outside with a broom handle length stick and a wire. When you take the lid off of the bucket and the acid contacts moisture, it smokes. Be upwind. Don't get the acid on anything you like meaning your body, your eyes, or your lungs. When you dip the part and the fizzing stops, you are done. Immediately rinse the steel parts with water then distilled water and immediately re-plate. You won't get the zinc plating back off easily by blasting even with aluminum oxide.
    If you chromate your zinc plated parts and are unhappy with the color, 5% more or less Muriatic acid for about 10 seconds will strip the chromate back off and leave the zinc. Rinse the parts with distilled water quickly after doing so to stop the acid and immediately chromate(color) again. This removal must be done when the chromate is still soft. If you let it harden overnight, you are back to the nasty 30% Muriatic bare metal strip down.
    A 1% Nitric acid quick dip for 3 seconds after zinc plating and before chromating will make the zinc a nice dull silver color. This is what you want for repeatable results. If you don't have that, strip it all off and zinc plate again. Nitric acid can be bought at a 4% solution and shipped to you non Hazmat. At higher concentrations, that is not the case. It is wicked stuff...
    Make sure all of the blasting media is off of your parts before plating. Do this by rinsing with water, then distilled water, then immediately plating. It doesn't take much to wreck the plating, it will stick to the parts like weld splatter and spread across the part like a black horrific cancer. Again, the cure is the nasty 30% muriatic acid stripping.
    A little zinc will go a long way. I was worried about not having enough. The pieces I started with were .040 thick, and 4"X8". I was able to plate all of the steel parts pictured here and you can see what was left. It is now about the thickness of a razor blade, but it was enough.
    Bath temperature does not seem as important as what Caswell recommended. They recommend 110 degrees for the zinc plating bath, and 80 degrees for the chromating bath. With my larger parts, I had temps down to 70 degrees for both with the same results.
    I would skip the zinc brightener solution. Too hard to replicate results between batches.
    I whipped up a home brew plating solution after I was done to see if I could get the same results. White vinegar, Epsom salt, sugar. It plated, but it was slow.... I believe if you wanted a good thickness of zinc, it would likely take up to 12 hours at the same .14amps per square inch. Still very thin plating after 2 hours. This elixir was not worth the effort.
    In a nutshell if you want to try this, buy the plating solution and the chromate from Caswell. It is worth the money. The zinc likely is too, but I'm going to try a product called Moss Boss which is a roofing product available at Menard's, Home Depot and the like to see what it acts like with the Caswell plating solution. It worked with the homebrew.
    Anyway, here are the completed pictures. I'm happy with it. Also included the Hillbilly Dust Collector. For some reason it didn't make it through on my last post.
    NOT A CHEMIST, OR AN EXPERT. PLAY WITH STUFF LIKE THIS AT YOUR OWN RISK!
    Jim
ID:	39519   Click image for larger version.
ID:	39520   Click image for larger version.
ID:	39521   Click image for larger version.
ID:	39522   Click image for larger version.
ID:	39524   Click image for larger version.
ID:	39525   Click image for larger version.
ID:	39526   Click image for larger version.
ID:	39527   Click image for larger version.
    Thanks stknrddr thanked for this post
    Likes Gordon Misch, mike mcs repair liked this post
  12. #212
    10,433
    Quote Originally Posted by Jim A. View Post
    Things I learned:
    Jim
    thanks, I bookmarked this...
    please consider starting a separate thread about plating and put this in, or if there is all ready a thread on it, adding it to it.... to make search easier for us
  13. #213
    10,433
    Jim
    thats all I've tried, and also was not impressed.... got the job done but dull & ugly.. thanks for the comparison
    let me know if any other home-brew formulas work... caswell will not ship up to me in alaska....
  14. #214
    Apr 2013
    Cloquet, MN
    135
    Mike,
    One I ran across was on thisoldtractor.com/zinc Gregory Bender. His parts look like they might brighten with the nitric acid dip. Might catch fire too, I don't know. Before my teeth get wiggly, I'm gonna quit experimenting with plating solutions. I'm not qualified to even guess. The one homebrew I tried sounded pretty harmless. His concoction looks to involve distilled water, zinc oxide powder, sodium hydroxide(lye, caustic soda?). There were also some other homebrews mentioned there. I've never tried Lutefisk because of the lye thing... Used lye on the farm to remove well, most anything stinky, dead, and gross. Bones and all.
    I'll try to figure out how to move these last two posts.
    Wish I could be more help to you.
    Jim
  15. #215
    Apr 2013
    Cloquet, MN
    135
    Moss Boss alternative zinc test
    Moss Boss is a roofing product for controlling moss/lichen? growth on cedar and asphalt shingles. I bought some from Menard's, a local big box home improvement store in this neck of the woods. This product is 99.7% pure zinc versus what I used for plating my parts which was 99.9%. Because it is shiny, I would guess the .2% is lead, but I don't know that for sure.
    This stuff by weight is much cheaper. I was concerned about having enough zinc to finish my parts, and it was available locally. Before work tonight I plated with it in the Caswell bath. Same conditions as the last parts, 70 degree bath, agitation from an aquarium pump. The only difference was that I was pushed for time so it only got 10 minutes of plating versus 20 which should mean a thinner coating of zinc.
    I can't see much difference.
    I suppose a better test will be to run more parts. There is likely some zinc from before suspended in the bath, but from my limited experience, if the bath is even slightly contaminated, it shows up immediately on your parts. I'll find out for sure on the next project.
    Some things I forgot to mention earlier:
    Don't handle the parts from blasting through the entire process including curing with your bare hands. Your fingerprints will show up like black ink.
    Get the water drops off the parts after chromating as soon as possible by blowing on them. Where the drip hangs will discolor the finish. Don't use compressed air, don't use a heat gun. Hang them in front of a box fan with a gentle breeze to dry them. I gave them 20 minutes before moving them to a place to further cure via a wire through a hole, not with my hands.
    The finish is soft as hell until it cures. It will smear or more like slough off if you don't leave it alone for a day to be safe. This is the chromate coloring, not the zinc. I assume this is because the chromic acid is working on the zinc and it needs time to react.
    I covered all the acid buckets immediately after use. It is acid, it is going somewhere. Use the Hi-Test stuff outside close to a source of water. I plan to tape the lids sealed on all of this stuff, put it inside a plastic tote with its lid taped shut and wrap it in plastic for storage. I wish I had a place other than my shop for this process and storage but I don't.
    Water down or neutralize any spills before you clean it up with a paper towel or rag. I wiped a drop of the chromic acid off the glass bottle it came in with a paper towel. It immediately got hot. After that I was very conscious of not making a spontaneously combustible pile of towels or rags in the trash.
    The Caswell plating manual helped. There is a lot of information in it. Some of it is helpful and important, some of it is not.
    This was my first attempt at this. I am an ignorant rookie. My postings are just my observations from along the way. Be mindful of that if you use any of them, and be careful!
    Time to put this stuff away. I finally have all the parts to put my wings together. This will be a first time experience as well.
    Jim
  16. #216
    Apr 2013
    Cloquet, MN
    135
    Gonna be tight in here for a while...
    Cleaned up everything from the plating tonight. Fished my spars out from under the bench and finally got them unwrapped. They aren't antiques yet, but I've had them for a while now.
    Pleased on three counts. 1) Looks like I'll have just enough space to put them both together at the same time. 2) My ribs slide on the spars. 3) Looks like after I tidy up the H2AD parts on my bench I'll have 8' of it left to assemble ailerons and flaps. Too embarrassed to take a picture of that mess. Looks like a bomb went off.
    Ordered the "how to assemble" CD from Univair last night. Hopeful it shows up yet this week.
    Assuming laying out, cutting the inboard ends of the spars, and match drilling the spar attachment points/brackets is first. Going to try to figure that out tomorrow.
    Super Cub wings so it looks like Figure 5 on drawing 14383 for front spar and Figure 2 on drawing 14453 for rear.
    If it isn't as straight forward as the drawings show for the inboard attachment points, please give me a heads up. Gonna hack on them if I think I'm sure. Not 100% on the exact total lengths yet, so outboard spar ends will stay long for now.
    Jim
  17. #217
    9,381
    Don't forget using the incidence block on your outboard saw horse while you are assembling the wings for the correct washout. Particularly while fastening the leading edges.
    Likes mike mcs repair, TurboBeaver liked this post
  18. #218
    Apr 2013
    Cloquet, MN
    135
    Thanks Pete. Will likely have to ask more questions when I get to that. Last aileron rib will be the last outboard rib. Won't be in the same place as a standard wing, further outboard some. Spars are just sitting there for now. Just wanted to make sure ribs were going to slide on and see how much real estate I was going to have left last night. Going to watch the DVD before I do anything much more than slide all the ribs on and lay stuff out. Maybe mount drag struts. Would like to get the inboard spar attachment points done for measuring and layout purposes before watching the DVD. This may not be a good idea, might be more involved than it appears. Hopefully someone will chime in on that. The iron is hot...
  19. #219
    9,381
    Last aileron rib will be the last outboard rib. Won't be in the same place as a standard wing, further outboard some..
    This is telling me that you are planning to have squared off wing tips. I would use the length that you have. Don't cut off any of it except to ensure they are the same. You will not regret having every extra inch of span which is available to you.
    Your incidence block should be in the same location as the stock outboard aileron rib in order to provide the same amount of twist. Not that there would be much difference in twist over that length of spar.
  20. #220
    Apr 2013
    Cloquet, MN
    135
    Pics
ID:	39578   Click image for larger version.
ID:	39579   Click image for larger version.
  21. #221
    Apr 2013
    Cloquet, MN
    135
    So far so good
    Going against what I know is probably sound advice, I'm going to have to take 10.375+- inches off of my 17' spars. They will be roughly 193.25" long from attachment bolt to the end. The reason is this, I'm not remaking my flap/aileron spars, and their leading edges. Sticking to what I had planned originally, 8' ailerons, 8' flaps extended to fuse and outboard. Can't go in reverse now if I want to try to finish this in my time frame. My rear spar is .125" shorter overall length vs. original round tip, my front spar is 3" longer vs. original round tip. My overall square tip wing will be roughly 5" shorter than the round tip, but will have 23.25" more flying wing surface per side. Hate to waste nice spar material, but its what makes sense to me. Ribs are close to where they go. Same layout as original 13 rib wing with a 14th at a narrow bastard spacing on the end. Lightweight nose ribs to go between all except for maybe between 13th and 14th. Laid leading edges(like original), false spars, flap/aileron spars over top of wing and it looks like all that I masterminded/crafted years ago should work. We'll see...
    I took close ups of what I butchered off the ends of the front(last post), and rear spars(this post) for attachment. It appears right to me(other than the temporary bolts and lack of steel bushings). If someone who has done this before sees anything that doesn't look right with this part of it, please let me know. For the moment I still have 10.375+- inches worth of spar to correct possible mistakes.
    Jim
ID:	39614   Click image for larger version.
ID:	39615   Click image for larger version.
ID:	39616   Click image for larger version.
ID:	39617   Click image for larger version.
    Likes stknrddr, mike mcs repair liked this post
  22. #222
    Oct 2015
    Garner,Texas
    12
    Good luck on getting the DVD anytime soon. I ordered a copy from Univair on Oct 23rd. Paided to have 2 day delivery. I called 6 days later and was told they were out of stock, but would have them restocked two days ago. I just checked online and it still hasn't been shipped.
  23. #223
    stknrddr's Avatar
    Mar 2011
    Greenville (north east), Wi. U.S.A.
    64
    Jim,
    Here's my take on the location of the holes for the cross members. I appreciate to know if you agree, as I hope to drill holes as well.
    I bought my spars with the cluster of holes already drilled at the wing root and at the strut attachment if you would like me to verify those.
Name:	spar hole locations.jpg
    you're project is looking great.
    john
  24. #224
    Apr 2013
    Cloquet, MN
    135
    I hope that’s right John. That’s exactly what I did. Stretched a string fom 1st drag strut hole location to #5 to determine distance off bottom of spar for #s 2,3,and 4. Going to need to take about 1/8” off the bottom of some of my drag tube feet so my holes will line up and fit within the spar web. Don’t see why, they measure right with the drawings. Kinda goofy how front spar drag tube locations increase from the bottom outboard while the rear does just the opposite. It will likely make sense soon.
  25. #225
    9,381
    I don't know for sure but that seems like it is accounting for the washout being built in.
    Thanks Jim A., Mander thanked for this post
  26. #226
    stknrddr's Avatar
    Mar 2011
    64
    Jim,
    Thank you for the confirmation.
    Here's the detail for washout and dihedral if you haven't
    seen it yet in the Piper drawing package.
    I found an on-line calculator to convert minutes and seconds
    into degrees, to get to 0.6875 degrees of washout when the
    fuselage is level.
    john
  27. #227
    Apr 2013
    Cloquet, MN
    135
    The drag with drag wires
    I know some people are using some ribs similar to mine. Mine are basically a copy of a Carlson aileron rib with some diagonals added. Once I got my drag tubes installed and put the drag wire pulls on, I stretched some string to simulate drag wires and realized I had to make some changes for clearance. My wing layout is a 13 rib wing with a 14th rib on the end. All of the ribs are where they go according to the print.
    This is not a dig on the Carlson rib. They look to be fine ribs, and they are great people to deal with. Just posting some pictures so hopefully it saves someone pulling their ribs on and off the spars a million times to make changes. Someone who has done this before would likely know and expect to make these changes.
    Ribs that had to change counted from inboard out are #1,2,6,7,8,9,10,and 12(because of the added diagonal). The nose rib between #8 and #9 also has to be changed.
    After stretching string in the tank bay, I decided to go with standard 18 gallon tanks. I have waffled back and forth on this one with many ideas, this will be the lightest and the simplest to carry enough fuel for my needs with an 0-320. A guy could just hack out the intercostals in the middle of rib two, but unused, unplanned holes bother me, I just remade them.
    Because of my unused hole thing, I tried to make my modifications reusing the rivet holes I had originally. They look a little goofy, and they are what they are. Some of my rivets had to go up a hole size because they didn't drill out well. In hindsight, I would have left the intercostals out on these ribs to start with and moved them slightly to have drag wire clearance. Tried moving them slightly on the spars for clearance, that wouldn't work either.
    Included is a picture of the PK (truss head sheet metal screws) that I used. These came from Dakota Cub. They are stainless and tiny. I used them because Steve from Texas who posts here recommends them.
    Also included is a picture of hillbilly long #40 bit which you will need. This is a 5/32 arc welding rod with the flux knocked off. I drilled a hole 1/4" in with a #39 and brazed a #40 in the end. Not NASA quality, but it is working so far. Also had trouble finding a long #1 Phillips screwdriver. Pictured is an extension from a spade bit kit with a #1 Phillips in the end. I'd rather put them in by hand for fear of twisting them off, but this is working. Running them most of the way in with power, setting them with a twist of the wrist to keep from burying them and twisting them off.
    Plan is to modify the ribs on the port wing now and get it to match the starboard.
    ONWARD.
    Jim
Name:	#1 Rib modification.jpg
ID:	39811   Click image for larger version.
Name:	#1 Rib modification different view.jpg
ID:	39812   Click image for larger version.
Name:	#2 Rib modification.jpg
ID:	39813   Click image for larger version.
Name:	#4 Rib close but no modification.jpg
ID:	39814   Click image for larger version.
Name:	#6 Rib modification.jpg
Name:	#6 Rib modification view 2.jpg
ID:	39816   Click image for larger version.
Name:	#7 Rib Modification.jpg
ID:	39817   Click image for larger version.
Name:	#8 Rib Modification.jpg
ID:	39818   Click image for larger version.
Name:	Nose rib between #8 and #9 modification.jpg
ID:	39819   Click image for larger version.
Name:	#9 Rib modification.jpg
Name:	#9 Rib modification view 2.jpg
ID:	39821   Click image for larger version.
Name:	#10 Rib Modification.jpg
ID:	39822   Click image for larger version.
Name:	#12 Rib modification.jpg
ID:	39823   Click image for larger version.
Name:	#12 Rib modification view 2.jpg
ID:	39824   Click image for larger version.
Name:	Final wing layout.jpg
Name:	Final wing layout view 2.jpg
ID:	39826   Click image for larger version.
Name:	Outboard end of spars.jpg
ID:	39827   Click image for larger version.
Name:	Dakota Cub Spar Screws.jpg
ID:	39828   Click image for larger version.
Name:	Home made long #40 drill .JPG
    Likes stknrddr, RVBottomly liked this post
  28. #228
    Apr 2013
    Cloquet, MN
    135
    Just noticed my spar stiffener is missing on picture one. I haven't forgotten it.
  29. #229
    Apr 2013
    Cloquet, MN
    135
    Necessary distractions
ID:	43080Click image for larger version.
ID:	43081Click image for larger version.
ID:	43083Click image for larger version.
ID:	43086Click image for larger version.
ID:	43085Click image for larger version.
ID:	43084Click image for larger version.
ID:	43087Click image for larger version.
ID:	43088Click image for larger version.
ID:	43089Click image for larger version.
    Time flies after half time.
    Daughter retired from gymnastics this winter to focus on running. Pictured here with the oldest boy. Reached level 9 without major injury, has more medals than display area. Proud of her, she could have continued on and had continued success, but to be honest I'm glad she's chosen to let this go. Nothing will log more miles on mama's vehicle than gymnastics and dance. Gymnastics makes flying look cheap and I know flying with wings is safer.
    Another wrestling season in the bag. From the middle of November until the middle of April, wrestling takes over. Not much time for much else. Oldest pictured here after his Conference win. Went 34-11 on the season. Proud of him too. Middle boy moved up with the High School program this spring, youngest has one more year with Dad at the middle school level and then I'm done coaching. 12 years will be enough.
    Had quite possibly the best time ice fishing ever with my Dad this past winter. Why wouldn't you go ice fishing fresh after a hip replacement? Not saying where, but the Bomber behind my Dad is likely a dead giveaway to some guys in Minnesota.
    Bought Mom and Dad a golf cart for bringing stuff up and down to the lake at their cabin. Maybe Dad will actually use the damn thing and keep from hobbling himself again... Needed some better rear tires.
    A go-kart for little boys was on the build list for this spring. Golf carts and 4-wheelers are listed in the same place on Craigslist by the way. Boys were disappointed that the golf cart was going 3hrs. away to Grandma/Grandpas. Wife said "absolutely not", but not emphatically and you know the rest.
    Finally got enough hours on the 172 to feel good about taking kids up. They are pleased and so am I.
    Finally got my lathe and mill leveled, wired, and operational. Purposely haven't done much with them yet, the money for tooling/learning the hard way comes from "Jim's Airplane Fun Money Account".
    Got all of the wheeled distractions out of the airplane factory this past weekend, got back to the wings. Port side wing coming together, making lots of little parts into big parts. No surprises so far. Exciting to see the wings slowly coming together without issue.
    I know this isn't Facebook, but I've found that if I post, I do.
    Jim
    Attachment 43078Attachment 43068Attachment 43069Attachment 43070Attachment 43072Attachment 43071Attachment 43073Attachment 43074Attachment 43075Attachment 43076Attachment 43077
    Thanks Bill Rusk thanked for this post
    Likes Bill Rusk, cubdriver2 liked this post
  30. #230
    Apr 2013
    Cloquet, MN
    135
    More little pieces...
    My South Bend 13 lathe is 72 years old. I noticed I had some movement in the headstock bearings when I first started playing with it and feared the worst. I had about .004 up and down in the front. After some reading and about 20 minutes of adjustment, got her back to .001. I love simple old heavy junk that works!
    Anyway I needed to make 6 bushings with it that get pressed in the spar attachment points. Yes, I know McMaster Carr will gladly ship these to me, but this was more fun. Had to dig out my plating stuff again. Took longer to re-remember how to do it than plate the parts. Nice to have this option for a few things that get forgotten. Last Fall, I hung a plated test part on the garden fence to see how long it would take to rust outside in Minnesota weather. Been out there roughly 8 months, still looks good. Should have hung one from my rear bumper on my truck for comparison.
    Had to make a couple of aluminum spacer washers as well for behind the #1 drag struts where there is no drag wire attachment in the tank bay. Also missed two spar stiffeners.
    Any problem with using AD (hard) rivets in place of the stainless screws that go through the spar stiffeners, spars, and drag tube feet?
    Jim
ID:	43331Click image for larger version.
ID:	43332Click image for larger version.
  31. #231
    9,826
    You have a B-12 too?
  32. #232
    Apr 2013
    Cloquet, MN
    135
    Wow Glenn, I am always amazed at what people know here. At first, I wasn’t sure what you were referring to with the B-12 question. The snow machine in the picture is not mine, but again an awesome old heavy machine that works. Jake’s Resort, NW Angle, Lake of the Woods, MN own it. They have a smaller one too, I think it used to be a school bus from the 30’s-40s. In my opinion, this is one of the most interesting and curious places I have been to, and I try to go every year with my Dad and his buddies. Cat is out of the bag now, I could tell you the fish weren’t caught up there, but it would be a lie.
  33. #233
    9,826
    This was a project my friend had in a snowmobile museum in NWNJ. I hauled it home 12+ years ago after my buddy Roger bought the project. Took him 10 years to restore it
    Likes Jim A. liked this post
  34. #234
    Apr 2013
    Cloquet, MN
    135
    That's awesome Glenn! Here are better pictures from a few years back of two of them they run. I believe they extended the big one. They have a third that I don't have a picture of. I thought it was built from an old school bus, but I'm remembering it having round windows like yours. The one I don't have a picture of has a manual transmission, controls remind me of a Studebaker grain truck we had when I was a kid.
ID:	43345   Click image for larger version.
  35. #235
    9,826
    I think all the round porthole window ones are plywood and the newer ones are Aluminum sided and built similar to a school bus body. Found an aluminum one up in the Adirondacks years back and it had been registered for road travel and it was a 1971 model. Look on YouTube for B-12 Bombardier
    https://youtu.be/V8lt0_Gkel8
    Sorry for thread drift
  36. #236
    Apr 2013
    Cloquet, MN
    135
    Update
    All ribs, nose ribs, drag wires, fuel bay tube, etc. installed. Trammeled wings, everything squared up nicely and easily. The only trammel points I already owned were for laying out ductwork and were permanently fastened to a sliding trammel bar that was too short. Bought these off Amazon, 25 bucks or so, Eclipse brand pretty decent for the $. 6' 3/4" square aluminum tube for a trammel bar was long enough. Doctored up a pair of channel locks with electrical tape to keep from marring the drag wires while tightening the nipples. Used the fish scale at an 8lb pull and the 1/4 drill bit for a deflection guage. Put doubled up heat shrinks everywhere the wires crossed and where I was concerned about potential of wires rubbing on ribs.
    Drilled holes for flap and aileron brackets. I'll have six total, 3 and 3. Missed making 8 part number 10291 rear spar stiffeners. Cranked out 6 tonight on my mill. Loving the mill.
    When laying out holes, I noticed that the outboard flap hinge on standard wings shows up in a weird spot on the 13 rib wing layout drawing. When you lay them out with the rear spar drawing, that 44" spacing from the inboard hinge puts it about where I have my pen in the picture. It is possible I missed something in translation, anybody else notice this before?
    Because I have 8' flaps and ailerons, I had to deviate 2 hinge locations.
    I moved my flap bellcrank out to the second/middle hinge. I put this hinge and bellcrank where I have my pen and screwdriver in the picture.
    I put my outboard aileron hinge 13" inboard from the tip of the squared wing because it had to go somewhere and I like odd prime numbers.
    I tried to keep both hinge locations close to a drag wire strut, and out of the way of everything else.
    Have a couple of questions.
    1) Is flap bellcrank stop to go behind the flap hinge bracket? It must, but it seems kind of weird to pinch it between the bracket and the rear spar. It looks like it will kick the bracket down at a weird angle by doing so. Not finding a good pic.
    2) The cover on the false spar behind the tank bay, is it there primarily to beef up the rear spar because of the location of the flap bellcrank or because that second rib has to be butchered to accept a tank? Both? I plan to do something similar on my first 3 rib bays because I moved that bellcrank out.
    Jim
ID:	43696   Click image for larger version.
Name:	Outboard flap hinge.jpg
ID:	43695   Click image for larger version.
Name:	Middle flap and bellcrank location.jpg
ID:	43697   Click image for larger version.
Name:	Outboard aileron hinge.jpg
  37. #237
    Apr 2013
    Cloquet, MN
    135
    Wings Coming Together
    Things are coming together. Did a light rear spar beef up at rear strut attachment point. Yes, I tried to copy for the most part what Javron does. Looked like a good idea, shouldn't make the wing weaker. Took lots of time to build, Javron's are nicer and better, just buy his.
    Also extended the false spar beef up for the tank bay one rib outboard. This is where my center hinge for the flaps and flap bellcrank live.
    Leading edge went on temporarily with PK screws. Had to cheat. My flange on the leading edge should have been 1/8" longer to get in the safe to drill area on the front spar. Not going to remake my leading edges. Peeled them back off, flush riveting. Solid rivets on bottom, blind rivets on top.
    64.8 lbs so far, I'm pretty sure they will be 97 lbs per side when ready to cover.
    Having fun.
    Jim
ID:	44161   Click image for larger version.
Name:	Outboard View of False Spar.jpg
ID:	44162   Click image for larger version.
Name:	Another View of False Spar.JPG
ID:	44163   Click image for larger version.
Name:	Beef Up Area at Rear Spar.jpg
ID:	44164   Click image for larger version.
Name:	Beef Up Components  Weight.jpg
Name:	View of Top Beef Up.jpg
ID:	44166   Click image for larger version.
Name:	Another View of Top Beef Up.jpg
ID:	44167   Click image for larger version.
Name:	Light Angle to Prevent Oil Canning.jpg
ID:	44168   Click image for larger version.
Name:	A View From Underneath of Beef Up.jpg
ID:	44169   Click image for larger version.
Name:	Lower Beef Up.jpg
Name:	Another View of Lower Beef Up.jpg
ID:	44171   Click image for larger version.
Name:	Rear Spar Beef Up Complete.jpg
ID:	44172   Click image for larger version.
Name:	Tank Bay and Center Flap Hinge Beef Up.jpg
ID:	44173   Click image for larger version.
Name:	Washout Block.jpg
ID:	44174   Click image for larger version.
Name:	Low Tech Flanging Stick.JPG
Name:	Low Tech Flanging Tool 2.JPG
ID:	44176   Click image for larger version.
Name:	Leading Edge  With Temporary Screws.jpg
ID:	44177   Click image for larger version.
Name:	Leading Edge Cheat.jpg
  38. #238
    9,381
    Perhaps it's just not visible in the pictures? Where are the holes to bolt on the rear spar to fuselage fitting?
  39. #239
    Apr 2013
    Cloquet, MN
    135
    Pete,
    The picture that you have referenced is the outboard end of the port side spar. I’m not the best photographer and because I have aileron ribs only, it is unclear. The rear spar attachment points are present and accounted for on the other end. Thanks for keeping an eye on me though. I for sure need it!
    Jim
    Thanks skywagon8a thanked for this post
  40. #240
    RVBottomly's Avatar
    Sep 2017
    551
    Jim, thanks for all the pictures.
    I've looked over and over at the Javron approach to stiffeners but I could never see any real detail. Did you ask him for drawings or did you just figure it out from photos?
    I'm building a wooden wing that is supposed to be designed to 2200 # gross. But I plan on adding larger flaps like you've done and moving ailerons out so they will fit, so I'm interested in "beef-ups" and why there were deemed necessary.
    Thanks again for the detailed photos. They help in ways that aren't apparent at first.
    Vic
  1. New member
    By willirw in forum Cafe Supercub
    Last Post: 02-16-2010, 06:17 PM
  2. model change PA18-125 to a PA18-150
    By cubcrasher in forum Modifications
    Last Post: 02-23-2005, 03:03 PM
