Cub junkie
My Moms basement
All I did was rip some pine lumber into 5/8" square strips and build a temporary framework in the door opening. I used a couple of cabinet hinges at the top clamped in place and some more lumber to simulate the strut and wing spars so I could check the swing and see if it would clear the strut and I determined it would. I was going with it but then decided to use the stock set up instead. The material I used for the doors and windows is what is called out on the plans.
