skywagon8a
SE Mass MA6
When a drooping system is installed there is less up aileron available. Up aileron has more effect on roll control than down aileron particularly at the "new" lower flying speed. Drooping ailerons are good at the expense of reduced crosswind control capabilities.
Most any shaped tip other than a flat plate would have lower drag and improved aileron control at minimum speeds.
