skywagon8a
SE Mass MA6
Look outboard of the skin which is clecoed in place. Count outboard to the 2nd and 4th exposed nose ribs. From here it appears that the rivets which are holding the vertical stiffeners are dimpled. This is from not holding the angle stiffener while driving the rivets. If you held the bucking bar in the palm of your hand and held the stiffener with two fingers of that hand while driving the rivets, the dimpling could have been prevented.Thanks Sky!
There are no rivets in there yet.
I do have a mushroom set with the rubber around the edges. I'm planning to back-rivet in those areas where I can. I made a 2" round brass bucking bar that works really well for that. It gets beat up some but I just put it in the lathe and "freshen it up" a bit.
