Sky,
Very interesting video and it sure makes you wonder why leading edge slats/slots aren't on every wing...cost and complexity I suppose. The different shapes sure go to show there were pretty advanced aerodynamic studies underway long before NASA came along. It would have been interesting to compare leading edge devices with VG's and see how much they really benefit airflow and keep it on the wing top at high AOA. VG's are certainly cheaper and easier to employ than the slats/slots.
My gear legs are much more vertical than the ones used on the Ballancas so I'm not sure if it's possible to get any real lift from them even with an airfoil shape. I'll be happy with just getting rid of the drag. I'm still playing with how to get 0.020 2024 bent just right before I cut larger chunks of material. The smaller pieces are much easier to bend correctly and I'm using poster paper to make patterns. I still think there needs to be some substructure to support the fairing on the gear legs. I think using the 1/4" tube will provide the support but then just using fabric instead of the 2024 seems to be the best solution for ease of construction. I do like the idea that the fairing can be removed or opened up for inspection or in case there is an issue with brake lines.
Thanks for sharing the video and pictures!!
