I used a high pressure poly-type tube that came with my kit. Nice and light and easy to position. Do you have the masters in the front? I used stainless steel braided hose from the fuselage to the wheel. This line did not come with the kit. Bulkhead fittings where the lines penetrate the fuselage. I also have no brake pedals or rudder pedals in the back. No stick or throttle either.
Spinner,
I'd agree with you on no pedal or stick but I need to do some instruction on stick and tail wheel for my kids so I need the backseat pedals and stick. They have only flown my C-170 so the stick is new to them. I may pull them out once they are comfortable and I feel OK with them flying the LSA, but then it is nice to be able to hand off the plane to a pax too or just get a break for a few minutes.
