I'm the guy doing some BETA testing for John using my Rans S-7S. The shock itself is made by this outfit
www.foxracingsox.com He is using it in a way that hasn't quite been done before as regards cub style gear. He also makes a cub style bungee retro fit gear for the Rans S-7S which I installed some time ago. This new shocked unit simply bolts into place, replacing the bungee shock strut. Here's a test rig I made up yesterday to test the drag of the faired unit, even the ends are closed in. At 75 mph indicated (car speedometer) and with a estimated 10 mph headwind so about 85 mph wind, according to my digital fish scale..... it exerted a force around 10 to 13 ozs. This obviously was a pretty crude test, but as I was comparing it to the faired bungee unit I was replacing it was more comparative in nature.
I now have about 20 hrs on them, and am cruising at 95 mph, on wheel skis, at the normal Rotax 912S prop rpm of around 2300. (That's 12,000 engine rpm, but still less then 4 GPH, (just a little Rotax/Continental/Lycoming joke, the fuel burn is for real though, the actual engine rpm was 5200 which it can do all day every day though I usually cruise it at less the 5,000 and get the burn down to 3.2 GPH) The cabane and a-frames are also faired. So, not a big hit drag wise. I am still playing with the air pressure setting, which is as easy as setting the pressure in a tire. As you can see by the Fox site, these shocks are very trick.... and right now it is looking like somewhere between 100 and 125 psi is going to be the sweet spot. As far as handling improvements, it's been tough to extrapolate that due to the fact I'm on the skis, I mean on fresh fluffy powder anything or NO shock would feel great, but as I encounter varied types of snow I am gradually getting a feel for them. The plane feels real solid while taxiing and on sideslopes, overall "tighter", while at the same time just as squishy when you want it to be. Like getting vg's on an airplane, it takes a while, at least for me, to fully get a handle on the performance differences, one landing in particular stands out: I was setting down in what seemed to be a smooth mountain meadow, and on slideout and going maybe 15 mph I saw I was going to go over a drift or berm, whatever, and it looked like the kind of bump that would pitch you back in the air just enough to give the gear a good workout but not enough to be a problem. I went over it and after coming to a full stop and getting out and looking back, I noticed the ski tracks had never left the snow, this I believe was the shocks in action, they kept me glued to the surface as they get rid of the rebound/bounce back of the bungee gear.
For the next few weeks, rather then look for the smoothest areas to set down in I need to look for the roughest, if I am any kind of a BETA tester that is. If I was on my usual 29" Airstreaks the differences would be easier to pick up on, the changing snow conditions confuses thing a bit, but so far, I like them a lot.
