Results 1 to 12 of 12
Thread: Aluminum struts
    Dec 2004
    Hutchinson, MN
    59
    Aluminum struts
    I'm looking for information (weight/supplier) and photos (specifically the fittings at each end)
    Is it so the cub crafters offers alum struts on a carbon cub? Please share the pros and cons
    Thanks, Butch
    Clay Hammond's Avatar
    Rhinebeck NY (NY94)
    1,297
    It is so. They are light weight and work just fine.
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,309
    D&E is another source. Last I heard you can't buy CC struts and related parts separately. Has that changed?
    Here are some photos of the D&E setup:
    http://www.supercub.org/photopost/sh...ry.php?cat=781
    gpepperd's Avatar
    Aug 2005
    Wasilla, Alaska
    218
    Does anyone have the weights avalable?
    Good judgment comes from experience, and a lot of
    that comes from bad judgment. will rodgers
    "Anyone who would give up liberty for safety deserves neither" Ben Franklin
    Bill Rusk's Avatar
    5,323
    I know Jay at Javron is (or was) working on this. The struts are not so much the problem, its the attach stuff that is. He is working with an engineer to get this done. I anticipate he will have it, and the weights, soon if not already. I have not asked recently how that project was coming. You might give him a call...
    Very Blessed.
    Likes Bill.Brine liked this post
    Hot Springs, SD
    363
    I got mine from Carlson Aircraft. I made my own ends out of square tubing. Total installed weight is 26 lbs. I weighed univairs struts a few years back and they were 39 lbs with the heavy duty forks installed. I doubt that the carlson struts would pass the compression loads of a 1750 gw cub, but they are fine for mine at 1320.
    Likes courierguy, mike mcs repair liked this post
    Olibuilt's Avatar
    Nov 2009
    Montreal, Canada
    832
    Most of the guys here in Quebec have aluminium struts on there experimental Cub or SuperCub. We also use the strut material for float rigging. It is cheaper to buy than sealed struts, and you can make custom attach fitting easily.
    http://www.aeronefmontreal.com/index...mid=54&lang=en
    We have the choice between 3.125'' (.750'' fllat inside) (0.8063 lbs\foot) and 3.625'' (1'' flat inside) (0.9945 lbs\foot). They are lighter than metal sealed struts. Next project I'll be using 3.125'' for all 4 struts.
    You can step or push on those struts...
    I can have the compression and elongation number for those if interested.
    My exp 180hp Super Cub (2400lbs gross weight) has one big strut up front and one smaller one in the rear. Big one for float rigging.
    Jonnyo's Avatar
    May 2014
    Fairbanks, Ak
    137
    Olibuilt
    Thank you for the post. Do you know a current source for the aluminum strut material and fittings? The Aeronef link did not work.
    Jonny Olson
    Quote Originally Posted by Olibuilt View Post
    nd
    3,495
    http://www.southernaero.net/products.html go to the bottom of the page.
    Thanks Ruffair thanked for this post
    Jul 2016
    Anchorage, AK
    116
    Does anyone have the complete weights of javron experimental aluminum struts or the Airframes certified aluminum struts?
    Jul 2016
    Anchorage, AK
    116
    28.3 pounds for complete set of airframes aluminum struts
    May 2020
    3
    Very cool and easy, thanks for the info.
  1. D&E Aluminum Lift Struts
    By PA18project in forum Experimental Cubs
    Last Post: 07-05-2010, 10:44 PM
  2. D&E Aluminum Struts
    By Bugs66 in forum Experimental Cubs
    Last Post: 06-08-2007, 10:34 AM
  3. Changing PA12 jury Struts to PA18 struts?
    By PA12driver in forum Super Cub Sick Bay
    Last Post: 03-12-2003, 12:49 PM
