I just realized I never put out a report on my Earthworks....
I installed Earthworks batt ETX36C (the C or D after the 36 is just a dimensional difference) in April of last year. So, I'm nearly at a year on the battery....
I love it. It's extremely lightweight and cranks harder and faster than the Oddesey it replaced. I just had a battery failure/warranty replacement three weeks ago which I'll describe in a moment. The company was very fast to have a new battery in the mail and with return postage to analyze my failed battery.
I really like the BMS - Batter Management System on this battery that balances the cells for you during charge. No special chargers required like most Lithium batts. It also has a current cut off at 6 volts to make sure you can't completely run the batt dead. If you do run any of these Lithium batteries to dead, they die and are now throw away, order a new one. I like the cutout saves the batt just before it dies anyway. Leaving on your battery master switch accidently will not cost you another $340.
Operating:
There is absolutely no difference operating this battery that I can tell, save one. After start as I switch on the alternator, this battery draws much more for a shorter period of time. As the alternator comes on, there is a audible drop in RPM (10-20ish RPM while idling near 1000) as the engine takes the load. A look up at my Ammeter shows about 25-30 amps load for about 10-15 secs, then back down to 2-3 amps. Presumably, it's all charged again. The lead acid used to charge much slower, for longer.
I've enjoyed the battery all year. It's more compact. It sits right under the seat, so no CG change but it's light and powerful.
I like the terminals in the center edges of the top, so it's a universal fit. My odessey had terminals in the upper corners, so you had to be careful which battery config with positive right or left when ordering. The earthworks can be laid on either side, or reversed right or left to switch terminals to side it's needed. They have screw in posts that work with a #2 Phillips driver and you can leave your #10 metric wrench at home (Odyssey).
A few weeks ago, it was cold for here, 19deg F. Plane hadn't flown in about 5 days. I did my best preheat. These batteries are not like lead acid, which gradually loose power when it's colder. But, the engine is arguably harder to turn over, and the battery becomes more efficient as it gets warmer. So, A warmer battery does better. I turned on my landing light for 10-20 secs as I remember instructed by a lithium batt guy. I switched off light and went right to cranking. It was slower to turn. Got hung up on a compression stroke. I popped the switch a couple times to help cut through the compression and I smelled a little elect smell. Strangely, the battery still showed 13.4 volts on a meter, but it didn't have enough push to even light up my electrical..... They replaced it immediately. In reporting back, the company said my battery had been overcurrented and cracked the circuit board. I had overcurrent(ed) the BMS circuitry. The new batts Battery Management System will also prevent that now. The company is constantly adding improvements to these batteries to make them better.
I really appreciate the cold weather reports that you guys are doing for this battery as it makes me pay attention to best starting practices.
After speaking with the Earthworks people, they stated I should have let the plane set for a couple minutes after the landing light drag to allow the heat to warm though the battery (OR done that during preheat). Lesson learned.
I love the battery. With it's cost, I'm not anxious to buy another. I hope this lasts a long time. The batteries have a one year warranty and they were very good in my warranty claim.
I usually talk to Karen, but have talked to others. They're closed on saturdays, but they've called me back on a Saturday when I left a message. This company is getting all kinds of attention from pilots. They are trying to learn our needs and adapt to them as quickly as they can. She complemented and complained that we're so much more technical than their normal customers
The Supercub guys and the Rans guys are really the main aircraft drivers of lightweight battery and most of their aviation business. As reported, they will be at the Alaska Airmans show in May and looking to develop this business. They have an even larger battery under development specifically for aircraft and are trying to learn about certification. Give them a look.
