| ]Item #: 10-3678-32-O-V-E CARB ASSY MA-4SPA Retail Price: $1260.00 Your Price: $718.20 |
Better to get a factory rebuilt carb than have your old carb overhauled because a factory rebuilt carb almost always has new top and bottom body castings. They are basically new carburetors but they charge you for a core because they want to get the old worn out ones off the market. The old stuff quite often gets destroyed. Even a new off the shelf carb can benefit from some massaging of the internals and set up on a flow bench by a knowledgeable mechanic. I think FobJob had some good info on improving carburetor performance and efficiency and evening out EGT's
Jason
Interesting thread, thanks to all for sharing ideas.
For whatever it's worth, I have the square filter airbox and a -32 carb on the O-320-A2B in my 12. I have not had any significant carb ice issues. I lean aggressively, pull carb heat fairly frequently, and watch the carb temp gauge. Fortunately I haven't had to fight ice even when temp and humidity are "just right" for icing. Just my personal experience - - -
Yep - BTW, my carb heat box is from Randy Rubbert. He rebuilt it and it looks like new - -
And maybe, ice isn't the root of the problem you're experiencing. Watching the video, I noticed that the black exhaust smoke is somewhat intermittent. Puffs, then lapses. Dunno what that might mean, but makes one wonder. Seems to me that the carb would certainly be a suspect in this mystery!
before you box up the carb to return as a core I would open it up and take a look inside. Work with a knowledgeable mechanic and check the float level, check the air passageways for obstructions. Also look at the condition of the fuel nozzle and look for oval wear/erosion on holes in the jets. Check the throttle shaft for play. Check the accelerator pump operation and make sure the pump is set on the proper hole in the cam ( 3 options ) Check the Venturi for looseness. Check the accelerator pump nozzle for looseness. And look for signs of staining where fuel might have been leaking along with signs of dirt/sludge/and water in the bowl and other fuel passages. Also now is a good time to clean the screen in your gaskolator and maybe replace the fuel hose to the carb.
Jason
I try to teach students to always be on guard for carb ice, because it can be a sneaky bastard, creeping up on you slowly and quietly, right up till the loud noise up front ceases....
I decided to do a little night flying last night. I'd pulled off my 31's and switched over to 8's in anticipation of installing my wheel-penetration skis. There was some moonlight after changing the tires and I thought, why not go for a night flight and get three landings in. With the little tires I land on the runway and could use the runway lights. With the 31's I always land on a parallel section I keep mowed.
This was my first night flight in this Cub. I was making a much bigger pattern than my usual keep-it-in-close pattern landing in the grass. I'd turned final and was headed down towards the inviting runway lights and decided to pull carb heat. This plane doesn't usually make much ice and often I don't use carb heat but decided to now. But instead of pulling carb heat in the dark I pulled the mixture control. That made things quiet. Power was quickly restored when I pushed it back in. My two knobs are side by side and in the dark I didn't notice my error until things went quiet.
Hi Steve. Ya kind of like the time I took off to the north from Polson in the Cessna and blew an injector line over the lake. I made a quick 180 and landed down wind.Got your attention didnt it? :lol:
But you see, jolly St Nimp, down here in this corner of Washington, it's MOSTLY inhospitable ground. No choice. (Waiting for Torch now - 8):lol But actually it's true in the vicinity of my farm, and it was prime atmospheric conditions for carb icing.I (almost) never pull carb heat or change fuel tanks over inhospitable ground. Over cautious, chicken? I also fill 'er up every time I come down to prevent excessive condensation. I certainly do carb heat once in awhile but never had any ice indication, guess I got a good carb system.
