Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 419
Thread: Greg's Supercub Build
  1. #121
    May 2011
    Oklahoma
    297
ID:	14828Click image for larger version.
ID:	14829Click image for larger version.
    Just a short update. I've been working on the wings, pulleys, brackets, bell cranks, and tip bows. I have also been painting small parts and fitting the sky light along with other odds and ends. Plenty left to do.
  2. #122
    10,229
    Quote Originally Posted by Greg Campbell View Post
ID:	14829 Just a short update. I've been working on the wings, pulleys, brackets, bell cranks, and tip bows. I have also been painting small parts and fitting the sky light along with other odds and ends. Plenty left to do.
    Before you cover the wings, be sure to hang the ailerons and control cables pulled tight. I found, on mine, that this pulley was not aligned properly. No matter which way I repositioned the attachment bracket, there was a cable misalignment. The cable would always be at an sidewards angle to the groove which would promote cable/pulley wear over time. I could get the cable properly lined up with the pulley in one direction, but not both. I had to change the dimension of one leg on the "U" clip which is bolted to the lift strut fitting. These fittings should be lefts and rights. Piper's drawing is in error, as it shows both legs to be equal length.
    I haven't heard any complaining about the cable and pulley wearing, here on SC.org. Perhaps the Piper phenolic pulleys wear their groove, so do not cause trouble? I have concerns with the aluminum pulleys wearing on the cables. Since this is hidden inside the wing, any wear could remain out of sight. I would hate for a cable to fray without being aware.
    Likes Delta Cub liked this post
  3. #123
    May 2011
    Oklahoma
    297
    Thank You, I am hoping to put the wings and ailerons on in the next couple of weeks to test everything. I will have help rigging it. Steve Pierce said the same thing you are saying, I need to rig it all up and make sure everything is right before covering. I have been frustrated a few times. Bill Rusk, on one of the frustrating occasions, said its a project, a project will not always be perfect. I appreciate your input skywagon8a. Greg
  4. #124
    nd
    3,536
    Note that the aileron cable pulley coming out of the top of the wing is at an angle. So when covering the wing the grommet for the pulley cover also goes on at a angle. I put my grommet on straight front to back and looks like hell if you lookat it.
  5. #125
    10,229
    Also note that the top aileron horn end is bent to align toward that pulley. I think that it is 3 degrees. It's on the Piper drawing.
  6. #126
    nd
    3,536
    And also note to take a rubber hammer and bend the false spar down where the turnbuckle rides on the top before covering.I did that and was real pleased with the results.
  7. #127
    DW's Avatar
    Dec 2002
    pacific northwest
    2,067
    Look great Greg your making good progress keep it up and you'll be flying before you know it.
    DW
  8. #128
    May 2011
    Oklahoma
    297
    Thank You Skywagon8a and Tempdoug, great info. I will use these great tips. Thank You DW, I am going down to Graham, next week to get guidance from Steve and the guys. Hope to see some of you guys there.
  9. #129
    docstory's Avatar
    Feb 2007
    Anchorage, AK
    664
    It is better in my experience to make the bend after covering (including tapes). Sometimes the fabric doesn't stay adhered to the false spar at the bend when shrinking and requires extra attention afterwards.
    With guns, we are 'citizens'. Without them, we are 'subjects'.
    "To be born free is an accident. To live free is a privilege. To die free is a responsibility."
    --- Brig. Gen. Robby Risner
  10. #130
    Jun 2002
    NC
    402
    I'm anxious to discuss your project at Graham.
  11. #131
    May 2011
    Oklahoma
    297
    Thanks Docstory, I always appreciate your input. Jasperfield I look forward to it. My project isn't perfect but I want to get it flying with all my mite. I can't wait to be rolling south with my Cub. I'll see you guys there. Greg
  12. #132
    May 2011
    Oklahoma
    297
    Headed to Graham!
  13. #133
    May 2011
    Oklahoma
    297
    First time with the wings on. We are still working on fitting the wings. Really cool for me at this stage. Steve Pierce and the crew are helping me work through the issues. Pierce Aero is really a great place to work on a plane. They have really been a great help to me. I have learned so much this week.
  14. #134
    Jun 2002
    NC
    402
    Greg, that's a big step! Way to go! You're right about Pierce Aero.
    Before you leave, you will have made lots of progress. You've worked at it every day, and I saw the progress through some of the difficult phases of construction.
    Jasperfield
  15. #135
    nesincg's Avatar
    Jan 2006
    Chattanooga, TN (KAPT)
    617
    Looking good Greg. I sure wish you could be ready by summer.
    The aviator formally known as 89.
  16. #136
    May 2011
    Oklahoma
    297
    Thank you guys. Me to Chris, Somebody vote me on the airplane version of "Overhaulin". I'll get it done someday.
  17. #137
    Bill Rusk's Avatar
    5,325
    Great job, Greg. Big big progress there. Congratulations.
    Very Blessed.
  18. #138
    Ak_Navigator's Avatar
    Nov 2009
    22
    Greg,
    Awesome thread with lots of useful information. My Dad and I recently picked up a project cub so your thread is incentive. Thanks to everyone for sharing their ideas and lessons, it makes things not so scary
    We look forward to seeing your finished project.
    Cheers,
    Rick
  19. #139
    little wing's Avatar
    Dec 2013
    340
    Was over at Greg's earlier and he still has the smile on his face from Graham. He learned a lot from all you guys that helped out, and he shared some of what he learned with me, so thanks from both of us.
    We were looking at his prop (came as part of the deal) and it's stamped as a 76/60. Since I've been doing a little prop research for the 360 lately, it seemed as though this is excessive pitch. I know you can add pitch, but is there any problem removing it? If not he can use mine, Pierce already ordered a climb replacement for me, but Greg needs to burn some fuel,,,,seriously,,,,like yesterday. Otherwise, my next visit with him may be under supervision in some sort of small padded room.
    Keep up the great work Greg, it's happening, day by day, inch by inch, but when she's done, she's gonna be great!
    Hagar
  20. #140
    10,229
    Generally a prop pitch can be changed in both directions. It would depend on "how much" and "how many times" over the life time of the prop. Also, the limitations vary from one manufacturer to another.
    If Greg is ready to fly, my suggestion would be to use the prop "as is". Then using the performance with that prop as a "base line", change the pitch to suit. I don't know where the nearest prop shop is located, but he could fly it there and get the job done while he waits.
  21. #141
    May 2011
    Oklahoma
    297
    Thank You Bill, Ak Navigator, and Billy for the Kind words. It helps keep me going. Skywagon8a, My engine is a V0360, Experimental, out of a Brantly Helo, as far as I know. It was Nick Smiths personal engine. He build a float plane, flew it for 6 hours and then sold the Cub to a person who already had an engine and didnt want to pay for the engine apparently. The logs are short and incomplete. It has 6 hours on the case, and 0 time on the cylinders rebuild. It had crome cylinders and Nick tells me he didn't like those because of the oil burn with crome cylinders. Now it just has regular cylinders w/ 0 time on the rebuild. Nick was nice enough to throw the engine in with the deal unprompted, so I am grateful and hopefull it will pan out. He says not to give that engine a second thought. I have the moisture plugs in and I have marine fogged the cylinders after I had had the engine for about 5 months? Billy was nice enough to offer to loan me his new cruise prop off of his New 180 horse Top Cub if mine won't work. Thank you for the kind offer Billy. What to you think Skywagon8a?
  22. #142
    10,229
    Greg,
    I'm guessing that you may have a prop from a Cherokee? The TC for the PA-28-180 gives a static full throttle RPM range of 2325 - 2425. If my guess is correct, bolt that prop on and run it. Can you get those static run up numbers? If so fly it. It will be fast (for a Cub) but not optimum. It will not turn up high on take off and the rate of climb will not be great. It will help if you can mount a manifold pressure gauge ( even if only temporary) in order to accurately determine the power settings. Then talk to your friendly prop shop with your MP & RPM numbers (climb at 70 mph, full throttle level flight, cruise speed at 24" & 2400 rpm). If you can get 24" & 2400 rpm you will have an intermediate range pitch. If the mp is higher, the pitch will be too high (cruise). If the mp is lower, the pitch will be low (climb). These will help determine how much to reduce the pitch. It may also be a good idea to talk to the prop shop before you fly just to get them in the loop.
    Since you have zero time cylinders it will be a good idea to be able to turn up full power (high mp & rpm) for break in. Ideal would be full throttle and 2700 rpm. You need to run it hard for break in. So, you will not be wanting to run the prop long if the pitch turns out to be too much.
    Hope this helps.
  23. #143
    May 2011
    Oklahoma
    297
ID:	15198Click image for larger version.
    Thank you Skywagon8a, I really appreciate your input. Just an update, I'm a greenhorn I know, but my eyes were opened on my trip to hang with Steve and the guys. I've never put wings on, the plane will stand with out tipping over with one wing only on. Half a cub fits in my garage. So I'm fitting my jury struts one wing at a time. A big thanks to friend and neighbor Mitch, my family, and a couple of neighborhood kids for holding the wing while I pinned it. I'm doing what I can with what I can. I like a half a Cub.
  24. #144
    May 2011
    Oklahoma
    297
    One wing jury struts drilled.
  25. #145
    Dec 2013
    340
    Now both jury struts are done, along with some windshield work. What's next on the agenda Greg?
  26. #146
    May 2011
    Oklahoma
    297
    Billy, I drilled the trim on the front edge an back edge of the skylight the last couple days. I'm just knocking out little odds and ends that will be part of the other 90% once I get the covering on. My flaps are suppose to ship next week. Flaps are one of the last few thing I must test fit before covering. There are other thing I may try to do before covering like working on some of the instruments and electronics. I am getting a few of my instrument used possibly as one of my friends is upgrading his 180 to the Aspen System. I'll have to have the airspeed sent off and refaced if that deal goes down. The funds and time waiting for the instruments to be ready may push me to covering before that. I know my desire to get back in the air is not suppose to be in control, but the need and want to be pilot in command in my Cub is ever present. I appreciate your interest and friendship. Greg
  27. #147
    fancypants's Avatar
    Jan 2011
    IL
    372
    The loaner nicopress crimper is on its way.
  28. #148
    May 2011
    Oklahoma
    297
    Quote Originally Posted by fancypants View Post
    Thank you my friend. I really appreciated your help and advice while we were at Graham.... I was talking to flymore last night on the phone and he was encouraging me to start thinking about readying my power plant. So I will be looking into having it looked over so I can bring it all together at the finish.
  29. #149
    Dec 2013
    340
    Was looking in the member area the other day and came across a schematic for the standard PA-18. (not sure they came with strobes) Anyway, it's well drawn and should be somewhat easy to follow, differences being the particular components you will be installing vs. what the diagram shows, shouldn't be a big deal though. It would be nice if we could get this printed out before starting, larger than standard, maybe a couple of copies, do you have access to any big printers? If not, maybe I can drop by Kinko's. Let me know when you're ready to start. I think I got Kelly talked into going to RPH for the prop on Tues., if not the seat is yours if you want it. Weather permitting, I'll leave @ 07:30, Steve said it should only take a few hours to do the bungees and Prop, have you home before dinner if Kelly doesn't go.
  30. #150
    May 2011
    Oklahoma
    297
    Billy, I don't have a big printer. I am off on Tuesday. I am all about getting the wives involved. If she'll go take her. If you have an empty seat and need the company it would good to be in Graham. I also really appreciate the loaner cruise prop for my engine brake in. That takes a question out of the equation. I'll pm you on the rest. Thanks for all your efforts on my behalf. Greg
  31. #151
    May 2011
    Oklahoma
    297
    Mike the Crimpers arrived today. I plan to ask our Grady County Supercub crew to come over and we'll roll the Cub out in the yard, put the wings on and rig the flaps the first pretty day after they arrive. I'll get the crimpers back to you soon. Thank you very much for your unprompted kindness. Greg
  32. #152
    fancypants's Avatar
    Jan 2011
    IL
    372
    No problem, Greg. They are available for loan to anyone that can put them to use.
  33. #153
    May 2011
    Oklahoma
    297
    Is this what you are talking about? http://kestrobes.com/AllLED.htm
    I have these on my Cub.
    Question. I have this set up. I plan to mount my battery on the fire wall and the powers supply just aft of the headliner in the upper baggage. The power supply has 22 gage wire coming out of it. What would be the suggested gage for the 12 volt wire coming from the from power up front to the power supply?
  34. #154
    Iflylower's Avatar
    Aug 2008
    Memphis, TN
    1,351
    Greg, I have these on my plane and am very happy with the price and performance. These low draw LED units draw fewer amps, thus need lighter wiring.
    You need to figure voltage, amperage, distance to carry load and 43.13 will also ask about voltage drop and whether you're in a bundle or not. I'll give you a call.
    (I used almost universally 18ga wire in red and black for most of my (load) wiring, just to keep it common as long as it was heavy enough.) Obviously, wiring to starter and solenoids and main bus will be heavier.
    Cal
    "There are three things in life that people like to stare at: a flowing stream, a crackling fire and a Zamboni clearing the ice." Charlie Brown
    Please Join and Support the RAF! http://www.theraf.org/
  35. #155
    Bill Rusk's Avatar
    5,325
    Folks
    I had the privilege of going to Oklahoma and visiting with a great group of guys there and tried to help Greg a little with his build.
    L to R Cayden - training to become professional pilot, out of college and building his hours. We exposed him to the dark side of pure fun flying. I'm afraid he has been corrupted for life. Poor kid. Greg - building his dream cub. Brian - welder and general mechanical guru - can fix or engineer pretty much anything. Bill - new Cub guy, learning fast and fully corrupted. Me - general instigator of all corruption. Dave - fully corrupted and helping me corrupt others.
    Gregs garage full of Cub. This is a "one off" kit from the founder of all Supercub Kits - Nick Smith, who is helping Greg get back in the air. Nick has gone way way over and beyond to help Greg. Thank you Nick!! There are some really good people in this world and Nick is one of them.
    Aerodynamics 101. When not working on the Cub we spent a little time visiting about flying. Imagine that!
    We built up the large heavy wires. #4 CCA Fatwire for the Battery to Master relay, to Starter Relay, then to Starter. #8 gauge from alternator to main bus etc
    You have to love it when the hangar is full of model airplanes. These guys eat, sleep, and breathe flying.
    Bill and Dave's Cub Crafters Top Cubs. When not flying these......
    Dave's YAK. Wow man what a machine and Dave is an awesome pilot as is Greg and some other guys that were there visiting. Oh yea....we also had some great ping pong games. Dave clobbered me.
    Greg's 1/4 scale J-3. Just great fun.
    Greg let me fly it but I'm not very good so I had to keep it high and let Greg land it. He does great wheel landings with it. It is fun to watch him work.
    We all got to watch Terry fly this IR equipped copter......
    Then got to look through the googles to see what it looks like (not IR) but with real time video. Way way cool. Lots of technology there.
    Caden looking through the googles
    Dave was kind and trusting to let me fly his Cub so I gave Caden a ride. He will never be the same.
    Bill's stunning CC Top Cub
    Very Blessed.
  36. #156
    Bill Rusk's Avatar
    5,325
    Greg with his 1/4 scale J-3
    Dave getting the YAK out...
    Testing Brian's home designed rotisserie. Worked great.
    Brian - the metal man - with his latest work.
    Bill and I making up some wires. When we were not eating, flying Top Cubs, flying models, playing ping-pong, etc. we actually got some work done. Sorta......
    Many thanks to a great group of good Christian men. It was fun.
    Very Blessed.
  37. #157
    flymore's Avatar
    Nov 2005
    OKC
    58
    As you can see we had the the honor of having Bill come and school us in many areas. He was a great help to Greg getting all big wiring lined out. We tried to help but I think he would have made more progress solo. Day two, Bill pushed Billy and me out of our comfort zone in our CC cubs. He is really an excellent instructor and we both learned a great deal. I am not really sure who had more fun, the students or the teacher. We spent the afternoon model flying and lots of pulled pork, potato salad, beans, etc. In the evening Terry Dow showed up so we had to go and fly some more (darn).
    Good times and great friends at The Good Life Ranch. Thank you Bill...
    David Childs
    "Whether you think you can or whether you think you can't, you're right!"
    Henry Ford
  38. #158
    fancypants's Avatar
    Jan 2011
    IL
    372
    Looks like fun! Keep plugging away, Greg.
  39. #159
    Meanwhile,...
    5,231
    Hey Bill, you need the name of a Relator yet... It’s all a conspiracy, to make an Okie out of you!
  40. #160
    3
    Thumbs up
    Quote Originally Posted by flymore View Post
    Talked to Kaden today... He said had the 3rd best day of his life at your get together. Only his wedding day and kids birth beats his time at your place! You and Bill are always making people smile.
  1. Cal's Supercub Build
    By Iflylower in forum Experimental Cubs
    Last Post: 10-15-2011, 08:23 PM
  2. Replies: 15
    Last Post: 05-02-2007, 09:04 PM
  3. need help to find or build a supercub jig
    By funcub in forum Cafe Supercub
    Last Post: 11-08-2003, 03:05 PM
