Page 3 of 11 FirstFirst 12345 ... LastLast
Results 81 to 120 of 419
Thread: Greg's Supercub Build
  1. #81
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,309
    Great progress! Love the updates!
  2. #82
    May 2011
    Oklahoma
    297
ID:	13000Click image for larger version.
    Baggage doors roughed in.
  3. #83
    Lowrider
    Nov 2012
    Idaho Panhandle (ID05)
    1,702
    Greg,
    Very nice!! Should they be hinged in the front so they will stay closed of blow against the fuselage if they become unlatched in flight?
  4. #84
    Larry G's Avatar
    Nov 2010
    Minocqua WI
    282
    Greg,
    Thats what the lock is for.
    Larry Experimental Supercub PA18 wide body
    http://www.mykitlog.com/Supercub
    I'm positive there is no life on other planets - if there where, America would be sending them financial aid
  5. #85
    May 2011
    Oklahoma
    297
    Lowrider, I have seen the the upper door hinged on the side. It looks like it works good that way. I chose the hinge on the bottom the door because the frame tubing is there and will in turn make the hinge stronger there. The side of the door jam is not as strong, small c chanel and stringer. I am always open to ideas. Thanks you for your input I am considering it. Greg
    Thank you Larry, alway appreciate you input.
  6. #86
    docstory's Avatar
    Feb 2007
    Anchorage, AK
    664
    Just make sure you pull the key out of the upper baggage door after unlocking it so it doesn't scuff the paint/fabric when open.
    With guns, we are 'citizens'. Without them, we are 'subjects'.
    "To be born free is an accident. To live free is a privilege. To die free is a responsibility."
    --- Brig. Gen. Robby Risner
  7. #87
    May 2011
    Oklahoma
    297
    Quote Originally Posted by docstory View Post
    I know, I thought of that. After I was finished of course. ;( You are right, it hits right on the side stringer if you can's see in the photo. I will just pull the key every time. I'll have a silent rule to keep the key with the ignition key and never leave it in the baggage door either way. I will also make a spot for a complete spare set. Thank you doc story, Greg
  8. #88
    Lowrider
    Nov 2012
    1,702
    Quote Originally Posted by Larry G View Post
    Just trying to point out that stuff happens....lock or not.
  9. #89
    docstory's Avatar
    Feb 2007
    Anchorage, AK
    664
    Quote Originally Posted by Greg Campbell View Post
    You're welcome.
  10. #90
    May 2011
    Oklahoma
    297
ID:	13229Click image for larger version.
ID:	13230Click image for larger version.
    I am working on the cowl doors. I have the hinges drilled, and I am starting to work on the bottom edge of the doors, as well as drilling the holes for the latches.
  11. #91
    May 2011
    Oklahoma
    297
ID:	13612Click image for larger version.
ID:	13613Click image for larger version.
ID:	13614Click image for larger version.
ID:	13615Click image for larger version.
ID:	13616Click image for larger version.
ID:	13617Click image for larger version.
ID:	13618Click image for larger version.
    Here are a few update pictures for the thread. I have been working on both ends of the fuse. I have had some victories and losses. The nose is coming along well. I have also pretty much finished up with the aft controls as well. I still have a few odds and ends to finish up. Examples are final grease and castle nuts on my upper pulleys. My defeat has come with this darn glass on the upper door. I've cracked it drilling twice, ug... I just need to get the right bit for an oversized #6 screw. I have two holes drilled in the top of the windshield. But I have decided to wait for the right bit to finish here. I am very close to disassembly for covering.
    I am going to OK18 this weekend and I hope I get to see a bunch of you friends. That's the update. Greg
  12. #92
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,309
    Nice work Greg, coming along nicely! For the holes in the windshield or other plexi, you can use a .223 shell casing, heat the neck until dull red and then melt your hole. Works great and no stress riser cracks from drilling. I don't remember where I got the idea from but if you are out there, you get all the credit!
  13. #93
    10,487
    Try a "unibit" drill. It worked great for me. There is just one cutting edge which doesn't grab and crack the plexi.
  14. #94
    May 2011
    Oklahoma
    297
    Thank You. I really appreciate the help. Greg
  15. #95
    White City, Oregon
    920
    There is a special way to "sharpen" a standard drill bit to use on acrylic plexiglas... This website http://www.plasticgenius.com/2009/03...lexiglass.html has a fairly good pic on how to grind the bit... You still need to use a wood block backer when drilling..
    Brian
  16. #96
    Little_Cub's Avatar
    Feb 2011
    Palmer, Alaska
    268
    Quote Originally Posted by Steve's Aircraft (Brian) View Post
    Brian
    also works to just heat/wear it thru in reverse.
  17. #97
    10,487
    Quote Originally Posted by Little_Cub View Post
    This is the method which I used to use, until someone here mentioned the unibit. Spinning a drill backwards leaves a little pile of plexi slag on the back side of the hole. This needs to be cut off and is easier done before it cools, which happens quickly.
  18. #98
    May 2011
    Oklahoma
    297
    Thank You. Those are great ideas. I will give it another go after ok18. I have one missing strut coming in the mail. I'm also waiting on my ailerons and flaps. Hope to get those by December so I can finish the wing tip bows. I want to roll right along on the covering process. I'm going to put the wings on like they are just to make sure everything is right before starting to cover. Greg
    Thanks Beaverpilot thanked for this post
  19. #99
    10,254
    The unibit/stepdrill doesn't grab the plexi, Alum, etc.... as it exits like a fluted bit will. It also drills a " round " hole, something a fluted drill won't do.
  20. #100
    Yooper Cub rotto789's Avatar
    Mar 2009
    Mi. ( Yooper)
    194
    Ditto the unibit procedure, worked great for Me also.
  21. #101
    May 2011
    Oklahoma
    297
ID:	13943Click image for larger version.
    Update, we are working on riveting the boot cowl to support the engine cover and cowl. My helper (the whole reason this is possible) and I are learning to buck rivets. I'm glad we did the bottom first, will need a little bondo on the first rivet. We got the hang of it after that. FedEx called, the strut I was missing will arrive in the morning. Moving back to the brakes next. That's some of the stuff I'm up to. -Greg
  22. #102
    Iflylower's Avatar
    Aug 2008
    Memphis, TN
    1,351
    Getting the wife invested....GOOD IDEA!
    Progress, always forward. Looking good.
    "There are three things in life that people like to stare at: a flowing stream, a crackling fire and a Zamboni clearing the ice." Charlie Brown
    Please Join and Support the RAF! http://www.theraf.org/
  23. #103
    19,911
    Keep up the great work Greg.
  24. #104
    windy's Avatar
    Dec 2005
    Utah
    706
    Looks like you're moving right along, Greg. Hope to see your Cub at OK18 this spring!
  25. #105
    May 2011
    Oklahoma
    297
    That would be awesome Wendy. I keep believing what everybody says, just keep working on it everyday and that great day will come. I trying not to put a date on it. I'm doing as much as I can right now. I do know I miss clawing for sky, cruising across the range, and controlling that sink rate on approach like you can't believe. That is my biggest motivator. I really appreciate the support and answers to my questions from all who are helping me.
  26. #106
    Bill Rusk's Avatar
    Sandpoint, Idaho
    5,339
    Awesome Greg. I know you will get her done.
    Very Blessed.
  27. #107
    C130jake's Avatar
    Sep 2012
    Minnesota
    411
    I found putting a piece of masking tape on the end rivet gun helps. Ymmv.
    Jake
  28. #108
    Jun 2002
    NC
    402
    Those circles or, smiles, around the rivets are so you can find them in the dark. Looks normal to me.
    Thanks rmac thanked for this post
  29. #109
    May 2011
    Oklahoma
    297
    I will try the tape idea. I showed the top view because the gun got away from me on the bottom side on one of the rivets. I tried to doctor it up a bit. The smart builder would have practiced a bit on scrap. The guy on the Utube video made it look so easy though. Easy on the trigger..... Lesson learned. Thanks for your input.
  30. #110
    10,487
    Reduce the air pressure and use a heavier bucking bar. Start with a low pressure and work up to a pressure that you can handle. Practice with scrap. Soft aluminum is more susceptible to defects.
  31. #111
    19,911
    It's called patina Greg. After it is assembled and painted you will always see it but no one else will. I have shot tens of thousands of rivets and I still get those from time to time. Actually I think I still have some panels from the polished Luscombe rebuild that had one of those out of thousands. That really tics a guy off.
  32. #112
    Larry G's Avatar
    Nov 2010
    Minocqua WI
    282
    If I remember correctly I was at about 35-40 psi when doing rivets that size
  33. #113
    May 2011
    Oklahoma
    297
    Gosh, I feel not smart. I will try using the regulated side. I guess I was trying to really do it up right with 150 psi behind the gun. Steve, I hear you. It's not going to be perfect, I know, but when ever I ding something like that, It's like dang.... I've learned so much from when I started. Still so much to learn. I'm already thinking of building another Cub after this one and after I get caught up from throwing 100 bills in the fire and caught Making my wife think she more my favorite than the Cub. I tell her, but I think it's going to take some showing her. You know Furniture and Jewelry always helps. Enough Rambling, Really appreciate all of you guys.
  34. #114
    flymore's Avatar
    Nov 2005
    OKC
    58
    Greg, the project looks great. If you get down a little just look at the first pictures you posted of the Cub. Wow...a lot of progress in a year. These things take time, just ask anyone who has done this before. A lot completed, a lot to do....baby steps.
    Having your wife help is a bonus.
    David Childs
    "Whether you think you can or whether you think you can't, you're right!"
    Henry Ford
  35. #115
    pittsdriver's Avatar
    Feb 2008
    221
    If you haven't got your fabric yet the lady at Colorado Classic Aircraft does fuselage envelopes with the nicest seam you will ever see. It is so flat and perfect you can lay it right down the middle of the top stringer. Only around 60 bucks and the cost of the fabric. DonClick image for larger version.
ID:	14101Click image for larger version.
    Vans RV7 finished 2008
    Backcountry Super Cub finished 2011
    A&P Aircraft rebuilding, Building assistance
    1956 Supercub complete rebuild
    Likes overactor liked this post
  36. #116
    May 2011
    Oklahoma
    297
    That looks really nice. I do have my fabric and all my covering through silver from Jason at Stewart Systems. I bought it last year. . I'm a little worried about my gallon of Ecofill and it's shelf life. Flyingmissdaisy I believe is his handle called me on it last winter. In my zest to get back flying I believed I would be done much sooner than reality has dictated. I had a hard dose of what ready to cover really is. That being said I am feeling covering is on the door step. I'm looking forward to visiting Bill at Poplar Grove late this month to help him and gain covering experience. My winter will be spent trying to do as much as money will allow. In the Spring I hope to have a little tax refund change to try and buy some of the other 90 percent, Used instruments, antennas, seat covers, top coat paint, transponder, and all those other things this first timer hasn't thought of. I am looking forward to hanging with everybody at Graham again this year. Trying to get as much done as I can before then. Keep the advice coming, I really appreciate it. I couldn't do this with out you guys. Greg
  37. #117
    May 2011
    Oklahoma
    297
    I leak tested the fuel selector valve fittings this evening. No leaks. It was good to see no leaks.
  38. #118
    Little_Cub's Avatar
    Feb 2011
    Palmer, Alaska
    268
    Does your selector shut everything OFF when in that position or allow cross flow between the wings?
    Some manufactures definition of OFF is not what you might expect.
  39. #119
    May 2011
    Oklahoma
    297
    I have an off, left, right and both on my valve. On the advice of a friend I plugged all four fuel tank lines and and then applied around 7 pounds of pressure. Sprayed the fittings downs with soapy water. No bubbles.
  40. #120
    May 2011
    Oklahoma
    297
ID:	14579Click image for larger version.
ID:	14580Click image for larger version.
    Hey guys. One of my friends was saying I haven't updated in a while. So here is an update. I'm installing the tip bows this week. It's going pretty well. I'm still waiting on my ailerons to get here so I'm going to wait to attach the bow to the rib next to the aileron. My ailerons come straight out instead of tapering like the certified Cubs do. On that subject if anybody out there has Smith wings like these and could send me the measurements out to the bow tip on that rib that would help. Otherwise hopefully the ailerons will arrive this month so I can get the plane ready to rig. I am ready to cover the fuse and tail feathers just want to rig it first to make sure it's all correct. I don't want any surprises after its already covered. That's the update. Sure will be great to get it flying. Greg
  1. Cal's Supercub Build
    By Iflylower in forum Experimental Cubs
    Last Post: 10-15-2011, 08:23 PM
  2. Replies: 15
    Last Post: 05-02-2007, 09:04 PM
  3. need help to find or build a supercub jig
    By funcub in forum Cafe Supercub
    Last Post: 11-08-2003, 03:05 PM
