grizzly one
Looking to install new fuel sight gauges,any preferances?
http://www.fadodge.com/index.php?op...-system-sight-gage&cid=8:fuelsystem&Itemid=53 only way to go if these are certified. Ops i see there only for atlees tanks.
Steve, I have a set of each, which way is up for Dakota Cub and Piper? Seems to me that you should turn the Piper ones over from what you have shown to show fuel down to 0? And do you have a part number / source for the sleeve? And does the 'restricted' elbow go on the bottom? Don
that's all I use, and field approve them to the different tanks... "deviated from STC by installing them on XX gallon tanks"
Gordon I'd like to know that as well!
I have the Atlee 30 Gal tanks on my certified cub, and the sight gages (Cubcrafters I think) on there look pretty but are horrible because the float balls are in the bottom metal area when I still have 15 gal left a side........I also run a totalizer but not seeing any fuel in the sight gages is unnerving to me.
I've been considering the Atlee Tygothane tubes because they dont have the metal on the top and bottom......anyone using/liking those?? They are very spendy for what they appear to be but they give you the visibility down low!
Tim
They work great, but get yellow and more opaque with time.
Sent you a PM.Good timing, What do you want for them?
Has been an age old problem since the early under wing sight gauges.....[emoji15] My old 12 guages will show only 3/4 per side after 30 mins of flight filled right to covers.... When the ball is disapearing into bottom aluminumSent you a PM.
