Just got my fuel tanks back from F A Dodge after replacement of the fuel filler neck and general repair ( first class folks!), When i called aircraft spruce for fuel hose they told me the h6000 hose that was installed was not good for this purpose. Original hose was dated 1/90 and i had not had issue, I would prefer to do the right thing h6000 is available through other sources andI have some ordered. My IA basically stuck his fingers in his ears and walked in circles chanting la la la la etc. I think he was having a bad day.
The sections of hose are short really just a connection sleeve and maybe as much as a 45 degree turn between nipples.
Does the 303 hose fit over the nipples?
Is this the proper stuff?Is 13/32" the proper size for 3/8" nipples?
Single clamp sufficient?
Thanks for your help in advance!
